Question about NetGear WGR614 Wireless Router
Open nat settings
I want to set the NAT settings on my netgear wgr614v6 router to open in order to play x box 360 live
  • 854 Answers
XBOX Won‘t Connect
The NETGEAR router is a firewall. It blocks ports to prevent attacks from programs or users from the Internet to the computers or devices behind your router. Each application on the Internet uses ports. For example, when you browse the Internet, it uses port 80. An FTP server uses port 21. This is the same as your Xbox that uses ports to connect to the Internet. Before we proceed to any troubleshooting procedures, check if the Xbox is working directly to the modem. This will verify if there is something wrong with the Xbox. If the game console won't connect to the Internet when directly connected on the modem, it means that it is not your router blocking the connection. Here are the steps on how to open the ports on the router:
A. Determine the IP Address and MAC Address of the Xbox.
Note: You may find the IP address and MAC address of your Xbox on your Dashboard's Network Settings. Please refer to your Xbox manual for more information on this.
B. Reserve the IP address.
1. Please open any web browser like Internet Explorer or Netscape Navigator.
2. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
3. For security reasons, the router has its own user name and password. When prompted, enter admin for the User name and password for the Password, both in lower case letters.
Note: If it does not take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you cannot remember the password, you need to reset the router and run the Setup CD to reconfigure it.
4. When the setup page opens, click on LAN IP Setup under Advanced tab.
5. Click on Add under Address Reservation.
6. Under Address Reservation window, please select the radio button of the computer you wish to add from the Address Reservation Table.
7. If the computer you want is not on the list, please click on the Refresh button to update the table.
8. If the computer is still not on the Address Reservation Table, please type in the IP Address, MAC Address, and Device Name of the computer you wish to add.
9. Click the Add button when done.
C. Forward the ports.
1. Click on the option with the name Port Forwarding/Port Triggering under the Advanced. For older firmware version, click on Port Triggering tab or just click Port Forwarding on Please select the service type.
2. Click Add and another window will pop up.
3. Type Xbox for Name. Set the radio button to Enable.
4. On Outgoing Port Range, set the Start Port and End Port to 3074.
5. On Incoming Port Range, you also have to indicate 3074 for Start Port and End Port. Save the settings by clicking on Apply.
6. Please repeat steps b to e and indicate 88 for Start Port and End Port. Then change the Name to Xbox2.
Note: If it still does not work, you may try these other options:
D. Lower down the MTU.
1. Access the Setup page of the router (refer to Step 2 above).
2. Click on the WAN Setup under Advanced tab.
3. Lower down the MTU size to 1492, 1400, 1358 or 1300.
4. Click on the Apply button.
E. Enable UPnP.
1. Go to UPnP tab of the router.
2. Enable UPnP and then save the settings by clicking on Apply. Some websites and devices require UPnP or Universal Plug and Play. Just make sure that it is enabled on the router.
F. Upgrade the firmware.
Note: Follow the steps below if the above troubleshooting still do not allow Xbox to connect using the router.
1. Please verify the router version and model either underneath or at its side panel.
2. Go to http://kbserver.NETGEAR.com/downloads_support.asp and please select the model of the router.
3. Click the appropriate version of the router.
4. Select the link of the latest firmware. Click the button Right-click and Save to Download. Save the file to the Desktop.
Note: Please perform firmware upgrade with Wired or Ethernet connection only.
5. Before upgrading, please write down all current settings since you need to enter them manually.
6. Using the computer hardwired on the router, please launch Internet Explorer and access the Setup page of the router (refer to Step 2).
7. Click on Maintenance and then Router Upgrade.
8. Click on Browse and locate the upgraded file in your Desktop. Then click on Upload.
9. Please wait for the router to reboot. After a successful firmware upgrade, you need to reset the router.
E. Reset the router.
1. Please push the reset button at the back of the router and release after 30 seconds.
2. Unplug the power adapter for 10 seconds and then plug it back in.
(this note should go before the step to Reset the router) Note: Resetting the router will erase all the settings so it needs to be reconfigured afterwards. The router can be reconfigured using the setup CD or by manual configuration.
Posted on Apr 13, 2009
I do not know how to change my NAT setting to open on Xbox Live
First of all I would just like to cover the basics of strict and moderate NAT settings. For those interested, NAT stands for Network Address Translation and is used to prevent problems with information being sent over a shared network.
With the XBOX 360, Microsoft have defined three categories of NAT. These are:
1. Strict
2. Moderate
3. Open
You can see the NAT level for your XBOX Live connection by going into your
1. System blade
2. Network Settings
3. Test Xbox Live Connection
For you question on how to open your NAT setting follow the steps below:
1. Type the IP address of your router in a web browser.
2. It will prompt you for a user name and password once connected
3. After logging in you will have a control panel of setting up different settings in your router.
4. The IP address, and default user name/password are different on every route
Note: 192.168.1.1 is a pretty common address for most routers.
5. Check the manual that came with your router for that info.
I also provided a few links below of password lists of different routers.
Click Here
Click Here
I hope this information will be helpful. Thank you for using FixYa!
Your feedback is greatly appreciated.
Feb 24, 2011 | NetGear WNR2000 Wireless Router
Dynex-e402 change nat settings to access x-box live
Dynex DX-E402 router, changing NAT settings(UPnP) to access x-box live. go to router settings web page for router, http://192.168.1.1/, enter user name and password to access settings page. user id is usually admin this also for password. under advanced settings click on forwarding. In listed sub-catagories click on UPnp. click enable. this should solve any NAT issues with X-box 360 signing onto x-box live. dynex dx-e402 was very easy to setup.
Mar 24, 2009 | Dynex DX-E401 Router
XBOX Live & Netgear Router Help!!!!!!!!!!!
You need a excellent signal to your Xbox. Xbox requires a constant connection. My son as an Xbox and we had to run a wire connection to the Xbox no problems after that. Or you need to move your wireless router to the same room as your xbox to get a stronger connection.
Please rate my response.
Jan 07, 2009 | Belkin (F5D5231-4) Router
Router will not allow me to play onling games through xbox 360
If the problem has something to do with NAT firewall in your router, then you may need to open certain application ports for your XBOX in the router. You may check this link from Microsoft http://support.microsoft.com/kb/908874 that talks about NAT firewall and XBOX live.
Hope this helps!
Nov 09, 2008 | Computers & Internet
NAT settings are set to Strict
Go to this link this will help you with your problem.
http://www.portforward.com/english/routers/port_forwarding/routerindex.htm
Once your on this page select the model of your router (look into Netgear).
On the next page select XBOX live. After this, this will give you instruction how to open ports for your xbox live.
Aug 04, 2008 | NetGear WGT624 Wireless Router
Strict nat settings
go to security tab on the router interface and deselect NAT button.
Jul 03, 2008 | NetGear WGT624 Wireless Router
NAT set to strict, can not play on xbox live. How do I set it to open?
Reinstalled software that came withrouter and went thourgh the reconnection steps.
Now the NAT is set to open.
Mar 27, 2008 | NetGear RangeMax WPN824 Router
Change NAT to open
Ok kids... all you hve to do is log in to your belkin 54g at http://192.168.2.1
Find out what ip address your xbox is using and then Click on the DMZportion of your settings on the left hand side of the page.
Enter the xbox's ip address and click the enable box.
Click apply.
Your NAT will now be OPEN!
Cheers!
Mar 24, 2008 | Linksys WRT54GL Wireless-G 54Mbps...
How do i set my Netgear Routers NAT type to open for playing xbox 360 games?
Ok in order to help you resolve this issue I need more information. Is this a newly setup router? Did you setup any type of security? WEP OR WPA these are encryption tools that allow only you to get onto your network.
Nov 20, 2007 | NetGear RangeMax WPN824 Router
Nat settings on netgear wgr614 wireless router
Hello --
Most NAT settings can be found, on modern routers, under the WAN setup of the router interface. Normally, it is set to Secured with the option of setting it to Open. Click Open and apply changes, giving the router a moment to reset the software and re-broadcast transmissions.
This comes secured for public consumption because the normal consumer would not create a WAN (wide access network) at home. However, gaming consoles (PS3 and Xbox 360) require this because of the P2P hosting that most online multiple-player games require. Setting it to Open full-duplexes the transmissions without restriction (since gaming console connections are "supposed" to be secure anyway).
After you've set the NAT settings, restart the gaming console, test the 'net connection and confirm it is reading your now Open NAT settings.
Oct 15, 2007 | NetGear WGR614 Wireless Router
NetGear WGR614 Wireless Router Logo
375 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
