Overflowing washer I have an eaton viking filter flo washer that has been working perfectly until today. I loaded the washer put it on my desired cycle and load size medium, i went down twenty minutes later to add fabric softener as it should have been on the rinse cycle, but... The washer was still filling (and pooring all over my floor as the washer was now overfull) and the dial hadnt moved at all... is there a censor for how full it should be?? any ideas how to fix this??
  • 686 Answers
Your water pressure switch is malfunctioning or the tube that connects to the bottom of the tub and runs up to the pressure switch is clogged. You need to get into the control panel and see if you see a clear hose. Remove it from the switch and either blow or use a small blast of compressed air to clear the clog. then try another wash. By the way do you use powder detergent? If so do you put it in before the clothes or after the clothes are in.
Posted on Apr 13, 2009
I have found an old boat engine with no make and no cover for it made in Canada patented in Canada in 1956, 57, 58, 60 serial number is C384919 and model number 25DE21V or could be 2IV who made it
Eaton's Viking
[PDF]Eaton's V Eaton's Viking Outboards Model Y iking Outboards Model Y ... www.romeosmarine.com/images/Outboards/VikingModel-YearGuide-2007edition.pdf
  1. Cached
  2. Similar
Eaton's Viking Outboards Model Y iking Outboards Model Y iking Outboards Model Year Guide ear Guide ... 25DE21V 25.0 Electric Starting. 40D15V 40.0 ...
[PDF]Eaton's Viking Outboards Model Year Guide ... - Richard L. Paquette
https://richardlpaquette.ca/VikingModel-YearGuide.pdf
  1. Cached
Eaton's Viking Outboards Model Year Guide. 1933-1969. Richard L. Paquette, Third Edition, August 2009. Year: 1933-35. 1936-38. 1939. 1939-41. 1940-41.
Original 1963 Eatons Viking 25 HP Outboard Motor Parts Catalog ...
blackcatantiques.net > Manuals > Boat Motor Original. 1963. Eaton's Viking. 25 HP. Outboard Motor. Parts List. Model 25D21V. &. 25DE21V. NOS. (Sellers Inventory no. B111003). Up for sale, we are ...
Original 1963 Eatons Viking 3 HP Outboard Motor Parts Catalog ...
blackcatantiques.net > Manuals > Boat Motor Original. 1963. Eaton's Viking 3 HP. Outboard Motor. Parts List. Model 3D19V. NOS. (Sellers Inventory no. B111000). Up for sale, we are offering an original ...
Original 1963 Eaton's Viking 5 HP Outboard Motor Parts Catalog Model
  1. Cached
Original. 1963. Eaton's Viking. 5 HP. Outboard Motor Parts List. Model 5D22V. NOS. (Sellers Inventory no. B111001). Up for sale, we are offering an original ... Eaton Viking 25DE21V Google Search
Sep 21, 2017 | Boating
I have an Eaton Viking stove that has a broken baking element. Is there anyplace that can supply one for me.
Amazon or direct
Amazon.com: Bake Element for Viking Range, PJ010004: Appliances
https://www.amazon.com/Bake-Element-Viking-Range-PJ010004/dp/B00OJ5VL0U
Rating: 4.8 - ‎17 reviews
Buy Bake Element for Viking Range, PJ010004: Range Parts & Accessories - Amazon.com ? FREE DELIVERY possible on eligible purchases.
Viking Parts by Viking - Factory Parts for Viking Appliances
www.allvikingparts.com/ Need a part for a Viking Range, Stove, Oven, Grill, Refrigerator or Dishwasher? We stock thousands of Genuine Viking parts.
Locate Your Viking Model and Serial Number - Allvikingparts
https://www.allvikingparts.com/Articles.asp?ID=142 What do Viking Model Number and Serial Numbers Look Like? Viking ... For Viking Open Burner Ranges and Rangetops(You have an Open Burner Range or ... Eaton Viking stove Google Search
Mar 13, 2017 | Heating & Cooling
Turn off the alarm eaton viking stove
This did not work for me. The alarm won't go off at all. The dial for the clock seems very loose - it stuck many times when I was turning the dial to change the time, and then it just got loose, and now the alarm won't go off. Please help!
Jun 14, 2014 | Viking Stove/Oven/Range Timer Knob -...
Need to clean water filter so water will flo better
If it is a top load washer. No have! Front loads one are to the bottom left or right on the door side.
Jan 19, 2014 | Crosley Washing Machines
Water keeps overflowing, dont know how to clean the filter or where it is .
hi, read about your problem. The filter is located at the bottom of the front of washer. If its not visible, remove the bottom kick panel. Three screws at bottom. Take a shallow pan and place under filter. Slowly turn counterclockwise and water will slowly start to come out. When pan is partially full, empty. Be sure to close filter before doing this. Keep up with this procedure until no more water comes out, then unscrew filter and remove and clean. Reinstall and put kickplate back on. Hope this helps.
Jan 19, 2011 | Hotpoint Aquarius WD640 Front Load...
Where can I find Viking Dryer drum belts? Who still has Eatons Viking dryer parts/ Montreal, Quebec
Hello, welcome to FixYa. Good day from Alberta !
At the risk of generalizing ( unless you can provide a model number ) most of the appliances sold through Eaton`s all across Canada where built by General Electric/CAMCO, which have since become "MABE". The exception would be the really old unit`s ( 25+yrs. ) who could either be built by Westinghouse, or GSW.
In any event, regardless you should be able to locate a belt at brick & mortar parts stores in your area or online at vendors such as "reliableparts.ca", "searspartsdirect.com" to name a couple.
Check the link below it has a local Montreal "GE" phone number if you scroll down that site.
http://www.geappliances.ca/parts/index.jsp
This should also help when putting on the new belt...
Hope that answer`s your question, thanks for choosing FixYa today.
Good luck.
macmarkus :)
Aug 17, 2010 | Dryers
Kenmore 80 Series Overflow
We've now had this happen three times and the exact same thing caused it all three times.
If the water level selector knob hasn't "clicked" into one of the given load levels on the control panel(i.e. the knob is in between levels) it will continue to fill until you discover water everywhere and turn the knob until it "clicks" into a level.
As far as I know, it has nothing to do with loose hoses or bad switches, it's bad design. There seems to be no safety mechanism to turn off the water if you over- or under-shoot the desired water level.
Apr 29, 2009 | Kenmore 24032\24036 Top Load Washer
Stove oven wont work..
Yes, you can use the Eaton Viking element in place of the Gibson element as long as all mountings are the same.
You should use ceramic washers between the element and the casing to prevent it from grounding out...which is what probably happened to the element in the first place.
Be sure to look for chapped or burnt wiring BEFORE replacing the element. Also look for burnt connectors.
Hope this help you! :)
Apr 11, 2009 | Viking Stove/Oven/Range Timer Knob -...
Whirlpool washer overflow during wash cycle
What you can try is to get the machine empty and remove the hose that connects the pressure hose to the switch and blow air through it to make sure it is clear, then tap on the nozzle where the hose connects on the switch to make sure it is also clear.
Oct 16, 2008 | Whirlpool 3.2 cu. ft. Plus Washer
Washing Machines Logo
116 people viewed this question
Top Washing Machines Experts
