Question about Dryers
We have a Kenmore Elite gas clothes dryer (110.73952101). It will not completely dry large loads. We have to reset timer and restart the dryer. If we set timer for 40 minutes, dryer may run for 10 minutes and then cuts off again. We have to repeat this process several times to get load dry. Any suggestions?? Thanks much, LR
  • 77 Answers
Loads may be too large. Also when you reset and restart, the heat overload is cutting out. If your discarge is kinked or not venting properly this will cause it not to dry as well. Also check your lint screen. Good Luck!
Posted on Apr 13, 2009
Kenmore 400 series gas dryer doesnt dry clothes
Replace timer, if you are sure that it is not working.
Do an internet search for kenmore driver parts and get dozens of hits.
Aug 03, 2014 | Kenmore Dryers
Kenmore Elite Model 110..71082000 Gas Dryer wont stay on to dry clothes
If the dryer lights and then goes out, you will need to replace the flame sensor. Here is the part to order.
Nov 06, 2012 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Model 11087731700, the timer decreases during cycle and stops before items are dry.
check the venting for your machine, the normal problem for clothes that don't completely dry is clogged vents , if your vent is clear and free from any buildup , you could have a bad thermostat which shuts the heat down too early as the drying cycle progresses
Jun 21, 2011 | Kenmore Dryers
My Kenmore Elite Gas Dryer in Refresh mode the cloth comes out wet.
I think the refresh mode is a no heat tumble only setting... just to fluff your clothing...
if they were wet they will not dry on that setting...
heatman101
Aug 27, 2010 | Kenmore Elite Oasis 7808 Gas Dryer
2 to 3 cycles to fully dry clothes
if the clothes are warm after the cycle then you need to make sure the vent to the outside of the house is not plugged if they are not warm then it is in the heating circuit of the dryer wether it be the element or a fuse will have to be tested. to dry clothes it takes heat and air flow if you dont have one of the two they will not dry correctly
May 18, 2009 | Kenmore Elite Oasis 6808 Electric Dryer
Takes too long to dry or keeps running when clothes are dry
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
May 07, 2009 | Kenmore Elite Oasis 6809 Electric Dryer
Kenmore Elite dryer heats but does not dry
Make sure that your vent tube is not kinked or crushed behind the dryer and it all this is ok then you need to change your cycling thermostat. is it gas or electric
Mar 12, 2009 | Kenmore Dryers
Kenmore Elite HE3 Dryer clothes not dry after cycle
it sounds like a clog in vent.if yours vents up thru roof you may need to have a chimney sweep come out and sweep vent.check and make sure the vent hose is net kinked or full of lint.
Mar 06, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Dryers Logo
129 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
