Question about Panasonic PT-50LC13 50" Rear Projection HDTV
We replaced the lamp in our Panasonic PT50LC13 and we still have the blue screen.
    Novelist:
  • 159 Answers
If the tv had the lamp blown, probably the screen was totally black.
the blue screen: there is not signal detected.
  • If is any other input available try to search for video or audio.
second: it is critical to know if the menu apears when you call it (front panel or remote control)
Posted on Apr 18, 2009
4 Suggested Answers
  • 108 Answers
SOURCE: i replace the lamp for
Make sure you have the lamp door or cover installed correctly. If it is not installed correctly it will not fire because the door cover engages a safety switch. Also make sure the lamp is seated properly. If all is well then suspect a defective lamp driver or ballast PCB
Posted on Jan 11, 2009
welcomejee
  • 10594 Answers
SOURCE: A warning pops up on the screen of my Panasonic
After replacement of lamp, turn on TV, press and hold Volume Down button on TV front and press and hold Split/ Play button on TV remote at same time for 6 seconds.
That will reset lamp timer and confirmation display will come at TV screen.
Above info are also available in original Panasonic replacement Lamp box.
Posted on Aug 19, 2009
  • 117 Answers
SOURCE: my panasonic PT50LC13 after awhile just turns off.
Did you reset the lamp timer?
Posted on Aug 13, 2010
Panasonic tv PT50LC13 has no picture red light flashes when i turn it on green light flashes and turns off
This model was recalled by Panasonic-----massive recall. Start by having the lamp examined or tested---that is the place to begin.
Oct 17, 2012 | Panasonic Televison & Video
The lamp light is blinking once every 5 seconds. The manual says that " Lamp will not light or light is abnormal"
HI,
Panasonic PT50LC13 lamp indicator blinks to tell you the lamp is faulty.
You need to replace the bulb or TY-LA1000 lamp assembly. This link displays all Panasonic TV Lamps and TV Bulbs. This page shows Panasonic lamp location and How to Replace TYLA1000 bulb. TY-LA1000 Bulb Replacement requires the use of a long Philips Screwdriver to reach screws within the lamp cage.
Unplug AC power before removing the lamp and re-install all doors, etc, correctly before starting the TV. Vacuum any visible dust or lint from air vents and lamp area. Do not used forced air to blow out dust, big problems may result.
The user's manual has a description of what the Blinking LED indicators mean.
Image of TYLA1000 lamp.
Robert
Apr 14, 2011 | Panasonic PT-50LC13 50" Rear Projection...
Having problem with my Panasonic TV.
hello Plug the power cord back into a properly grounded wall outlet. Then press the POWER button on the projection display or the
remote control to turn the power on
While pressing the VOL- button on the projection display,
hold down the PIP or SPLIT button on the remote control
simultaneously for more than 5 seconds
When the lamp time reset procedure is complete, the
above screen will appear. (This screen may be different from
the actual screen
Note:
When the lamp time reset is complete, the LAMP
indicator goes out.
regards
shaun
Jan 18, 2010 | Panasonic PT-50LC13 50" Rear Projection...
I want to know how to reset the lamd on panasonic
HI; The instructions will come with the lamp itself for your model Television, as long as the lamp was an OEM type lamp.(Original Equipment Manufacture)>>>
Dec 21, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Tv won't turn on
You may need to replace the lamp, and if this is the case make sure you pbtain information to reset the lamp use hours so that the tv will recognise that their is a new lamp in the unit, Good Luck.
Sep 24, 2009 | Panasonic PT-50LC13 50" Rear Projection...
A warning pops up on the screen of my Panasonic PT50LC13 That my lamp needs replacing and I need to reset the lamp timer, how do I reset the lamp timer?
Aug 19, 2009 | Panasonic PT-50LC13 50" Rear Projection...
I replace the lamp for the panasonic pt50lc13 now it is just flashing green. what did I do wrong and how do i reset the lamp
Dec 08, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic PT-50LC13 50" Rear Projection HDTV Logo
113 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
