Question about Lexmark X5650 All-in-One InkJet Printer
Refilled the black cartridge and now it doesnt recongize it
Is there a way that i can get the printer to recognize the refilled cartridge?
  • btracie31 May 13, 2009
    refilled my color cartridge with a refill kit and my computer doesnt recognize it
  • Steve Brooks
    Steve Brooks Mar 28, 2013
    Lexmark is the asswhole company trying to screw the consumer sort of like Tandy computers did years ago..run from this printer..you can only buy original cartridges and they quit when they want to quit..it's a total scam
How do i reset the chip to where i can print again...already have filled ink cartridges
Posted on Jul 09, 2009
  • Lexmark Expert
  • 228 Answers
“Lexmark does not support the refilling of its ink cartridges. Refilling the ink cartridges can cause them to leak, thus clogging or even damaging the print head. Any damage to your printer caused by refilled ink cartridges may not be covered under warranty”. Please use genuine Lexmark cartridges for best results.
Posted on Apr 14, 2009
  • Steve Brooks
    Steve Brooks Mar 12, 2013
    lexmark does not have the right to not support the fefilling of "our" ink crtridges..again they are "our" ink cartridges and we should be able to do anything with them we want..
HP 940 would not recognize refilled cartridge
You must have a working chip on the cartridge in order for the printer to recognize the refill. The replacement chip must be placed in the same position of the OEM in order for the printer to read it.
Feb 02, 2013 | HP 940 Black Inkjet Cartridge
My Epson NX415 does not recognize refilled and reset cartridges. What can I do about it?
Don't let your ink levels drop below 25% before refilling and resetting your cartridges. There is an inner and an outer chip on these cartridges. The inner chip disables the outer chip when it's contacts are no longer bathed in ink. So, it doesn't matter if you "reset" the outer chip after refilling your empty cartridge because the chip was disabled. I'm really curious how you refilled these cartridges yourself without souring yourself on refilling from the experience. I own a Cartridge World ink refilling store and I refilled a set of these cartridges when we had replacement chips available (we don't now because our chip distributor was violating Epson patents) and it was an absolute mess, took forever, and the cartridges still didn't work in our test printer.
Feb 13, 2010 | Epson Stylus NX400 InkJet Printer
Hp F4280 can't recognize a black cartridge after refilling it. What can I solve the problem? Please help me!!
If the printer not recognize it, that mean the cartridge are failed electrically and you need to replace it.There is an another option.After refilling printer will recognize cartridge like empty but it will printing.
Nov 17, 2009 | HP DeskJet F4280 All In One Printer InkJet
Using refilled printer cartridges in Canon MP500, how to reset
There is no way to reset it, you just have to watch your ink by the printing you do, Normally, black ink will last up to 500 copies or more if you put your printer properties on fast print (this is to save ink when printing from the Standard version). In Color, it may vary with the projects that you do. The way I check, when my cartridges to see if they are almost out, is to run the clean cycle under the printer utilities menu, then the printer test page. This should show you what colors, and black ink you have or dont have. When you recycle or reuse your cartridges, the metal component that is on a new cartridge for the printer to recongize the it, is removed during refill process. I dont why the companies that fill the cartridges do put it back. I wish they would it would may things alot easier. I hope this helps.
Aug 27, 2009 | Canon Pixma MP500 All-In-One InkJet...
Epson c62 color ink cartridge says it is empty when i just refill
I use cheap replacement cartridges about 20$ for 3 color/5 black....the printer usually doesnt recognize the cartridges ink level but it still prints......do you use actual epson replacements? If you use cheaper replacements you might have gotten some with dud chips...prob the cartridges fault, not your printer
Jan 01, 2009 | Epson Stylus C62 InkJet Printer
Canon ip1200 black cartridge wont recognize after i refill
Dear lim,
Here a solution for you. The cartridge of this printer has memory chip that store ink level data inside. Once the cartridge is empty we cannot restore ink level data to be full. To continue using refilled cartridge you need to deactivate ink level detection function first. Perform this step: when the message 'The following cartridge cannot be recognized' appears press Resume/Cancel button. Do this for each cartridge you refill;if you refill both black & colour cartridge do this tip two times (once for each cartridge).
Please rate this as fixya ok.
Regards,
Dec 02, 2008 | Canon PIXMA iP1600 Printer
Working with cannon ip 1300
You need to have a black and a color cartridge installed to use your printer. That doesn't mean the color cartridge has to be full. You can have an empty color cartridge in the printer and it will work as long as the electronics are good on it so the printer can recognize it's there. You cannot refill these cartridges yourself. Your printer remembers what cartridges have been in it so that it can reject refills (it sees the same serial number twice and catches you trying to not give Canon their money). You can use refills, but you need to get them from a refiller with a high turnover of cartridges so you don't get the same serial number twice. I recommend Cartridge World stores as they have high quality refills with a 100% satisfaction guarantee.
Sep 21, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Printer says ink cartridge not recognized.
Take the black ink cartridge back to the person who refilled it. The Microchip that's on the cartridge was not reset properly that's why the printer is returning that error.
You can try some steps before you take it to them to verify it.
1: reseat (take out and put back in) the cartridges into place
2: buy another black cartridge just to check if it will be recognized by the printer, if it does recognize it we know the cartridge is defective. If a new cartridge is also not recognize, start to check your warranty option with the manufacturer...
Sep 05, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Ink cartridge error message
Turn the printer off.
Hold down the Stop, B&W, and the Color buttons.
Press the ON button.
The LCD screen should flash 3 times.
Release the Stop, B&W and Color buttons
Press the Color button again.
Then turn the printer off and back on.
Aug 25, 2008 | Epson Stylus RX500 All-In-One InkJet...
Machine does not recognize refilled office max cartridge (black)
sir,
try to clean the cartridge on the copper side with tissue with and alcohol maybe the contact points doesnt meet or the cartidge itself is already defective. try also use an empty good cartridge just to to determine wich cartridge is defective.
yours,
alecz
Apr 23, 2008 | HP PSC 950 All-In-One InkJet Printer
Lexmark X5650 All-in-One InkJet Printer Logo
758 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
