Question about Danze D302521 Antioch Roman Tub Faucet with Soft Touch Personal Shower - Ch...
Moen Kingsley roman tub- no/slow hot water flow
Flowing fine for 2 years. Now only have a trickle flow of hot water. Cold water is flowing as normal.
  • Anonymous Mar 13, 2014
    hot water flowing slow
    New Friend:
  • 92 Answers
Sounds like you may have a little debri on hot side stem or kinked hose between valve and spout turn off water to house remove handle pull bonnet and remove stem turn water back on with stem removed see how water flow is be careful turning water on you could make a mess i am assuming the low pressure is in shower only
Posted on Apr 16, 2009
Water in tub is only hot for a few seconds and then turns lukewarm. We have hot water everywhere else.
Check this link: http://www.selfhelpandmore.com/plumbing/how-to-adjust-a-single-lever-shower-faucet.php
Nov 17, 2014 | Moen Kingsley Two Handle Roman Tub Faucet...
I replaced a moen 1222 valve stem becasue i had just a trickle of water. I go the new stem in ok, but still no water. I have the hot water heater diconnected on the water inlet, but the out let is still...
With posi-temp cartridges, if one supply of water, hot or cold, is interrupted, the cartridge automatically restricts the flow of the other water source. This is to prevent you from getting scalded if the pressure on the cold side drops because of a toilet being flushed or any other uses of cold water. The cartridge will only allow cold water to flow through if there is hot water to balance it out. If you restore hot water to the faucet, it will operate properly.
Aug 04, 2017 | Moen 2919 Chateau Two Handle Tub and...
L have a moen kingsley t125 with a moen 9000 m pact the cold water handle comes out with a trickle only when you turn it on the hot water is find unit is about one year old
You have a obstruction in cold side turn off both cold and hot water to faucet then disassemble cold side(take note of how you take apart it must go back correctly) slowly open cold water stop to see if you can dislodge obstruction(use a towel over cold water handle assembly to keep from water shooting everywhere).
May 30, 2011 | Moen Kingsley Two Handle Bathroom Sink...
I have a Moen tub and shower system similar to the Moen 2919 Chateau two handle above. When I turn on the faucets up to 1/2 way everthing works fine. If I try to increase the water capacity by turning up...
To talk about your problem forces me to assume a few things.....If you allow the water to flow without cartridges and handles, the water must be flowing straight through the cartridge channels and out into the tub. It is not flowing through your tub spout or shower head when you test the water this way. If I'm correct, then the problem is isolated to the water mix operation. That means coming out of your spout or shower head. So now I have to ask a question. When you operate as normal (cartridges and handles installed) does your problem show up only on your shower head or does it also show up when operating out of the tub spout? If the problem is isolated to the shower head, try a head replacement. It may be partially plugged. If it's head or spout there may be something in the mixing pipe that only shifts around as pressure increases. I hope that is not your problem. It would require pulling those pipes out for inspection and most likely replacement. Nimsgame
Feb 19, 2011 | Moen 2919 Chateau Two Handle Tub and...
Hot water trickles in swhower--works fine on other faucets--cold h2o flow fine
Clogged galvanized pipes. Replace with Pex or Copper lines. Or bad Moen cartridge- see department store for replacement or call Moen direct. You can get the # from gethuman.com
Nov 11, 2010 | Moen Posi-Temp Single HandleTub And Shower...
Cold water hose is not flowing normally. The flow is very slow almost to a trickle
Remove the hose connection from the machine and check if you have sufficient water pressure and flow. If that is ok, check the screen on the inlet valve for debri and clean that out.
Aug 27, 2010 | Hoover HTC243 Top Load Washer
Cold water works, hot does not
your problem can be fixed by running a loop in the plumbing. If you hired a professional in the first place it would already be done. basically the water pressure isn't enough, i bet your faucet is on the second or third floor, or even just THAT far from the water heater.
Sep 07, 2009 | Moen Chateau Loop-Handle Kitchen Faucet...
Moen shower/tub faucet
hi... yes that's a very common issue with moen "cartridges" -- it's very simple to fix..... grasp the handle and give it a gentle tug upwards when the water is on... if it retracts again, pull the handle out again and tug again but this time a bit harder. Not sure what causes this on new cartridges but it will fix your issue.
Apr 27, 2009 | Moen & One Handle Tub & Shower Faucet
Moen roman tub faucet on hot water side stops flowing and just trikles out
If this occurs after you were able to get hot water to flow from the hot side then I suspect that it is a piece of debriis that has found its way to block the port opening. Remove the acess panel to the valve shut the water supply off to the tub valve using the handles only first on the valve. With the access panel removed tak e a bucket or other similar container and remove the hot water tubing from the spout. Once that is accomplished stick the tube into the container and turn the hot lever on. This should blow out any debris that may exist. Reassemble the valvle. If this did not work remove both the cold and hot feed tubes from the spout and use an air compressor to blow the spout out. If neither of these worked you will probably need to call a serviceman to resolve as other options require cutting the hot supply to the handle and may require special tools that you may not have handy. Thanks for using Fix Ya.
Mar 03, 2009 | Moen Plumbing
Kenmore wash macine
its in your cold water line valve to the washer if it works good with hot water the valve are incoming line being blocked when you turn it on the pressure comes in fast then when pressure is gone water slows down so when its off the pressure builds back up it runs fast then slow
Feb 27, 2008 | Washing Machines
Danze D302521 Antioch Roman Tub Faucet with Soft Touch Personal Shower - Ch... Logo
869 people viewed this question
Top Danze Plumbing Experts
David Wiebe
Level 1 Expert
Donni Steen
john h
Are you a Danze Plumbing Expert? Answer questions, earn points and help others
