Question about Refrigerators
We emptied the ice maker befor we went away ,came home no ice.We checked to make sure it was in right switch on ,red light on.what else can we do?
  • Linda Shirk
    Linda Shirk Apr 13, 2009
    it is a whirlpool conquest mod# gs6shexml00
    Scholar:
  • 145 Answers
There should be a silver lever that needs to be completelty against the icemaker (pushed all the way down)- in most cases- Are you sure this is in the right position.
May also want to check the tube that is feeding your icemaker water and make sure it is not frozen.
If this doesnt solve your problem, please let me know the make and model of your refrigerator and i may be able to be more specific.
Posted on Apr 13, 2009
  • Brandon Baker Apr 13, 2009
    I would try taking a blow dryer to the tubes near the icemaker because that is the most likely cause of an icemaker not working after it was shut off is the tubes freezing.
Ice maker sotp making ice / red light blinking
J, As you open the freezer door the LED on the right should flash 2X with a pause repeatedly. When you hold the left side emmiter down the light should stay on steady. If you have this, you know the optics are good unless the ejector blades are not home. First thing to check is where the ejector blades on the ice maker are parked. They should be resting in the 2:00 position. If they are not, you could have a broken module. If they are in the 2:00 positon the next thing to check would be the fill tube. You want to make sure it is not frozen over. You can disconnect it from the back and see if you can blow through the line or visually inspect it. If all of the above mentioned check out, jump start the ice-maker. Remove the quarter inch screw holding the harness cover on the right side. Remove the harness cover. Pull the ice-maker straight out but be carefull not to smash the emmitter flap on the left side. Leave the harness connected. Get a jumper wire with the ends stripped apout a 1/4 inch. Unplug the refer and place the jumper in test holes T&H. Leave the jumper in and place the ice maker on the shelf where you can close the door. Close the door and plug the refer back in. Wait 30 seconds and open the door. The ice maker should be cycleing. Pull the jumper and place the module cover back on. Put the ice maker back in the rails. It should fill at approx the 12:00 position. Let me know how you make out. Catriver.
Jul 07, 2007 | Whirlpool Gold White-on-White 21.9 cu. ft....
57029 Side by Side Refrigerator: ice maker not making ice and red light inside the ...
Your ice maker may be turned off. The blinking light is the sensor. The switch is right beside it. Is it in the on position?
May 16, 2010 | Kenmore 57029 Side by Side Refrigerator
Whirlpool side by side Ice maker has quite making ice
Open the freezer door and on the right side , make dure the slide is in the on position . If the red light flashes twice , then pauses , flashes twice , pauses , consistently , then close the flap door on the left side of the freezer . The light should go off . If these tests work , then the cut-off optics are good , and the icemaker needs replaced , due to the cubes not dumping . Also check the coils under the front of the refrig , to make sure they are clean of dust , lint , etc.
Sep 15, 2009 | Whirlpool GS6NBEXR Side by Side...
Ice maker does not fill and produces no ice.Has almost new water filter. Red lights come on for full bin sensor. Ice maker does not move. Cavities remain in place
You need a new water valve and possibly a new ice maker. I would start with the valve first since it's less expensive. Call or email us with model number and we'll be sure to get the right part out to you right away. Hope this solves all your problems.
Sep 09, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Amana SBD21VE No water to ice maker
your water line to the fridge is most likely leaking. You should turn it off right away. The line turn off is either behind the fridge or under sink. sometimes its in basement. The line is very easy to replace. You can get the plastic ones at home centers for under 5 bucks.
Jun 08, 2009 | Amana ASD2326HE Side by Side Refrigerator
Ice maker does not make ice
check water valve check for water
Apr 07, 2009 | KitchenAid Refrigerators
Ice maker is not working but water dispenser is.
Try the following check:
First make sure that the temperature in the freezer is 5 degrees or below.
Self-Diagnostics
Unplug the fridge and then plug it back in.
If the compressor is running when you unplug it make sure that you wait 15 minutes before you plug it back in.
You will then have 60 second to open the freezer door and 2 second to view the LED output code.
Ice maker check 3 pulses pause 3 pulses
Optics receiver 4 pulses pause 4 pulses.
Optics emitter and receiver 2 pulses pause 2 pulses.
All good 5 seconds on
Dec 28, 2007 | Whirlpool ED5SHAXM Side by Side...
check you havent put icemaker onto vacation mode.. also if it has infra red sensors at both sides of ice maker unit , these can go faulty.. ally
Jul 02, 2007 | Whirlpool ED5SHAXM Side by Side...
Ice Maker
Company needs to recall....
Mar 11, 2007 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
115 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
