Question about Samsung 793S 17" CRT Monitor
Problem in my samsung 17``(793s ) monitor
There is a problem in a monitor when i connect the monitor to the pc the monitor switches off we checked almost all the sections and replaced almost all the major components please help me which section would be defective and what am i supposed to do
    Scholar:
  • 116 Answers
These are so hard to narrow down the problem with as these monitors are becoming obselete. You should replace it! If this is the type you want to continue to work with since they are not popular anymore you could go to a local PC store and purchase one at a very low cost! Or shop for one online!
Posted on Nov 26, 2007
SOURCE:
My samsung q320 will not detect my projector
Connecting an External Monitor or Data Projector
You can switch to an external monitor or data projector by two methods. 1. Connect the external monitor to the laptop's video port, power up the external monitor first and the laptop. The video information will automatically switch to the external monitor. 2. If you power up the laptop first then you can switch the video output to the external monitor by pressing the Fn key and one of the Function keys, depending upon your make and model laptop. You can also toggle between the external monitor or both LCD screen plus the external monitor or back to LCD screen only by pressing the Fn key plus one of the function key a few times. Here is a list of key combinations for some of the laptops :- IBM ThinkPad = Fn + F7 HP and Compaq = Fn + F4 Toshiba = Fn + F5 Dell = Fn + F8
Jan 12, 2013 | Samsung Q32032P PC Notebook
Samsung 920nm sync master Black screen
Samsung sync master monitors were well known for bad capacitors, if you have a esr capacitor meter you can check in circuit, if not look for dome shape at the top of the capacitor, a dead give away it is open, also check for poor solder connections in the power supply inverter board area.
Jun 20, 2012 | Samsung Computers & Internet
I have a samsung 740N 17" TFT monitor. When switch on computor(its CPU) and then monitor. Monitor goes to slip. There is no sign of its on, except blue light at bottom right of the monitor.
Try connecting another monitor to the computer.
If it works, then the monitor is faulty and should be checked .
If it does not work, then probably the videocard of your computer needs to be replaced.
Mar 05, 2011 | Computers & Internet
Check signal cable
Check if the monitor is not working by connecting this monitor to another computer.
If the monitor woks on another pc, then the pc is the issue and not the monitor.
If monitor doesnt work on the other pc, then it's the monitor that needs replacing.
I hope this helps you :)
Jul 13, 2010 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Samsung 56V, difficult to switch on the monitor
check the capacitors inside the monitor, as they may be broken, and they start screen up, just change em and it should kickstart fine
Sep 19, 2009 | SAMTRON 55V 15" CRT Monitor
42 inch samsung plasma tv
please check the cables whether the 15pins signal calble is connected properly, and checke the resoultion is too high than 1024x768 to 1280 x 1024 , if it is high change to lower like 800 x 600 or 1024x 768
or restart the computr and press and f8 function key and selecte safe mode and do above
Aug 13, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
Samsung syncmaster 551v
you dont have problem with your monitor, check your cpu very well am very sure you have problems with your system board
Jul 17, 2009 | Samsung SyncMaster 151 N 15" LCD Monitor
Samsung SyncMaster 510N LCD TFT Monitor
Does the monitor remain on does it switch off?
Problem seems to be hardware related ie monitor itself is defective.Try connecting to another known working system.If monitor is defective it could be a power/inverter related issue or panel could be defective.
Please provide feedback and rate the solution.
Samir
Jun 13, 2008 | Samsung SyncMaster 510N (Silver) 15 inch...
Screen on first start doesn't work
I have a SyncMaster 931BW which I duel Screen with a analogue montior.
There are Three things that I would check:
  1. Connection: if you are using the DVI adaptor, try using just the analogue (VGA) connection into your PC. You may have a faulty DVI adaptor which the PC cannot detect an output device.
  2. Drivers: If you have a standard monitor connect that to the PC and see if there is any output, if so, you may need to install the drivers for your monitor. You should have a Samsung Drivers Disc, or visit the Samsung website: http://www.samsung.com/uk/support/download/supportDown.do?model_nm=930BF&mType=DR&vType=L
  3. Cable: ensure that the cables are not knotted, and that within the adaptors the pins are all there and not bent as there is not a proper connection with the device.
Try them.
Jan 01, 2008 | Samsung SyncMaster 930BF 19" LCD Monitor
Samsung 793S 17" CRT Monitor Logo
37 people viewed this question
Top Samsung Computers & Internet Experts
Ekse
asber
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
