Question about Xerox Phaser 7750DN Laser Printer
"Replace Fuser" error won't go away after replacing the fuser
I keep getting the "Replace Fuser" error message even though I have already replaced the fuser. Twice.
  • 186 Answers
SOURCE: Xerox Phaser 6100- Error message - "Fuser Error Low Temprature"
time to replace the fuser assembly.
Posted on Jun 21, 2007
Cops
  • 64 Answers
SOURCE: Fuser Error 50.1 Fuser is hot. What is a fuser?
50.1
A low fuser temperature error has occurred, possibly due to an inadequate external or internal power supply.
this basicaly means that either the dc controller board is on its way out (expensive) or that there is a drain on the power line.
if you have it plugged into an extension lead try plugging it directly into the wall socket. if this fails also try using a different power lead (very easy to get hold of and are normaly called kettle leads)
Hope this helps
Cops
Pete@wedotoners.com
Posted on Oct 10, 2007
  • 208 Answers
SOURCE: Xerox Phaser 6100 Fuser Error
Try this,
Reset Fuser Life
  1. Using the control panel buttons scroll to Maintenance, press OK.
  2. Scroll to Check Others, press OK.
  3. Scroll to Fuser, press Reset
Posted on Dec 03, 2007
Soulvisitor
  • 1113 Answers
SOURCE: Fuser temp error
To test fuser out of circuit make sure lamp and thermal fuse are not open circuit, and thermister is neither open or shorted
Fuser repair procedure from tec manual.
Fuser Failure (U4-1, U4-2, & U4-3)
Switch off printer main power. Remove the Fuser Full Cover so you can observe the Heat Rods. Switch on printer main power and observe the ends of the Fuser Assembly. The Heat Rods glow.?
Y N
Go to step 5.
2 Replace the Printer Engine Controller PWB (REP 4.10.6). The error message reappears.
Y N
Problem solved.
3 Replace the Fuser Assembly The error message reappears.
Y N
Problem solved.
4 Check for a broken wire or a loose connection
between components
5 Measure the AC voltage between J23-2 and J23-6 on the AC Driver PWB. There is 110VAC (or 220VAC if the printer is the 220VAC model) between J23-2 and J23-6.
Y N
Go to step 7.
6 Replace the Fuser Assembly (REP 4.7.1). If the problem persists, replace the Printer Engine
7 The Fuser cycles up and down.
Y N
8 Measure the voltage between P401-1 and P 401-4 when the Fuser Fan cycles up and down. There is 24VDC between P401-1 and P401-4 when the fan is rotating and 0VDC when the fan is off.?
Y N
9 Replace the AC Driver PWB
Please rate solution to your question "How can I check that new Fuser unit is ok?"
Posted on Jan 10, 2008
SOURCE: Replace Fuser Reset
Enter Maintenace menu by pressing
Menu,*,2,8,6,4
8,8 for parts life
scroll down to fuser
hit start for yes
9,9 to exit
Posted on Aug 29, 2008
Develop ineo 501, machine stopped, showing " have the fusing unit replaced soon, contact the service representative" -no error code. There is also "license management error occurs" but this promt was way...
that unit is manufactured my konica minolta. it is a Konica Minolta Bizhub 501 and will use the same fuser even though the image units, toners, and transfer belt have to be chipped for the ineo. There is a picofuse in the fusing harness that blows as soon as it is installed and that starts the fuser life counter. the counter is reset when a new fuser (or new fuse, if the fuser is still good) is installed. You will need to replace the fuser for the message to go away.
Jan 05, 2015 | Office Equipment & Supplies
Hp lj 4100 50.2 error
is this error on a lj4100 or on a cm1017?
if on a 4100- then the complaint is that the fuser has not reached the required temperature in the allocated time- replace fuser kit with CORRECT fuser ( lm4100MKIT) and not a 4000 fuser which is not the same even though they look like each other.
if its a cm1017 then the error is poor communication with the thermal resistor measuring the fuser temp. again replace fuser kit to resolve
Dec 17, 2013 | HP LaserJet CM1017 MFP All-In-One Color...
Xerox 6280 gets error message replace fuser kit, it was replaced and still has the same message
This is an easy one.
The original fuser supplied with the printer DOES NOT have a counter chip. Instead, the PRINTER assumes that when the number of pages printed reaches the level at which the fuser needs to be replaced, the printer issued the REPLACE FUSER message.
If you replace the fuser with another that has come OUT OF a new printer (i.e. a 'PULL' from a new unused printer), since it has no counter chip of it's own, the printer assumes the fuser pagecount is the same as the printer pagecount (because there is no information to read from a fuser chip), and still wants the fuser to be replaced.
A new REPLACEMENT fuser from XEROX, or a CORRECTLY refurbished fuser WILL have a counter chip, and therefore clear the REPLACE FUSER message.
Nov 28, 2012 | Office Equipment & Supplies
Printer keep says replace fuser kit
These is a part on the fuser called a fusable link that blows the first power up cycle and resets the replace fuser message. It sounds like the fuser you installed is a remanufactured unit that was not professionally rebuilt. Contact the place of purchase and get a replacement. The message can only be reset with the fusable link on the fuser.
Feb 13, 2012 | HP LaserJet 4700 Printer
I keep getting a "replace fuser kit" message on my
If you replaced with new fuser even getting same error, then check,
>Check the fuser connector (J5001). If
it is broken or damaged, replace it.
>. Check the connector (J1025) on the
DC controller PCB.
>. Replace the DC controller PCB.
Oct 07, 2011 | HP LaserJet 4700 Printer
When I turn the Printer on, it will initialize and then display an error message "50.7 fuser error" and will not get to 'ready mode' for printing
1. Turn the printer off, wait 10 minutes, and then turn the printer on. 2. If the message persists, reseat the fuser. If that does not work, replace the fuser. To check the fuser, turn the printer off and remove the fuser. Measure the resistance between the fuser connectors. If it is not within the proper range, replace the fuser. If there is not continuity between the fuser connectors neutral and hot with the fuser removed, replace the fuser. If the problem is not related to the fuser, replace the engine controller board. http://printertechs.com/tech/error-codes/error-codes-50-59.php
Fuser Ref: http://computer.howstuffworks.com/laser-printer3.htm
May 05, 2011 | Computers & Internet
I have a Lexmark c540n printer that has the fuser error of 122.03 service fuser error how do i clear it on my machine I don't have tick btn any help would be great
you can reseat the fuser, and see if the message goes away. Or you will need to replace the actual fuser assembly. unfortunately you can't just remove/clear the error. see picture attached as this is what the fuser looks like
after you replace it let me know if you still receive the error.
Oct 15, 2010 | Lexmark T632 Laser Printer
925 service fuser error
A 925 Fuser Error indicates that the wrong fuser lamp or the incorrect fuser assembly is installed.
  1. If this error appears shortly after the fuser unit in the printer is replaced, put the old fuser unit back in.
    If the error message goes away with the old fuser unit, please check that the new fuser unit is the correct one for this printer model.
  2. If the printer has not recently had its fuser replaced, plug the printer directly into a wall outlet. Surge protectors and power strips can sometimes regulate the voltage to a fault for the printer. If the printer is already on a wall outlet, plugging the printer into a different outlet may solve the problem. Keep in mind that there is no need to have the printer connected to a computer during testing for a fuser error as any pages to test the functionality of the printer can be processed internally.
  3. If you have tried the printer on other wall outlets and the 925 Fuser Error still appears, the printer will require service to clear the message.
Jan 12, 2010 | IBM Infoprint 1352 Laser Printer
Replace Fuser error will not go away
With in 2 seconds you have to hit Menu,*,2,8,6,4
Continue even though you hear the 3 beeps.
When it does into maint mode press 88
That is parts counter reset
Scroll to the part and hit ok.
Press 99 to exit Maint mode
Dec 14, 2008 | Brother MFC-8870dw Wireless Multifunction...
RESEAT FUSER
Hi G,
99% of the time the error is the fuser. Either it is damaged, or just not locked in place, and with power off, reseating it will fix the error. Since you just replaced the fuser, I guess the question is did you do it because it was also giving this error, or because it reached EOL ( end of life ).
If it was for EOL message, I would try reinstalling it. If the "reseat fuser" error goes away, but comes back with the new fuser again, then the new fuser you purchased is defective and should be returned or exchanged.
See the information below to correctly troubleshoot your issue.
The following steps are the troubleshooting steps that should be followed for error code 010 397.
First, the definition of the failure is <IOT Fuser Failure>, and means a Fuser Error is detected.
1) With power off, reseat the fuser by physically removing it from the printer, then reinstalling it and locking it in place. Turn the power back on. ( if the error is still present, proceed to step 2 ).
2) If reseating the fuser did not resolve the problem, Replace the fuser with a known good fuser.
( if problem is not resolved, proceed to step 3)
3) Replace the LVPS ( low voltage power supply ). ( if problem not resolved, proceed to step 4 ).
4) Replace the PWBA MCU ( printed wiring board assembly - machine control unit ).
END of troubleshooting.........
In most cases, the fuser itself is the problem. If you tried to reseat or replace the fuser while power was still on, the LVPS could have been damaged just as if there were an electrical storm.
Hopefully this helped.
Oct 28, 2008 | Dell 5100cn Laser Printer
Xerox Phaser 7750DN Laser Printer Logo
180 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
