Question about Dryers
Drum having a difficult time spinning
I have a Maytag dryer model # MDE7057AYW and the drum seems like it is binding and very difficult to turn. It will turn with no clothes in it with some difficulty but not at all with any type of load.
  • 686 Answers
YOU'LL HAVE TO OPEN IT AND CHECK THE FELT SEAL IN BACK OF DRUM. THE DRUM ROLLERS. AND THE FRONT SHROUD SEAL.
Posted on Apr 13, 2009
Drum does not spin. Belt appears to be ok
You have a bad tensioner or a bad motor. The tensioner for the belt can drag the motor. However, what you are describing sounds like the motor is shot. But make sure you are getting correct voltage to dryer and nothing is binding the motor.
Mar 03, 2015 | Maytag Dryers
My Maytag Performa Dryer model PYG3360AWW wont turn on it just buzzes when I push the start button. what do I do to fix it?
See if you can turn the drum by hand, there should be some resistance. If its locked you will need to disassembly the dryer and see what is binding. If everything(motor,rollers,pullys)spins freely they you most likely have a faulty motor winding and will need to replace it.
Dec 21, 2014 | Maytag Dryers
Maytag ensignia
follow this steps and fix it. God bless you
Drive Motor
The dryer drive motor turns the drum and the blower wheel to exhaust the air. If the dryer stops the motor might be defective. If the dryer stops and the dryer motor makes a humming noise there might be something caught in the blower wheel, or the drum might be binding. Try removing the belt from the motor and checking the blower wheel for obstructions. Also try rotating the drum by hand with the belt off, it should rotate freely. If the drum doesn't turn freely, determine what is causing it to bind. The dryer motor can't be tested easily. If the drum turns freely and the blower wheel is clear, and yet the dryer still keeps stopping mid-cycle the motor may be defective. it will need to be replaced. It is not serviceable.
Enter your model number to see parts for your dryer.
Help me find my model number
Drum Roller Axle
This dryer has drum support rollers. There will always be two supporting the rear of the drum, and on some models there may be two supporting the front of the drum. The rollers must spin freely to work properly. If the roller axles are worn out the rollers may not spin freely which can overload the motor and the dryer stops. If the dryer stops mid-cycle, remove the belt and spin the drum, it should spin freely. If not, check the rollers and roller shafts.
Drum Roller
This dryer has drum support rollers. There will always be two supporting the rear of the drum, and on some models there may be two supporting the front of the drum. The rollers must spin freely to work properly. If they are worn out or start binding the motor can get overloaded and the dryer stops. If the dryer stops mid-cycle, check to be sure the drum turns freely with the belt removed. If not, check the rollers. Do not lubricate the rollers or roller shaft, lubrication will attract lint and cause the roller bearings to wear out faster. If the rollers don't turn freely, replace them. The roller shaft can often be reused, unless it has worn down. Clean the shaft thoroughly before installing the new rollers.
Drum Support Roller & Axle
This dryer has drum support rollers.There will always be two supporting the rear of the drum and on some models there may be two supporting the front of the drum. The rollers must spin freely to work properly. If the roller axles are worn out the rollers may not spin freely. If not, check the rollers and rollers shafts. If they are worn or do not turn freely they will need to be replaced.
Drum Slide, Glide, or Pad
The front of the dryer drum is supported by small pieces of plastic-like material. As the drum rotates, it slides on these plastic pieces. If the dryer stops mid-cycle, it may be that one or more of these plastic slides or glides has worn out. When they wear out the drum can start binding and put strain on the motor. The motor then shuts down and the dryer stops. Check the glides for wear and replace as needed.
Drum Bearing
The drum bearing supports the rear of the dryer drum. Over time this bearing will wear out and may cause several different problems. If the dryer stops during the cycle it may be that this drum bearing has worn out and is putting too much strain on the motor. If the belt is removed and the drum spins freely, the drum bearing is probably not worn out. If the drum bearing is worn out, there may be some grinding or squealing, and the drum will be hard to turn.
Drum Support Bearing
Dryness Control Board
The dryness control board shuts off the dryer when the clothes have reached the level of dryness selected by the user. If the dryer stops too early, the dryness control board might be defective. This is not very common and other possibilities should be checked first.
Jul 21, 2013 | Maytag Dryers
My dryer is making a squealing sound
Your drum bearings are wearing out or the belt driving it is spinning. The drum could be binding up and causing it to slow down and brake itself. The belt will continue run at regular speed and cause a loud noise as at literally slides across the drum. Kind of like spinning your tires on the pavement.
Feb 22, 2013 | Maytag SDE4606A Electric Dryer
Westinghouse Electric Dryer, Drum doesn't turn on start up, if your spin drum and close door it will start,
Either something is binding the blower wheel up or the motor is bad. The best thing is to take the front of the machine off to access the blower wheel to verify ifanything is indeed binding it.IF not read the next section.
If you can turn the drum and then the dryer starts you have a bad motor. The way the dryer works is when you initially push the start button, electricity is sent to the start winding, or stator, of the motor. This will in turn start the motor turning. From there the stator will drop out of the electrical process and at the same time the run winding, or rotor, will take over and the motor will continie to run. Your stator is damaged, has a burn spot, etc so by you turning the drum, the belt around the drum is moved which is attached to the motor pulley. You basically take the place of the stator. Long story short, you have a bad motor.
Jun 22, 2012 | Westinghouse Laundry Dryer Motor...
The dryer does'nt heat Model # MDE7057AYW
You most likely have either a broken heating element or a popped safety switch.
Both can be found on either Applianceparts.com or Ebay after you go the Maytag website and spec out your parts.
Feb 09, 2010 | Maytag Dryers
Maytag dryer wont spin It makes heat,but the dryer wont spin
Sounds like the drum belt is broken or off the pulley of the motor
Sep 25, 2009 | Maytag Dryers
Drum Will not turn
you probably have a broken drum drive belt. They are not a difficult do-it-yourself job.
Your local appliance parts outlet should have the belt.
Jun 13, 2009 | Maytag Dryers
Dryer Drum Won't Spin
Reach inside and grab ahold of the baffle. Try to spin the drum, it should have resistance. If it spins freely you have a broken belt. Hope that helps. Dave ww.washermd.com
Dec 16, 2008 | Maytag Dryers
Dryers Logo
129 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
