Question about Dell 922 All-In-One InkJet Printer
PRINT CARTRIDGE 922
How do you close the cartrigde casing as i have tired to do and it no closing down for me
    President:
  • Dell Master
  • 2,022 Answers
Just open the cover of printer the catridgecasing will come on center just oull don to remove the catridge. and for installation just push it back , or you refer the mannual for installation. bye
Posted on Sep 24, 2007
SOURCE:
I can't print anything off the computer since I put in a new cartrigde.
Now way related to cartridge &Printer driver, check USB cable,reload drivers once again.
Dec 22, 2011 | HP Officejet 5510 All-In-One Thermal...
My Canon printer does not print
It would have helped really had you given us some idea of what happens when you send a document to print; the fact there are many scenarios. However try the procedure below:-
“All lights blinking and printer not responding” is indicative of serious ink cartridge issue. Usually when this happens the printer fails to goes through the motions of the printing process, kind of stands still with indicator lights just blinking away. This could be as a result of either of these scenarios.
i.                     Ink cartridge has developed incompatibility or is incompatible
The Solution is to try an older/another cartridge (doesn’t matter if ink is finished. You must replace cartridge one at a time). If lights stop blinking it confirms that your cartridge has become incompatible or developed incompatibility. Also if your printer is the type that can work with only one cartridge, remove one after the other (closing back the lid/cover) to determine which in the set (black or color) has become incompatible. At the instance the incompatible one is removed and you close the lid, the blinking will stop (for printers that can print with one ink cartridge only). Just replace the incompatible one and start printing again. In most cases the issue is always with one cartridge. But if both are affected, you have to replace both. Because of this type of problem, always keep used cartridges somewhere safe; they come in handy for this type of troubleshooting.
ii.                   The Cartridge electronic panel  is dirty
The electronic panel on the cartridge that makes contact with the cartridge carrier inside the printer is dirty and needs cleaning.  This electronic panel is front part of the cartridge with copper “dots”.
The Solution is to try to clean this panel with a piece of folded tissue paper soaked in a bit of methylated spirit. Also try to clean the area in the cartridge carrier/holder that makes contact with the cartridge’s electronic panel (Usually this is more difficult). If you cannot reach it with your fingers, use a stick or something with tissue wrapped around it. Allow to dry well and return the cartridges, close the cover. The blinking should stop if the electronic panel is the issue. Once the blinking stops the printer will print.
Mar 27, 2010 | Dell 922 All-In-One InkJet Printer
The color cartridge carrier lid will not snap shut when loaded with a new cartridge
my ink cartridge lid wont close after replacing ink and i have clicked down the cartidge.
Jan 26, 2010 | Dell 922 All-In-One InkJet Printer
How to change cartrigde
Installing ink cartridges:
  1. Make sure that the machine is turned on, lift the Scanning Unit (Printer Cover) with both hands, then pull the Scanning Unit Support (A) down into place.
  2. Take out a new cartridge from its casing and gently remove the orange protective tape in the direction of the arrow.
    Note: - Do not attempt to reattach the protective tape once you have removed it.
    - Do not touch the gold electrical contacts or the print head nozzles after removing the protective tape.
  3. Insert the ink cartridge into the ink cartridge holder.- Black: the left slot- Color: the right slot*
    *One black cartridge and one color cartridge must be installed in the machine in order for the printer to operate. It does not matter if the capacities (Standard or High) do not match.
  4. Push up on the front of the cartridge until it locks into place. (A click sound will be heard when the cartridge is locked in place.)
  5. Confirm that the ink cartridges are installed properly.
    <1> The ink cartridge is not installed properly.
    <2> The ink cartridge is installed properly.
  6. Fold the scanning unit support and close the scanning unit (printer cover).
  7. Wait until the preparatory operation is complete; it takes about one to two minutes.
Removing Ink Cartridges:
  1. After confirming that the printer is powered on, open the scanning unit (printer cover). The ink cartridge holder moves to the replacement position.
  2. Press down on the semi-circular tab to release the cartridge and then remove it.
    Note: Handle the ink cartridges carefully to avoid staining clothes and surrounding work area.
  3. Remove and replace each cartridge individually. Or, remove the second cartridge after the first has been removed.
  4. Fold the scanning unit support and close the scanning unit (printer cover).
Oct 24, 2009 | Canon MX300 Office All-In-One Printer
Cartrigde leaked ink to bottom of printer
Print cartridge
When the print cartridge contacts are dirty and the printer cannot detect/communicate with print cartridge.
Clean the contact points on the cartridges with a dry, lint-free cloth.
1. Open the top cover of the printer.
2. Remove the print cartridges.
3. Clean the copper-colored contact points on the cartridges with a damp, lint-free cloth.
Use a dry, lint-free cloth to remove moisture from the contacts.
5. Insert the cartridges back into the printer.
6. Close the top cover.
7. Try printing again.
If you still cant communicate try with new cartridge .
Hope this help. Please Rate My Response! Thanks!
Aug 18, 2009 | Office Equipment & Supplies
Cartridge stall; Nothing printed
PREM
May 23, 2009 | Dell 922 All-In-One InkJet Printer
My dell aio printer 922 will not print
my dell aio printer well not print systen 32 spool driver is close how do i get it to come on
Feb 06, 2009 | Dell 922 All-In-One InkJet Printer
Dell Photo All-in-One Printer 944 cartridge carrier malfunction
Nobody fixes ink-jet printers anymore.
If the old cart will go back in OK, it could be a bad cartridge.
Dec 28, 2008 | Dell 922 All-In-One InkJet Printer
Hi, Even though I have replaced the black cartridge, I continue to get the message that the ink is empty. I would love some guidance!!!!
Hi snascent,
It's possible that you may also need to replace the color ink cartridge. If this is not the case, then the message you're receiving could be due to any of a number of factors:
1) Make sure that you've removed the sticker and transparent tape from the new cartridge before installing it.
2) Make sure that the new cartridge is snapped in securely, and that the lid over it is snapped close.
3) Make sure that the black cartridge is on the left and the color one is on the right (silly as this may seem, it can actually cause problems).
4) If all of these are done and you still get the same message, you might try powering off and back on.
5) If it still doesn't recognize the ink, you might have a clogged print nozzle. To clean the print nozzles, click Start Menu > Programs > Dell Printers > Dell Photo AIO Printer 922 > Dell Printer Solution Center. On the "Maintenance" tab, click "Clean to fix horizontal streaks" - then click "Print."
I hope this helps you - please let me know if you still have problems, or if I can be of any other assistance.
Kind regards,
H2H
Dec 14, 2008 | Dell 922 All-In-One InkJet Printer
Ink cartridge
Try unplugging the power cord, and replugging it after one minute has passed. (Turning the switch on and off does not work). If nothing changes, then rerun the CD used to install the printer. Both of these techniques reprogram the electronics, to a certain extent.
You might also visit the manufacturer's website, to see what solutions are being offered for printer problems. They usually have a number to call, in case you need to talk to a technician.
Jul 08, 2008 | Dell 922 All-In-One InkJet Printer
Dell 922 All-In-One InkJet Printer Logo
35 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
