Question about Toaster Ovens
Burnt pie cook a pie in the oven it burnt because the top heating eleiments kept comming on. i had it on bake not broil. i even pre heated it for 10 mins before i put the pie in. i have never had a toaster oven do this.am i doing something wrogne?
    President:
  • 267 Answers
YES YOU ARE your trying to bake something in a toaster oven :) toaster ovens have two modes toast /bake in this mode top and bottom elements get hot .and broil in this mode only the top elements get hot . the problem is the marketing the word OVEN makes you think of a normal oven that the bottom elements do all the work . toaster ovens work well melting stuff and toasting . thats about it . if you must bake in it try placeing a sheet of foil on top of your baked goods it might insulate the top of you food . good luck ... if this answer helped please rate it a 3 or 4 stars , this high rateing will help keep me in the paid answer department , thank you
Posted on Apr 19, 2009
My cobbler run over in my oven what can I use to get it off?
Posted on Aug 30, 2009
Is preheating this toaster oven necessary? How do you preheat?
Preheat is helpful when you're not cooking for more than a few minutes. If you're going to cook for 20 minutes or more, then most likely you don't need to pre-heat.
To pre-heat, simply turn your toaster-oven on 10 minutes before you put the food in.
Feb 27, 2016 | Toaster Ovens
I have a Black & Decker Toaster Oven Plus. The only number I could see was, toaster listed 228E. It bakes, and toasts only the underside of bread. It no longer broils. Do I need to replace the top element,...
Mine has The same problem and I am trying to fix it I don't see anything burnt and everything seems to be put together and write and I can't understand why the top bars would not heat up,I need help to prepare this thing I love it so much
Aug 13, 2013 | Black & Decker Toaster Ovens
The toast part works but the bake and broil does not work , the blue light does not come on and no heat is produced
We've got the same problem and I just took ours apart.
Bad news: I'm pretty sure it's the circuit board. It's not the timer knob, and I'm almost positive it's not the upper selector knob. Most of the components on the circuit board are only used for the "bake" mode to regulate temperature. The board is marked, "128301 Timer PCB". I looked into whether one can buy a replacement board from Kitchenaid, but it's not on their parts list. If I had to guess, I'd say it's the relay on the board, but it's only a guess. Shoddy components, plus it gets hot in there and "bakes" the board. The little fan in the side isn't part of the "convection." It's for cooling off the circuit board. Don't laugh.
Even worse, next to the thermostat on ours, there's a little rubber insulator that's burnt to a crisp. The connection under this insulator was also loose. It hasn't affected functionality, but it doesn't instill confidence in the design. Kind of scary. Unplug this unit when not in use!
Only a one year warranty. I think we now have an expensive toaster.
Jul 24, 2011 | KitchenAid KCO1005OB 1400 Watts Toaster...
How to clean the inside walls of a delonghi alfredo toaster oven?
pour water in the pan with little detergent for dish,and heat it on 30 deg Celsius for about 30-50 minute,and wipe the walls with cotton rag.
Jun 29, 2009 | DeLonghi XU620 Alfredo Ultima Bake 'N'...
Labels on black and decker toaster oven worn off CT0650C
Top dial is Bake/Broil knob, it goes left to right. Starts with OFF @ 9 0-clock next is 100 dgre then @12 o-clock 180 Deg. is at top center next is 250 Deg. next 350 located opposite of off. Next @ 4 o-clock is 400 Deg. Next @ 5 o-clock is 450 Deg. and finally at the bottom at the 6 o-clock position is BROIL. The Center Knob is BAKE TIMER . Starts @ off position as 0, next @ 10 o-clock is 10-mins. Next @ 12 o-clock position is 20 mins. Next @ 2 o-clock pos. is 30 mins. Next @ 3 o-clock pos. is 40 mins. Next @ 5 o-clock pos. is 50 mins. Next and finial pos. is 60 mins. The Bottom knob is TOAST @ the 9 o-clock is is 0 next @ 11 o-clock pos. is Light , Next between the 12 & 1 o-clock pos. is MEDIUM and the final pos. @ 3 o-clock is DARK. TOAST.
Jun 13, 2009 | Black & Decker CTO650 1500 Watts Toaster...
Cuisinart Toaster Oven Broiler Not working properly
This is not a defect - it is just how the unit operates. You can set it to Broil, and the top element should not come on. Make sure the wire rack is turned upside down so that it curves inward and try one more time.
-Tha Mp3 Doctor
Jan 04, 2009 | Cuisinart TOB30BW Toaster Oven with...
Toaster does not work!!!
I investigated further (took it apart again to satisfy my curiosity) and it appears that one of the top heating elements (the front one) is open (burnt out). I cannot see an easy way to replace it (contacts are spot welded) and I can't find a place to buy the element. If I could it probably won't be worth it since a new oven costs $25 at Target (B&D TR0490W). Too bad since the oven looks like new. I assume the upper elements burn out more frequently because heat rises from the lower elements and adds extra heat at the top.
Jul 02, 2008 | Black & Decker TRO360 Toast-R-Oven Toaster...
Black & decker toster oven
Black and Decker Toast-R-Oven Countertop Oven/Broiler Mfg Part No: CTO650
same problem here, toaster works, then when I go turn on the oven ........nothing!
Oct 29, 2007 | Black & Decker CTO649 Toaster Oven with...
What is exactly a toaster oven?
A toaster oven is a cross between a toaster and an oven. But unlike a toast, you can cook things in it like you would on a regular oven. It might also be more comfortable than a regular oven, because it heats up faster and saves energy. I even bake cookies in it! The only problem is that it is usually much smaller than a standard oven, so you probably won't be able to bake a birthday cake or a roast in it. Other than that, it's a very useful device. have fun!
Aug 06, 2007 | Cuisinart TOB-30 Toaster Oven with...
Toaster Ovens Logo
276 people viewed this question
Top Toaster Ovens Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Toaster Oven Expert? Answer questions, earn points and help others
