Question about Cell Phones
Won't turn on
Audiovox cdm8910 won't turn on, screen flashes about every 5 seconds. Battery pack is swollen.
  • ringle Apr 13, 2009
    Okay! Battery's out and Verison stock is looking up if a normal battery doesn't work. Thanks!
  • 31 Answers
If you battery pack is swollen, then the worst thing to do is keep it in there and let it turn off and back on -- this could cause permanent damage to the device and could harm you as well.
Try and find a new battery on Ebay, CellPhoneShop.net, etc. and see if the problem is the battery or not. If it is, then that is the simple solution.
If the new battery doesn't fix it, then the situation is a little more sticky. Since the Audiovox 8910 is a fairly old phone, it is unlikely that you have any warranty left on the phone (unless you have insurance or have purchased it through Virgin Mobile, which in that case, go ahead and file the insurance claim or call VM and ask for a replacement or buy a refurbished one).
Most likely you will come out cheaper just buying a new phone altogether or finding a nice used one on Ebay.
Posted on Apr 13, 2009
Hp pavilion ze1210 intermittently boots up or will not turn on at all.
ok it's a laptop., old.
let me guess 2003 made, square 4:5 screen
XP removed, (smart idea) Linux installed.
I guess the screen is 100% dead, not one pixel ever glows, right?
no text, ,no BIOS screens on demand, (esc key pressed, power on)
1: step 1 is always remove the main big battery. run now?
2: try external VGA screen yet, to see if the old internal screen is dead? see that VGA jack on the rear, and the hot function key that turns it on, bingo.?
(use a flash light to see if screen internal has data but the
CCFL back lamp is dead.?)
4: if bios is dead and both screens fail,what is next.?
19vdc from the power pack must reach the guts (MOBO)
if not all HP lap tops die. use a voltmeter or get a spare power pack
many power packs this old are now bad. 14 years old,
the can be good, bad, or weak. weak is bad.
5: sparks is a bad thing, in all cases, when heard it needs service.
BSOD:
http://pcdied.com/#black-screens
May 04, 2017 | HP Pavilion ze1210 Notebook
My tv won't turn on, it will if i hold in the power button and will only stay on a few seconds, then flashes green
Bad capacitors on power supply board they will be vented or swollen on Top. 1000uf 2200uf 10v 3300uf 10v
May 31, 2011 | Sharp AQUOS LC-32D44U 32 in. LCD TV
When I try to charge my Audiovox 8610, the phone beeps & flashes
Either the phone needs a full reset / maybe battery issue / maybe mother board has partly destroyed itself! Lots of luck
Mar 04, 2018 | Audiovox 8610 Cellular Phone
We need information on how to repair the battery pack for the audiovox vbp800 portable dvd player with screen
Batteries are not repaired (it is dangerous to open a battery yourself).
I suggest checking a battery refill company online. These companies are equipped to replace the chemicals inside your existing battery or might sell you a refilled battery, if yours is damaged. This is cheaper and more environmentally friendly than buying a new battery.
Oct 06, 2009 | Audiovox VBP800 Portable DVD Player with...
My Audiovox FPE3205 has a black screen with a flashing picture that flashes just a split second.
there is a problem on your back light inverter transformer.the fusible that supply the backlight is open.i have encountered already for that problem.
Aug 01, 2009 | Audiovox FPE2306 23 in. LCD Television
Cell phone wont turn off
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Jul 08, 2017 | Audiovox CDM8940VW
Screen got really hot and now it won't play DVD's
I was going to see if you DVD player has a reset button on it but it isn't popping up on Audiovox website.
If you open up the player see if there is a reset button on it. Hold it down for about 5 seconds and see if that works.
Unplug power from the unit and remove the battery as well. Put them back in.
Try a different DVD in case its warped or damaged.
If those don't resolve the issue you should take it in and have someone look at it.
Jun 17, 2008 | Audiovox DT102A
AUDIOVOX CDA 100 AM/FM/CD setting clock
SETTING THE CLOCK - AUDIOVOX CDA-100
  1. Turn the vehicle ignition and radio "on".
  2. Press and hold the Time/Frequency Selector button approximately 2 seconds until the time display begins flashing on the display panel.
  3. Within 5 seconds after the time display begins flashing press the Manual Down Turning button (<<) to adjust the hours and the Manual Up Turning button (>>) to adjust the minutes to the correct time.
  4. Five seconds after the last hour or minute adjustment is made, the time will be set in the unit and normal operation can resume.
Contact Audiovox.com or 1-800-688-3135 and they will email (PDA) or fax a copy of the manual.
Oct 17, 2007 | Audiovox AM/FM/DVD/CD/MP3/WMA Receiver...
Cell Phones Logo
108 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
