Question about Frigidaire FWS833A Top Load Washer
Fridgidare washer notr spinning top loaded
Fridgiare not spinning
  • Anonymous Apr 22, 2009
    same here
This may either be the lid switch usually located to the right (as you face the washer) under the lid.  Or, the more expensive problem-the timer, which is located behind the main washer control knob on the right.  The first thing I would check is the lid switch-make sure the plug in the switch is tightly connected and try spin cycle again. If that doesn't resolve it, you're looking at a timer issue. You can replace the timer yourself if you are mechanically inclined, you just need a lot of time and patience. There are several websites out there that walk-you-through the process of replacing the timer.  Good luck!
Posted on Jun 24, 2009
Fridgidare washer front load won't spin & there's water in the tub. It's about 10 years old
If it's that old, you're better off buying a new unit. You'll spend about half the cost of a new one fixing it.
Jun 11, 2012 | Washing Machines
My fridgidare top load washer does not drain all the water from my clothes,could it be the belt?when it spins,it makes a whistling sound
Replace the belt and check for debri around the transmission (tranny drives the agitator which controls the capability of the washers actions). The cost of tranny replacement is not worthy buy a new unit when all else fails the whistling sound comes with age
Jun 17, 2011 | Frigidaire Washing Machines
Fridgidare affinity washer will not spin, makes a growling noise
use a shop vac and attach it to the end of the drain hose remove all the water then you need to check the drain pump and see if there is anything blocking the pump.
Sep 27, 2009 | Frigidaire Affinity ATF7000E Front Load...
Buying a front load washer
NO, All of the fridgidare products are bad. Buyer beware. Check out more internet if you need further warning. Spyder bracket and drum bearings on the front load fridgidares are a money pit. Buy and LG from anyplace but Sears. Buy anything otherthan GE,Electrolux, Kenmore, Hotpoint from Sears.
Jan 11, 2009 | Frigidaire ATF6000ES Front Load Washer
My cltf2940es0 fridgidare front loading washer will not start a cycle. The door will lock and the timer will set, however when the cycle should start the motor makes a subtle humming noise. This will...
unplug washer. take off bottom front panel remove rubber boot hose from bottom of tub to pump .have towel or cake pan ready for water.clean out boot and stick finger in pump clean out also remove drain hose at pump check for coin reinstall hoses this fixes must problems with front loaders
Nov 12, 2008 | Frigidaire GLTF2940ES Front Load Washer
Fridgidare Affinity washer door won't open after wash cycle
Try the following site for full information on unlocking Dryer -------
http://www.freepatentsonline.com/4908957.html
Sep 14, 2008 | Frigidaire Affinity ATF7000ES Front Load...
Washer appears to be out of balance
Double check the screws holding the washer to the pedestal to make sure they are tight and make sure all the jam nuts on the leveling legs are tight. Loose jam nuts are the most common cause of this.
If they are tight, loosen the right front leg and screw it up until the weight is off the floor. Then run it back down until it contacts the floor. Put the washer in high spin and tighten it down to the floor until you get the spot where there is the least vibration. Tighten jam nut, and check it again in spin with a load of clothes.
Post back and let me know how this works.
Oct 18, 2007 | Whirlpool GHW9100L Front Load Washer
Frigidaire FWS833A Top Load Washer Logo
257 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
