Question about Troy-Bilt® Briggs and Stratton Chipper
Chipper only runs on choke
I have craftman chipper and it was working fine and now it only works when on full choke
I was using my o17 saw today it was runing Just fine I shut it off when I went to start it again it fired on choke seting after that I could not get it to do anything what is wrong with it
All 2-strokes love to run rich when cold thus full choke till it kicks, half choke to start and leave on for 5 seconds high rev's to warm & lubricate, then no choke to run. Restart when hot is 1 pull full choke (you are now flooded) & then no choke til it starts. Try it. Works every time on all of my 2-stroke engines.
Apr 22, 2015 | Garden
Engine starts and runs fine until i run about 5 pieces of branch
what color is the fire at the sparkplug? if it is blue it is good, if it's red that means that your spark is weak probably your coil is weak replace your coil
Jun 05, 2010 | Yard Machines 24A452G700 205cc Briggs ...
Engine pulse at choke off, smooth at half choke. Cleaned carb...didn't help.
Get a can of carb. cleaner and squirt some into the air intake as it is running. Let it run on this carb. cleaner for a couple of minutes and you will clear your clog. J.
Apr 05, 2010 | Troy-Bilt® Briggs and Stratton Chipper
Craftman Chainsaw do not run
Extreme Flooding by Dolfoff
Please follow this link, http://www.fixya.com/support/t3226410-no_spark_new_plug_but_continues_flood cursor down to “Best Solution”, while there click the “Was this helpful? [Yes]” button HTH
Lou
Oct 20, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I have Chipper/Shredder model 47321, 10 HP. I have
try changing spark plug, if unit sits outside rain can rust the coil but I would try a new spark plug first and make sure it;s gaped correctly
Oct 03, 2009 | Troy-Bilt Chipper Shredder
5hp chipper will start and run only with the choke on and has no power, please, help.
sounds like the carb is gummed up. You probably need to do a complete carb cleaning.
Aug 07, 2009 | Yard Machines 24a 452g729 5.5 Hp Chipper...
MTD chipper shreader
Sounds like the carb is gummed up. Do a complete carb cleaning and see if it helps.
Jul 10, 2009 | Yard Machines 24a 452g729 5.5 Hp Chipper...
10 hp Troy Built chipper pull start frozen
If a branch was already being chipped when it ran out of gas...you must clear the hopper of any chunks of wood in it. Pull the plug wire and use a metal pry bar to dislodge any pieces of wood. when the flywheel runs free, put the plug wire back on and the choke on. Try it now!!!
Jun 14, 2009 | Troy-Bilt® Briggs and Stratton Chipper
Troy-Bilt® Briggs and Stratton Chipper  Logo
249 people viewed this question
Top Troy Heavy Machinery Experts
Roland W VanLue
Roland W VanLue
Matt Olenzek
Matt Olenzek
Paul Sikkema
Paul Sikkema
Are you a Troy Heavy Machinery Expert? Answer questions, earn points and help others
