Question about T-Mobile Dash Smartphone
Turns on and keeps cycling through the main start up screens thats all it does wont fully turn on
My t mobile dash turns on and keeps cycling through the main start up screens but will not fully turn on i cant use it at all
  • 1 more comment
  • Anonymous Apr 14, 2009
    same problem
  • toddmull Apr 14, 2009
    My T-mobile dash keeps re-booting and cycles thru start-up screens but will not turn all the way on.
  • nptbandbrat Apr 15, 2009
    the phone will not turn on it goes to the screen like it wants to but it wont
I had the same thing the phone has two things on it that look like dashes one on the right and one on the left hold them down tell you get a thing that says something about restetin to factory and hit the send button and make sure the phones on cahrge if anything else pops up hit yes and it should work u might have to turn it off and back on
Posted on Apr 15, 2009
Scotts tractor mower wont start. new ingintion switch installed
Doubble check your wiring to make sure you did it correctly. Trace out each wire to make sure it is correct. Check that you start on the hot side of the start solinoid. Check your main fuse. You may need to check your switch with a volt/ohm meter to ID the functions.
Nov 30, 2012 | Garden
Car wont start, changed ecm, plugs, started but died, what should i do
After you put in the ecu, do the crank relearn, and you're good to go.
Ensure that your battery is fully charged before attempting the relearn procedure. Do not leave any battery charger or jumper cables attached to the battery. Close the hood completely. Some applications require that the doors remain closed during the procedure.
96-99 GM
1. Rotate the key to the start position to attempt to start the vehicle (the vehicle will not start).
Allow the key to return to the all position (same as if the vehicle would have started). The theft system light will flash (or stay lit) on the dash for approximately 10 minutes.
2. When the theft system telltale stops flashing (or turns oft) turn the key to the off position for 5 seconds and then attempt tostart the vehicle. The vehicle should start on this cycle.
3. Once the vehicle is running, the password relearn is complete.
00 + GM
1. Rotate the key to the start position to attempt to start the vehicle (the vehicle will not start). Allow the key to return to the on position. (same as if the vehicle would have started)
2. The theft system light will flash (or stay lit) on the dash for approximately 10 minutes.
3. When the theft system telltale stops flashing (or turns off) turn the key to the off position for 5 seconds and then attempt to start the vehicle.
4. Repeat steps 1 through 3 two more times for a total of 3 cycles/30 minutes.
5. On the next cycle of turning the ignition key from off to crank the vehicle should start
6. Once the vehicle is running, the password is learned and this completes the cycle.
7. Clear any DTC's with a scan tool if necessary. DTC history will be cleared after 100 ignition cycles.
Thank you for using fixya and keep us posted
Jun 12, 2010 | 1999 Chevrolet Tahoe
My Dash turns off after the green windows screen
it coiuld be ur battery might have to buy a knew one try ebay
Mar 30, 2009 | T-Mobile Dash Smartphone
My phone doesn't want to turn on!
First make sure your phone is fully charged. Then check...
It may be the storage card - if you take the storage card out it will boot up and you can put it back in. - pain in the a## but it may work. Or Try taking the SIM card out, boot it up, turn it off, replace the card, and turn it on again.
Last resort is a hard reboot. If you did a hard reboot and nothing happened then you did not do it successfully. To do a hard reboot.
- with the phone powered off
- press the two soft keys, yes the left and right soft keys which are the two dash keys labeled - -
- while keeping it pressed, press the power button down
- keep the power button pressed down for 1 - 2 seconds and then release the power button while still holding down the two soft keys. Keep holding down the soft keys until a black screen appears and prompts appear
- now release the soft keys and follow prompts
- if you dont see the black screen with the reset option, pull the battery out, reinsert it and repeat the above steps
- when you see the black screen with the reset option, press the Send button to confirm the reset.
Nov 04, 2008 | T-Mobile Dash Smartphone
My dash will not power on..
Plug it in, take the cover off, keep it face down, and charge it under a cool air. it may not be charging due to the battery being too hot. I had this problem.
Jul 21, 2008 | T-Mobile Dash Smartphone
Phone wont turn on or off
just open your phone clean your keypad than reattech mobile every parts,do wih care,dont do in hurry,
than charge your mobile battery 10 mins or more than try to start your phone.
thanx.
May 16, 2008 | Samsung UpStage SPH-m620 Cellular Phone
T-mobile Dash Won't start
This will fix it:
Turn the phone off, remove the battery for a minute. Replace the battery.
Hold down the right and left soft menu keys simultaneously then press the power button for a couple seconds and release. Keep holding down the soft keys until the hard reset screen displays.
The reset screen will tell you to press 'Send' to reset or any other key to cancel. Press and hold 'Send', which is the button with the green phone on it. After a couple seconds, the device will start to do its thing.
This will take some time so be patient. It will have a question or two as it goes through the process. Answer.
Don't worry, you won't lose your branding (e.g. if you are a tmo customer, you don't lose the ability to have myfavs and your phone keeps the tmo branding/settings).
Apr 30, 2008 | T-Mobile Dash Smartphone
Helio will not fully turn on!
Hi i have had the Helio Hero phone which is no longer carried through Helio for some tech reasons. But this phone is horrible i try and turn the phone on and a white screen shows up i have to keep restarting it and taking the battery out and its fully charged, now it wont even cut on all the way i cant get it to turn back on
Feb 20, 2008 | Helio Kickflip Cellular Phone
T-Mobile Dash Smartphone Logo
145 people viewed this question
Top T-Mobile Computers & Internet Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
