Question about Dell 944 All-In-One InkJet Printer
It says change cartridge, carriage jam, and a little white clip
A white clip fell out
  • 34 Answers
It is probably of an ink catridge so just buy a new one
Posted on Apr 13, 2009
Disconnected white cable
if it is a flat cable some of them had a little clip that would slide back allowing you to reattach the cable some do not
Jan 29, 2014 | Kodak ESP Office 2150 Wireless All-In-One...
What is carriage jam
the carriage is the interconnecting parts between the tray and the rollers
you have to open all the doors and remove all the drawers completely
then open the unit itself and roll all the rollers by hand.
a little TLC will have her running in no time,......
ps dont clean with anything other than air
Apr 07, 2011 | HP Officejet 5610 All-In-One InkJet...
I just changed the (2) ink cartridges in my HP PCS 1610 All-in-One HP printer and now get an error message "CARRIAGE JAM - OPEN DOOR. CLEAR CARRIAGE JAM, AND THEN PRESS OK." I don't see any jam...
Have you tried moving the carriage to see if it really is jammed? Maybe you haven't put the levers down properly on your new cartridges....remove them, see if the carriage slides, then refit them and check the carriage again. You wont visually 'see' a carriage jam,; you have to try moving it. By the way, if it doesn't move, DONT force it to try and overcome the jam try and reason out why it doesn't move.
Hope this helps!
nicam49
Jan 18, 2011 | HP PSC 1610v All-in-One Printer
Copier makes a noise when first turned on and then it tells me to open the door clear carriage jam and press enter. But that does not work. The printer has been sitting for a little...
Check the following steps for fixing Hp Carriage Jam Error :
Open the print carriage access door. Check for any packing material that may be blocking the internal components. Check for an orange shipping lock that may still be in place on the left side. Pull the shipping lock out, if present, and discard.
Remove and reinstall the cartridges to make sure they are properly installed. Lift the front center of the print carriage access door to open it. Lift the door up until it locks into an open position. Press down on a print cartridge and allow it to spring back up. Lift the cartridge out of the printer. Do the same for the other cartridge. Slide the black cartridge into the slot on the left and the color cartridge into the slot on the right. Press down on each one to lock it into place. Lower the print carriage access door.
Check the print cartridges to make sure the protective tape has been removed from the ink nozzles. Remove the cartridges from the printer. Remove any tape or labels. Replace the cartridges into the printer.
Push in on the tab on the left side of the clean-out door on the back of the printer to open the door. Lift the door out of the printer. Check for any paper jams. Jammed paper can block the printer cartridge carriage from moving. Pull any jammed paper out.
Nov 29, 2010 | HP PSC 1600 InkJet Printer
The status and power lights are flashing and the printer carriage is stuck in the far right position. There are no paper jams or any other visible problems. Any help would be appreciated!
  1. Disconnect the power cord from the printer.
  2. Open the top cover.
  3. Find the metal clip that is attached to the exposed side of the carriage
  4. Follow the metal clip to the bottom of the carriage. Straight back from the bottom of the carriage is another metal clip that is pointing toward the back of the printer
  5. Using a screwdriver or similar tool, push the metal clip (indicated by call-out 2 in the graphic below) toward the back of the printer.
  6. Gently rock the carriage up and down while pulling the carriage from the right-hand side toward the center of the printer.
  7. If the carriage is still locked in place, push the metal clip
  8. After the carriage is pulled out from the right-hand side of the printer, remove both print cartridges
  9. clean the connections and reconnect them
  10. Push the carriage back to the right-hand side of the printer.
  11. Close the top cover.
Properly storing the ink cartridges will increase their life. The following are guidelines for storing cartridges for future use.
Place the cartridges in a standard paper envelope
Jan 05, 2010 | HP DeskJet 940c InkJet Printer
My canon i850 is blinking 3 orange lights at me and refusing to print. any ideas. tried turning on and off. removing print driver and re-installing thanks!
3 blinks is a line feed error, something stopping the platen roller from turning, look inside where the paper goes and see if something fell in like an ink pen, paper clip, just something that doesn't belong. The platen roller is the gray roller behind the carriage and sometimes you can see thru under the white plastic guides something jammed.
Nov 25, 2009 | Canon i850 InkJet Photo Printer
Won't print. Message says "carriage jam. Open door and clear carriage jam." There is no jammed paper or anything visible. Put door back on, still won't print. have turned on and off, and reinserted paper....
It is giving carriage jam not a paper jam the carriage is the part which carries cartridges on it. It seems your carriage is jam and can't move left and right so open the door and try to move your carriage with the help of rubber roller which moves your printer. Also clean the steel road on which the carriage moves just check at the corner of cartridge carriage if any paper bit is stuck or excessive paper dust has jammed it. If this does not solves your problem kindly comment back.
Jul 28, 2009 | HP Photosmart C5180 All-In-One InkJet...
Carridge jam problem, please help me to fix this problem. it is a 6310 all-in-one printer.
THat happened to me while changing out a printer cartridge before the carriage had fully stopped. I was able to gently move the carriage over a little bit...
Mar 24, 2009 | HP Officejet 6310 All-In-One InkJet...
I have HP Office Jet V40. I changed ink cartridges. When I put the printer on, there was a message in the window, "Clear carriage jam, and then press Enter." I opened the door and had a good...
Open the lid and uplug the power cord, then reach in there and give the whole carriage a little boost one way and the other, my photosmart 8450 does this once in a while and once I move it a little and plug it back in, it goes where it should be.
Aug 07, 2008 | Office Equipment & Supplies
Printer shows Carriage Jam, but I can't find it.
many reason coses carriage jam bout i think that the in coder belt faulty
Mar 23, 2008 | HP Photosmart C4150 All-In-One InkJet...
Dell 944 All-In-One InkJet Printer Logo
73 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
