Dell Deminsion e521 powers on fine and every thing lights up but i have no video signal from the video
  • Arthur Hoffmann
    Arthur Hoffmann May 11, 2010
    Have you installed a new video card? moved the machine? or recently install new hardware inside the machine?
  • Dick
    Dick May 11, 2010
    If you are getting no video signal, how do you know the computer is booting properly? Or did you mean something else when you say "powers on fine"?
    Problem Solver:
  • 4 Answers
First try an external VDU (monitor) on the laptop and see what will happen or change the RAM
Posted on Apr 14, 2009
  • Akin Lucas
    Akin Lucas Apr 14, 2009
    first try an external VDU (monitor) on the laptop and see what will happen or change the RAM
Where can i find mixer for dell deminsion dime521
If you mean audio sound Mixer.....go to lower right on screen and click on speaker icon, then on "Mixer".
hope this helps.
May 05, 2014 | Dell Dimension E521 AMD Athlon 64 X2...
Dell dimension e521 power light flashing green
Flashing green power light indicates that the computer is in a Windows Standby power-saving state.
Jul 19, 2011 | Dell Dimension E521 PC Desktop
Describe your dell dimension E521 wont boot and Problem my computer turns on but doesn't open it goes to a black screen with little flashing bar in top left corner nothing new was installed but there...
The 123 lights on tower translates as:
Routine system activity subsequent to video initialization.
Watch your monitor for on-screen messages.
Disconnect the video cable from the computer and see if you get floating color bars on display. If not, your monitor is defective.
Jan 10, 2011 | Dell Dimension E521 PC Desktop
MY DELL DIMENSION E521 WONT BOOT WINDOWS AFTER STARTING UP, I WAS TOLD THAT THE VIDEO CARD COULD BE BAD, WHERE IS THIS LOCATED IN MY PC AND CAN i USE ANY VIDEO CARD TO RPLACE THIS?
Hello, if you were told by an expert tha you need a video card, here what you need:
1: You do not have a slot card type video card in your system( Dimension E521) your system has on board video, which you can not remove from the system but disable it.
2: Your system has PCIe x16 slot that can be used for new video card.
3: Link below will give you a list of PCIe x16 video cards, you can pick and choose according to your needs. Do you need DVI (digital connection, does your monitor has a white port in the back or just the blue one?), or regular VGA (blue port) is enough, do you need HDMI etc...
bottom line is any of those video card will work.
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=40000048%201069609641&Description=pci%20express%20video%20card&name=PCI%20Express%20x16&ActiveSearchResult=False
4: I am assuming you have never done this before so before you open up computer and start taking things apart go to the link below and download service manual for Dell Dimension E521 ( I selected the model for you so you don't have to look for it :-) )
http://support.dell.com/support/edocs/systems/dime521/en/SM_EN/index.htm
5: In the service manual link there are several Sections like:
Before You Begin
About Your Computer
Technical Overview
Specifications
Advanced Troubleshooting
System Setup
Removing and Installing Parts click on each one and read about it first to familiarize your self with the system.
6: Once you feel confident enough remove the power cable from from computer.
-> open computer cover
-> follow instructions in service manual under
->Removing and Installing Parts
-> Cards
->PCI Express Cards
-> Installing PCI express card.
-> Close computer cover
-> plug monitor cable to new card
-> power on the computer
-> if Picture quality is bad that means card was not properly recoginzed, install drivers from the CD that came with the video card.
I hope this helps, if you get stuck at any step or not clear feel free to post back.
Kind Regards,
Amar Sondhi
Feb 01, 2010 | Dell Dimension E521 (D10E16) PC Desktop
Dell dimension e521 won't turn on
hi !
If your have already changed the power supply, there is still a lot of main points of failure in the no power situation. If the motherboard has a flea light, then it could be one of the components. It can be the memory(if no beeps are heard, then memory is not the cause), it can be the processor, or it can be the control panel, in which the power button is attached. Try to check the cables as well.
Cheers !
Dec 25, 2009 | Dell Dimension E521 PC Desktop
I need help upgrading PLZ URGENT dell dimension E521
The most powerful CPU Dell sole in the E521 was the 5600+, 2.8G, Pretty Cheap on EBay
http://shop.ebay.com/i.html?_nkw=Athlon+5600%2B&_sacat=0&_trksid=p3286.m270.l1313&_odkw=Athlon%2C+5600%2B%2C+2.8G%2C+1MX2%2C+Dual+Core%2C&_osacat=0
Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150369
Power supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371007
Oct 08, 2009 | Dell Dimension E521 AMD Athlon 64 X2...
Gibberish + won't finish loading Windows
remove the new memory first. if that does not help you may have some a virus, indicated by safe mode workng fine. One other thing i found would do that is a damaged Hard drive, not to likely here because safe mode works.
Apr 28, 2009 | Dell Dimension E521 PC Desktop
Dimension e521 black screen no video signal
if your num lock key responds, you may have to reseat/change the video card (if you are sure monitor is good). else you need to replace your motherboard.
Getback if you need any clarifications
Jan 09, 2009 | Dell Dimension E521 PC Desktop
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
