Question about Whirlpool GEW9250 Electric Dryer
Whirlpool Dryer won't spin
The model number is lg5351xtw0
it turns on but no spinning, and if its the belt i have no idea how to fix that i have no manual.
  • 686 Answers
REMOVE THE LINT FILTER AND THE 2 SCREWS UNDER IT THEN PRY THE TOP UP AT THE EDGES WITH SCREWDRIVER AND OPEN TOP. NEXT REMOVE SCREWS ON THE INSIDE OF THE FRONT PANEL ON BOTH SIDES THEN UNDO DOOR SWITCH WIRES AND PULL FRONT PANEL UP AND OUT. DRUM MAY DROP A BIT. FROM THERE PULL DRUM OUT AND PUT NEW BELT ON AND REASSMBLE. IT WILL BE EASIER TO REMOVE THE REAR PANEL AS WELL TO RE-INSTALL THE BELT TO THE MOTOR AND TENSIONER.
Posted on Apr 13, 2009
Whirlpool dryer won't spin
Most dyers after you pull the top up, the front should just lift a little and it should come loose, sounds like you may have the belt intact, but the motor is not conected to the belt.
Jan 12, 2013 | Whirlpool Dryers
Dryer won't spin
Someone is going to have to get inside to see if the belt (it should have one around the drum) is broken or the motor that drives it is seized, etc.
Need to see if drum turns and if too freely my money would be the belt.
Dec 05, 2012 | Whirlpool Dryers
Kenmore Heavy Duty Plus Dryer 86273100 drum won't spin
How could the belt be in working order if the drum doesn't spin? Check to see if the belt has come off the motor. If the motor runs but your dryer doesn't spin, the belt is off. If the motor runs with the belt on but it still won't spin then you'll have a lot of black smoke because your drum is jammed. In other words, there are a number of things that could be wrong, but not very many.
Dec 22, 2011 | Washing Machines
Whirlpool imperial series dryer heats not spinning
This problem is almost always a broken belt. Yes you can do it yourself.
Go to repairclinic. com and put in your model number for the exploded view of your dryer. Locate the belt part number and belt orientation.
Jan 03, 2010 | Whirlpool Dryers
Whirlpool dryer has power, but drum won't spin
More likely does have a belt. Get me the model number and I will see if I can help you on this problem, Thanks, Sea Breeze
Mar 21, 2009 | Whirlpool GEW9250 Electric Dryer
Whirlpool Ultimate Care II - Gas Dryer - Drum Won't Spin
If you are handy with tools, try to remove the back panel and feel the belt that should surround the drum. If access is that limited, try to turn the dryer on its side and you can get to the motor from the bottom. But like the guy said before, call a pro if you can't do any of this.
Dec 21, 2008 | Whirlpool LER4634J Electric Dryer
Whirlpool Dryer wont spin
If it heats but doesnt spin, most likely the belt. May not be broke though. May have fallen off. Let me know if you need more help.
Dec 16, 2008 | Whirlpool LEQ9858P Electric Dryer
Dryer does not spin
Usually if a dryer won't spin, I suggest checking the belt to make sure it isn't broke or even the motor burned out. If you post a model number for your dryer, I may be able to assist you further.
May 28, 2008 | Dryers
2003 whirlpool dryer problems
full size free standing whirlpool dryer???? part number 341241, on a scale 1-10 it might be a 3 for a first timer, the package i belive even comes with direction on installing
May 12, 2008 | Dryers
Whirlpool GEW9250 Electric Dryer Logo
193 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
