Question about Zebra Z6M Plus Thermal Barcode Label Printer - Motherboard
Ladder orientation barcode printing bad resolution needs correcting
A barcode that was designed to print in fence orientation. when rotated 90 degree and became the ladder orientation. Printing very bad resolution The barcode cannot be scanned. What can I do to print in ladder configuration at a higher resolution so the barcode is scanable. Printer is Zebra Z6M plus using Bar tender program.
  • 257 Answers
Try slowing down the speed of the printer. Faster speeds degrade the quality of your print. Try printing your serial (ladder) barcodes at 2-4 inches per sec. It should improve the quality of your format.
Posted on Jul 15, 2009
I want to rotate the text by 90 Degrees
you need a program to do that hp has one you can check to see if your printer has one as well
Feb 28, 2014 | Zebra Computers & Internet
Tally genicon 6605 is printing from top to bottom of the page...what could be the problem
I think it depends on what you mean by printing from top to bottom of the page.
If you are describing the print being rotated by 90 degrees so rather than a line of print going across the page from left to right, the print goes up and down the length of the page.
The most common cause of this is that you are printing from a Windows application and you have set the page orientation to LANDSCAPE rather than PORTRAIT.
With in the application you are printing from look for the PAGE SETUP options ensue you select PORTRAIT.
This should rotate the print.
Oct 18, 2013 | TallyGenicom Office Equipment & Supplies
Rotate 90 degrees
H,
To change the print 90 degrees goto print and -> properties -> under orientation select Landscape instead of portrait
May 15, 2013 | HP Office Equipment & Supplies
My acer screen is sideways. how do i fix it?
Computer users occasionally have a need to rotate, or "flip," a monitor display to be better able to read long documents or to view pictures. Because rotating a computer screen is such a basic function, modern operating systems (Windows XP and up) include hot keys and display options that enable the user to rotate the computer screen by 90, 180 and 270 degrees. Rotating the computer screen allows for more display options. For instance, when rotated 90 degrees, a 1680x1050 monitor becomes a 1050x1680 monitor, which provides more vertical pixels than a standard display.
Windows XP/Vista Monitor Orientation
Minimize any windows or programs to the taskbar. Click the desktop. Press "CTRL" + "ALT" at the same time. Press one of the arrow keys to flip the monitor orientation by 90, 180 or 270 degrees. The left arrow rotates the computer screen 90 degrees; the down arrow rotates the computer screen 180 degrees; the right arrow rotates the computer screen 270 degrees; the up arrow resets the monitor orientation. Rotate the computer screen in Windows Vista by opening the Control Panel, searching for "Tablet PC" and changing the "Orientation" drop box to the desired rotation. b> Windows 7 Monitor Orientation b> Click the Start menu at the lower-left hand part of the screen, and open the Control Panel. Select "Display," then click "Change display settings" from the left column. When using multiple monitors, select the monitor that you would like to rotate. Click the drop box next to the "Orientation:" option. Select the desired rotation and click "Apply." Click "Keep Changes" or "Revert," depending on preference. Click "Apply" in the Display Settings window. Click "OK" to finish.
Apr 11, 2013 | Acer Computers & Internet
Rotate screen back to normal
Feb 23, 2013 | Gateway Computers & Internet
My screen does not flip 180 degrees when i turn the screen around
Jan 28, 2013 | Panasonic Toughbook 19 Rugged Notebook -...
Change screen orientation
Minimize any windows or programs to the taskbar. Click the desktop. Press "CTRL" + "ALT" at the same time. Press one of the arrow keys to flip the monitor orientation by 90, 180 or 270 degrees. The left arrow rotates the computer screen 90 degrees; the down arrow rotates the computer screen 180 degrees; the right arrow rotates the computer screen 270 degrees; the up arrow resets the monitor orientation. Rotate the computer screen in Windows Vista by opening the Control Panel, searching for "Tablet PC" and changing the "Orientation" drop box to the desired rotation. b> Windows 7 Monitor Orientation b> Click the Start menu at the lower-left hand part of the screen, and open the Control Panel. Select "Display," then click "Change display settings" from the left column. When using multiple monitors, select the monitor that you would like to rotate. Click the drop box next to the "Orientation:" option. Select the desired rotation and click "Apply." Click "Keep Changes" or "Revert," depending on preference. Click "Apply" in the Display Settings window. Click "OK" to finish. Hope this helps
b>
Dec 14, 2012 | Dell Computers & Internet
I am printing a brochure that i created on microsoft publisher, but i can't get it to print double sided the right side up for both pages
Hello:
The Brother DCP-7030 supports manual duplex only. When choosing duplex (2-sided) printing, it will print the even-numbered pages first and prompts you to reinsert the pages in a different orientation.
To correctly print the second side of your brochure, you could do one of two things:
  1. Reverse the orientation of the paper when you reinsert if for the second side of printing.
  2. Reverse the direction of the second page in Publisher.
The first option is simple enough. When the Brother driver directs you to insert the paper for the second side, insert it in a rotated position. It should be on the same side, but rotated 180 degrees.
The second option is also easy, but if you want to edit the document in the future, it will involve in some work before being able to edit it.
  1. In Publisher, select all of the objects on the page (pressing "Ctrl" and "A" on your keyboard at the same time will accomplish this).
  2. Right-click on an object on the page.
  3. Choose "Group"
  4. Your objects are now grouped into one item.
  5. There should be a green dot at the halfway point at the top of the group. You can click and drag this dot until the object is rotated 180 degrees. Alternatively, you could go to the menu and choose "Arrange>Rotate or Flip>Rotate Left 90 degrees" twice.
  6. Now when you print, you should follow the Brother driver directions when flipping the paper.
Jan 14, 2011 | Brother DCP-7030 Digital All-in-One Laser...
Zebra zm400 turn printed info 180 degrees
Yu can rotate the print orientation in the Z Designer printer driver, in the OPTIONS tag tick the 180Deg box
Dec 17, 2009 | Zebra 300DPI CUTTER [zm400-3001-1000t]...
How do you speed up he printing speed on a Paxar 9800/9850?
Are you printing a serial or parallel barcode? If you don't know, a serial barcode looks like a ladder as it prints out on the label. A parallel barcode looks like a picket fence. A serial barcode (ladder) prints at 2.5 ips by default. You can't increase the speed. If you're printing a parallel barcode (picket fence) you must hit "enter' once you adjust the speed setting in the printer menu. If you've done that and it still won't increase speed, then the speed is set by the software itself, and overrides any changes you make in the printer menu. The speed adjustment must then be made in the software, not the printer.
Apr 08, 2009 | Paxar Monarch 9850 Thermal Printer
Zebra Z6M Plus Thermal Barcode Label Printer - Motherboard Logo
803 people viewed this question
Top Zebra Computers & Internet Experts
Mike
Lawrence Oravetz
Are you a Zebra Computer and Internet Expert? Answer questions, earn points and help others
