Question about HP Color Inkjet cp1700ps Printer
ETB Installation procedure
How to fix a ETB for hp color laserjet 2600 series printer
  • 53 Answers
Hi I hope this is helpful for you. http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=c00314345&prodTypeId=18972&prodSeriesId=238800 Good Luck.
Posted on Sep 12, 2007
SOURCE:
Can you clean the ETB on the hp 2600n laser printer
yes you can clean it..you can use 40% solution alcohol
May 27, 2012 | HP Color LaserJet 2600n Printer
Error 59.9 after cleaning a HP 2600n
59 errors have something to do with the ETB(electronics transfer belt).
Try reseating the belt, see if that doesn't fix your problem.
When was the last time that the ETB was replaced?
Oct 17, 2011 | HP Color LaserJet 2600n Printer
How do I replace my HP Color LaserJet 4700 Image Transfer Kit? I don't have the manual for it.
Replace the ETB when a REPLACE TRANSFER KIT message displays on the control panel.
1. Turn the printer off.
2. Open the top and front cover.
3. Lower the ETB by pulling the green handle at the top of the unit downward.
4. Press the small blue latches located on either side of the bottom of the ETB and lift the unit out
of the printer.
5. Install the new ETB.
6. Close the front and top covers.
Apr 11, 2011 | HP LaserJet 4700 Printer
What do I do to fix repetitive image defect issues that appear to be ETB rollers?
Swap out the ETB.
You never said what the defect is.
All three of the defects for the ETB will require you to replace it.
Dec 22, 2010 | HP Color LaserJet 2600n Printer
HP 2600 is printing with a grey background. I have done several recalibrations and cleaned it but it does not fix the problem.
same as me, I got reduce this effect printing in normal paper as if i where printing transparency paper. The background is lighter now, but still appears.
The other thing I test, printing a blank page it was that with a glosy photo paper with the gloss side to the back i dont get any background. So i suspect it has to do with the tansfer belt ETB rollers.
Nov 02, 2010 | HP Color LaserJet 2600n Printer
How to exchange the ETB unit (belt) on a HP Colorlaserjet 2600n?
To replace the ETB Belt.. follow this step..but it would be easier if I can show u the diagram.. I will figure a way to upload. but let see if u understand here...
ETB removal and replacement
Use the following procedure to remove the ETB (RM1–1881–000CN).
1. Remove or slightly pull out Tray 2 (RM1–1916–000CN).
2. Remove three (3) screws, two (2) from the right cover assembly and one (1) from the left cover
assembly.
3. Open the front door.
4. Remove the right cover (RM1–1858–000CN), carefully twisting the front edges of the side covers
outward to remove.
NOTE : To make the removal of the right cover assembly easier, release the tab on the
inside of the cover.
5. Remove the left cover.
6. Squeeze the white link lever on the left side.
7. Remove the screw on the right white plastic catch, and then remove the plastic catch.
8. Close the ETB.
9. Remove the small black cable cover (RC1–5147–000CN) on the left side of the printer by
carefully snapping it out of place.
10. Remove one (1) grounding screw from the ETB harness.
11. Pull out the white wire holder by pushing it up.
12. Pull out the ETB connector.
13. Remove one (1) screw from each hinge cam on both sides.
14. Using needle-nose pliers, remove the hinge left cam (RC1–4249–000CN) and the right hinge
cam (RC1–5311–000CN).
15. Remove the ETB.
Use the following procedure to replace the ETB.
1. Align each foot of the ETB with the respective holes, securing the right side first, and then the left
side.
2. Complete replacement by following steps 1 through 14 above in reverse order.
NOTE : When replacing the right cover, align the tabs on the upper edge of the right cover
and lower edge of the face-down cover with their respective slots.
May 23, 2010 | HP Color LaserJet 2600n Printer
HP LJ 2600 "dirty" printing
If the toner cartridges are "refills" that might explain some of your print quality issues. Unfortunately, HP only has 2 replacement parts for that model, the fuser and the ETB (Transfer belt) both would require a technician to replace. Check the transfer belt of any tears or punctures. Careful not to touch it, oils from your skin can cause quality issues as well. If at all possible replace all the toners with ones that were working fine.
Jul 31, 2009 | HP Color LaserJet 2600n Printer
Insert C toner cartridge
Have you tried upadtaing the firmware?
Mar 19, 2008 | HP Color LaserJet 4650DTN Printer
ETB ASSEMBLY
Probably www.laserpros.com/pdf/HP 2600-2605 fuser-etb.pdf will help...
Oct 22, 2007 | HP Color LaserJet 2600n Printer
HP Color Inkjet cp1700ps Printer Logo
105 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
