Question about Barska Optics Barska 10-40x50 Ao Varmint Riflescope, Black Matte, Mil
How do i solve for reflection and refraction in physics
What r the formulas and how do i know which one to use
  • knuclebuster May 11, 2010
    What is the actual issue? Your question says; "how do I solve for 'reflection' and 'refraction in..." and " what r the formulas and how do i know which one to use".
    Please provide more info.
    "Reflection" sounds like you are possibly getting reflections at both or one end of the scope. A rubber eye cup at the Ocular lens(the part of the scope where your eye looks through) and a shade tube at the Objective Lens will eliminate reflections on the surface of those lens. "Refraction" is the bending of a ray of light which will occur when light passes through one medium, such as glass, to another which happens when light passes through the objective lens to the Ocular lens and to your eye.
    If you will provide more info as to your issue, I'm certain there's an answer.
    In the meantime go to; www.eabco.com or www.netsolstores.com (no, I am not a rep. or have anything to do with either site) there you will find helpful scope terms/definitions that may also answer your question.
    I can also help you 'Zero' your scope to get it on target.
    What cal. rifle is it mounted on?
  • 3 Answers
Blah blah blah u use ur brain!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Posted on May 07, 2009
Need to know how to use the telescope after it is setup
Lorraine, join a club or get instruction book. An optical telescope which uses lenses is known as a refracting telescope or a refractor; one which uses a mirror is known as a reflecting telescope or a reflector. Besides optical telescopes, astronomers also use telescopes that focus radio waves, X-rays, and other forms of electromagnetic radiation.
Purpose of Telescope One Minute Astronomer
Jan 31, 2016 | Optics
What does reflect mean
The direction of light can be changed in 2 ways. One way is refraction which is usually done by a lens (eyeglasses do this). The other is reflection, most often done by a mirror. Telescopes are almost always based on reflection and/or refraction designs. A reflective telescope has at least one curved mirror, often 2 curved mirrors which focus light by reflecting a larger area of natural light on a smaller spot.
Nov 20, 2014 | Optics
If the angle of the light striking a substance is 32.0 degrees and the angle inside the substance is 15.0 degrees what is the index of refraction
Let i be the measure of the angle of incidence; let r be the measure of the angle of refraction. Both angles are measured from the normal to the surface at the incidence point. Let n_i be the index of the first medium where the incident ray lies. Let n_r be the index of refraction of the second medium.
The law of refraction states that n_i*sin(i)=n_r*sin(r)
Assuming that the first transparent medium is air, we have n_i=1. Solving for n_r we find
n_r=(n_i*sin(i))/sin(r)
For i_r=32 degrees, and r=15 degrees
n_r=sin(32)/sin(15)=2.0475
May 22, 2013 | Office Equipment & Supplies
I have the Linksys WRT54G router hooked up thru Ethernet to my desktop PC with Windows XP. I go thru a cable modem to the internet. I have 2 laptops, both with Windows Vista on, wirelessly linked to to the...
Low or poor signal is mainly caused by the following major factors:
Going Around Physical Obstructions
Wireless networks are also susceptible to obstructions that may lead to low signal. Often, the signal gets reflected, refracted or absorbed by the obstruction.
Common obstructions are:
  • Cabinets
  • Mirrors
  • Glasses
  • Metal objects
  • Thick walls and ceilings
If you have any of these objects between your wireless adapter and access point, consider relocating your access point somewhere high to get around the obstruction.
Aug 05, 2010 | Linksys Wireless-G WRT54G Router
I want to view construction diagram or a diagram that can explain Reflex mirrir lens for digital slr camera.
Same principle as a reflex telescope- might Wikipedia Schmidt-cassegrain OR reflex telescope for more info. Long glass lenses need a lot of correction for fact that different wavelengths refract at different angles, while those same beams of light bend the same when reflected.
May 10, 2010 | Minolta AF 500mm f/8 Mirror Reflex Lens
How to make a homemade refracting telescope
There are several do it yourself projects on the internet like this one:
http://www.astronomyforum.net/atm-diy-telescope-making-forum/80586-4-diy-refractor.html
and this
http://www.vintageprojects.com/telescope/3-inch.html
However I would suggest that you build a reflecting style telescope like this one. More aperture and lower cost.
http://pages.sbcglobal.net/raycash/manualv2.pdf
Feb 06, 2010 | Night Detective Optics
Opengl code
OpenGL doesn't handle photonics or any other low-level physics - you'll either need a raytracer, such as POVRAY or Blender, or you'll have to write the physics yourself, to emulate light rays of varying colours (I recommend using a HSL colour space for your physics, only translating to RGB when rendering the frame).
The refraction of a ray at the interface of the prism and the "air" can be calculated using Index of Refraction, correction factor to account for different refraction dependent on frequency (Hue) and a random number generator to emulate slight scattering.
Apr 24, 2009 | Advanced Graphics Programming Using OpenGL...
What is difference between reflection and refraction?
Here is refraction
Refraction is the bending of light as it passes from one substance to another
Here is reflection
Reflection occurs when light changes direction as a result of "bouncing off" a surface,
i think the definitive difference is a refraction is a bend in the light where a reflection is a redirection of it
GL :)
Dec 29, 2008 | Barska Optics Barska 10-40x50 Ao Varmint...
Barska Optics Barska 10-40x50 Ao Varmint Riflescope, Black Matte, Mil Logo
174 people viewed this question
Top Barska Optics Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Vladimir Frolov
Are you a Barska Optics Optic Expert? Answer questions, earn points and help others
