SOURCE: HOW TO PRINT LABELS IN DATAMAX PRODIGY PLUS PRINTER USING VB.NET
Tu necesitas utilizar comandos DPL. Pero si vas a utilizar graficos o windows true type fonts, tu necesitas un cartucho de memoria ram o flash. You need to use DPL commands. But if you use graphics or windows true type fonts, you need a RAM or flash cartridge.
SOURCE: Ido not have any problem if I print label using
Do you have Zebra emulation firmware installed? If not, your printer will not understand the command language that you are sending to it. Datamax has its own language and you will need a branch in your code to support that if the printer does not work with ZPL.
SOURCE: Datamax I-Class Thermal Label Printer:
Check job darkness setting and you can downlaod manuals on www.datamaxcorp.com
SOURCE: I use a 4208-I model printer. The labels print out
Might I suggest increasing the temperature of the device if it is indeed possible, consult the manual in this regard.
Thanks
damnor01
SOURCE: Got to work this morning
Uninstall the printer and restart the computer once installed reinstall the printer from the CD that came with the printer or get the latest software / pilots from the printer's web page
