Question about Bosch 24 in. SHX36L05UC Stainless Steel Built-in Dishwasher
Growing dishwasher i just replaced my disposal and didn't realize that i had to knock out the dishwasher plug until the dishwasher wasn't draining. i popped the plug out and the dishwasher drained, but now won't stop growling. i tried to re run the load but it's like it's stuck in drain mode now. help please
  • 457 Answers
Ok i will tellyou the secret. your unit is in drain mode .there is water in the base of your dishwasher and it has to dryed out to come out off drain mode. when you dryit then hit cancel and the unit will work. to get the water out you have to take off panel side to see the base. trade secret :0)
Posted on Mar 03, 2010
  • tk105 Jan 12, 2011
    how do I take off the panel side? Do I have to slide the unit out from under the counter? Could I use my shop vac to **** it dry?
Dishwasher not emptying out water
If you recently replaced your garbage disposal make sure the "knock out" plug was punched out to allow drain water into the disposal. The guy who replaced my disposal forgot to do it and my dishwasher would not empty. It's an easy fix. Just remove the drain hose from the dishwasher that attachs to your garbage disposal. Look inside with a flashlight and you will see if it is still there.
If it is, take a hammer and screw driver or punch and knock it out. TURN OFF POWER to your disposal and you can retrieve the "knock out" plug (piece of plastic about the size of a dime). Replace your drain hose to the disposal and try your dishwasher again. Worked for me! Good luck.
Oct 05, 2014 | Dishwashers
Whirpool built-in puddle of water in bottom, food on drain
see this causes and proceed according. God bless you
Belt, Water Pump Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Drain Pump If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable Pump and Motor Assembly If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Check Valve If the dishwasher won't drain the check valve might be stuck closed. The check valve is a small plastic device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is the device that the drain hose is attached to on the dishwasher.
Check Ball If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
Oct 16, 2012 | Whirlpool Dishwashers
My Kitchen Aid superba does not drain. It just happened after I replaced my garbage disposal. I folllowed all of the instructions. How do I check for blockages, etc?
easy job, DISCONNECT POWER..... YOU FORGOT TO KNOCK OUT THE DRAIN PLUG ON THE DISPOSAL.... remove the drain hose off of disposal and push a screwdriver into the opening..does it go thru or does it stop...if it stops..take a hammer and knock the end of screwdriver forcing out the plug...remember, to remove plastic plug from inside of disposal....Do not turn power back on until finished
Jan 23, 2011 | Dishwashers
My GE will not drain at all, I do not hear the drain cycle. We did recently replace a disposal, can this cause the diswaher not to drain. If so, how do we check this and fix it?
Sorry to read about your problem, I hope this helps you out.
i will assume you hookek the dishwasher to the garbage disposal... their is a knock out plug you have to remove from the disposal..you will have to remove the disposal, take a screw driver and put it into the place the hose hooks up to, and remove the plug.. hit with hammer. if you put your finger in the hole you will see its blocked
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 02, 2011 | GE Dishwashers
Dishwasher will not drain- just replaced old, clogged garbage dis
Hi, If your dishwasher drain line is attaching to the disposer than you'll need to insure the "knock out" in the disposer upper end bell where the drain connect's is indeed knocked out. You can do this by removing the d/w drain at the disposer, then reaching in with a long screw driver and with the palm of your hand give it a quick firm punch. Once the knock out pop's out you'll need to reach in the garb and remove the piece of plastic from the knock out. This is a common step overlooked, so if that is the only problem don't be embarrassed, I see it at least once a month or more. Let me know if I can assist you further. Thanks for coming to "fixya" for your solution's. If you found this helpful please allow a second for a positive rating, if it wasn't helpful let me know and I'll try to expand on possible causes and remedies. Good luck. macmarkus :)
Mar 24, 2010 | Bosch SHU9915UC Dishwasher
My dishwasher won't drain after I installed a new garbage disposal.
Check the drain spout of the disposer where you connected the drain hose from the dishwasher and make sure you`ve knocked out the plug in the spout.
If not, with the aid of a long screw driver and a hammer, or a firm smack with the palm of your hand you should be able to knock out the plug. Then reach in the disposer and remove the plug you`ve just knocked out, reconnect the drain hose for your dishwasher and you should be good to go.
Hope that help`s. good luck.
macmarkus :)
Mar 06, 2010 | KitchenAid Dishwashers
I replaced a disposal and now when I run the washer cycle the used water shoots out the drain that is on top of the sink. It didn't shoot out that drain while the old disposal was working and the dishes...
The new disposer has a plug inside the dishwasher nipple that you must knock out. The dishwasher hose nipple is plugged so water won't leak out if you don't have a dishwasher connected. You must take a flathead screwdrivers and knock out the plug inside the nipple with a hammer or something. Make sure you don't leave the plug inside! The air gap is designed to prevent water from siphoning back into the dishwasher. With the disposal's drain connection blocked, the water exits through the air gap!
Feb 15, 2010 | Whirlpool 24 in. DU1100XTP Built-in...
I need to get the drain plug out of the garbage disposal so i can hook up my dishwasher to drain. can this be done without disassembling the disposal. can i knock the plug out into the disposal
Take a flat blade screwdriver and insert it into the drain port that you connect the dishwasher drain line to. Take a hammer and tap the screwdriver until the plug pops loose inside the disposal. Now, reach down inside the disposal and retrieve the plug. You should not have to disassemble the disposal to do this. I hope this answers you're question.
Jun 21, 2009 | Dishwashers
BOSH won't stop draining
take your dishwasher out and look for a water at the base of your dishwasher.
If that is a water at the botton base, just dry the water and its ok.
if you dont find water at the botton base inside replace the water level system PN= 263834 at repairclinic.com, item# 935595 for 41.00 and that part goes in the left side of your dishwasher
May 24, 2008 | Bosch 24 in. SHX46A05 Stainless Steel...
How to knock out garbage disposal plug
Turn off the power source to the garbage disposal. Take the drain hose from the dishwasher off the connector going to the disposal (if connected). Insert a flat blade screwdriver in the drain hose fitting and tap a few times with a hammer. The plastic plug will pop off inside the garbage disposal. Reach inside from the top of the disposal to retrieve the plastic plug. Sometimes you have to use a little force to tap the plug out. Hope this helps you.
Apr 07, 2008 | Frigidaire 24 in. PLD2850 Built-in...
Bosch 24 in. SHX36L05UC Stainless Steel Built-in Dishwasher Logo
272 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
