Question about Electrolux Over-the-Range Microwave
Does not heat
Electrolux model FMV158FM
How do you remove the control panel to trouble shoot.
  • 686 Answers
I WOULD SAY REMOVE THE CABINET FIRST AND GO FROM THERE. IF YOU HAVE NO POWER THAN CHECK THE FUSE.
Posted on Apr 13, 2009
We have code F84 coming up on our Electrolux microwave, wall oven. Seems to be affecting the microwave. Any ideas what might be going on?
The F84 code is a communication error between the user interface panel of the microwave and the main control board. This could be the result of a problem with the touch panel's interface board, the main control board or the wiring between them. (The wiring harness can come loose or have a bit of corrosion at the connectors.) The usual recommendation is to check the wiring at the interface board then replace the interface board first. If that doesn't solve the problem, you have to replace the control panel.
If you add a comment with the model number of the unit, I may be able to help you find the parts your unit needs.
I hope this helps.
Apr 09, 2017 | Electrolux Microwave Ovens
Hi, we have an electrolux builtin microwave.when on standby it occasionally makes a crackling noise not unlike a laptop or storage device when it looks for data. Microwave runs fine otherwise
You really need to be sure it's not running by itself - even intermittently - because that can cause arcing damage, or even a fire.
If you're not sure, leave the door open or the oven unplugged until you're sure it's not or it's fixed.
You can keep a cup of water in it and check it hourly over the course of a day to see if it coming on and actually heating.
It really shouldn't make any noise when idle except a gentle 60Hz hum.
For more free DIY and other help & advice, feel free to contact me via my site.
Please include FULL model number*, FCC ID number*, + detailed symptom information.
* on the tag in cooking cavity or around door frame or control frame or on back
William E. Miller, AS-EET
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Feb 02, 2017 | Electrolux Microwave Ovens
EW30MO55HS Electrolux 30"microwave doesn't turn or heat
Good Morning Jody, thank you for your post!
If your Electrolux microwave (EW30M055HS) has power but does not heat, often the possibilities include one of four culprits:
·Power Supply
    ·Plugged into GFI Outlet
    ·Faulty Control Panel
    ·Faulty Magnetron
I always recommend resetting your microwave first. You can do so by unplugging your appliance or flipping the circuit breaker for about 30 seconds and then turn your microwave back on. If your microwave stills does not heat or turn, I would recommend reaching out to a professional or alternatively, visit the manufacturer website for a comprehensive listing of appliance techs in your area.
Feb 19, 2014 | Electrolux EW30MO55HS 30" Built-in Drop...
I have a frigidaire Electrolux gallery series glmv168cqi microwave. The timer counts down, but the oven doesn't turn on. Sometimes when you open the door the fan turns on.
That would be a failing bottom door switch, or its mount.
My help file on door switches is here:
http://031d26d.namesecurehost.com/mwd/doorsw.txt
There's a video here showing how to remove a typical over the range control panel assembly in under 5 minutes.
Once the control panel has been removed, you can access the door switches for testing and possible replacement.
There should be a technical manual hidden behind the controller or grille, too.
If you need further part ordering help, contact Electrolux:
USA
800•944•9044
Electrolux Home Products
North America
P.O. Box 212378
Augusta, GA 30917
Canada
866•213•9397 (English)
866•294•9911 (French)
North America
6150 McLaughlin Road
Mississauga, Ontario, Canada
L5R 4C2
Apr 22, 2013 | Microwave Ovens
My GE PVM2070 microwave is stuck in DEMO mode. Nothing heats up. Unplugging it, even for an hour, did not resolve the problem.
This would be a controller issue, and sadly, on the 2070-series ovens, GE does not make separate parts available.
So you would have to replace the "control panel subassembly".
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you have any trouble getting the grille off once the screws are removed, slide the hood vent grille to the left about 1/4", then then pull it forward.
On some models there are L-shaped clips that fit into a slot to hold bottom of the vent.
Disconnect the keypad strip as shown in the photo below, remove your smart board, then insert it into the new subassembly.
Dec 31, 2010 | GE JVM2070 Microwave Oven
Control panel and rotation work. Bad Smell like
We are sorry to hear of the problem with your Whirlpool appliance. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at Whirlpool_Reviews@Whirlpool.com with your name, phone number, address and the model and serial number.
Apr 06, 2017 | Whirlpool GT1195SH Microwave Oven
Goldstar MV1501W not heating or turntable, light/display does wrk
micro switch is bad .remove top vent cover 4 screws,after removing plastic vent panel you will see 1 screw above display time window,remove this screw and lift up the complete button time control panel slightly and pull towards you to remove.there are 2 connections on this panel 1 is a 12 pin connector and a 2 pin power connection remove both put control panel aside.now there are 3 micro switches where the door pins close into the oven lock,remove 2 screws that hold the micro switch housing,on the bottom of housing you will see a small clip gently pull to the right and push back to remove .there are 2 switches on bottom of it and 1 on top. the 1 on top is normally open and closes when door is shut but like mine it stayed open and resulted in (light s display but no turntable)soon as i replaced upper microswitch it runs perfect.i hope this helps .MODEL MV1501W GOLDSTAR
Dec 10, 2008 | Goldstar MV-1155 Microwave Oven
Frigidaire FMV158FM over the range microwave 1000 watts
everything works on microwave but does not heat
Sep 18, 2008 | Microwave Ovens
Electrolux Over-the-Range Microwave Logo
290 people viewed this question
Top Electrolux Microwave Ovens Experts
William Miller
William Miller
Paul Bade
Are you an Electrolux Microwave Oven Expert? Answer questions, earn points and help others
