Question about Samsung SF 5100 Laser Printer
Not Printing Hi There. My Printer does not print. when i try print something from my pc, it does not even react. but it works fine as a fax machine. the only drivers i could find for it were the Sf-5100p drivers. Is it possible for you to tell me where i can get the correct drivers. Or tell me how i can solve this problem. Thanks
  • 1 more comment
  • Mrakulis Sep 19, 2007
    Where Is "the computer market"??????
  • Anonymous Nov 02, 2007
    samsung sf 5100 working great as a fax machine not printing from my computer
  • Anonymous Mar 03, 2008
    not printing but bwking as a fax
Sf5100 p is a printer port, sf5100 is a diagnostic port, useless?
Posted on Oct 01, 2008
I have the samsung sf-5100 and found on the samsung website that even though this machine has a parallel port, it does not work. Check your model number. If it is just SF-5100 you can't print to it from your computer. If it is SF-5100P then you should be able to print from your computer. I have no idea why samsung would put in a parallel port that doesn't work.
Posted on Jan 19, 2008
  • 163 Answers
Find the driver from the computer market
Posted on Sep 12, 2007
Ca no longer scan or copy
Try to unplug the power adapter at the back of the printer for about 30 seconds then plug it back in.
If it doesn't work, then the printer may already be defective.
Dec 17, 2012 | Lexmark "x4650 multifunction inkjet...
I am having trouble with the printer. The DR is working fine. It sounds like it is printing, however it does not. print. There seems not to be a problem with ink The printer is not printing. I...
Definitely you have a problem with the printer.
That will not prevent you from sending faxes out, but did you try to make a copy?
If the machine sat idle for some time, the ink in the jets would have dried, but this will not generate any error messages.
There are cleaning kits available, and they usually work.
May 31, 2011 | HP 1040 Plain Paper Inkjet Fax
My fax machine stays on and I can't print somethings. Everytime I try to print something the "FAX" machine window opens up....instead of the "PRINT" window. I clicked on the little arrow by the printer...
Try this.. Go to start, devices and printers and you will have a few things listed in there that are related to your printer. Most likely it will say document writer, fax and your hp printer. Make sure that the check mark is on your printer, not your fax. This indicates what your default printer is. To change this, right click on your hp printer and select set as default printer. Once this is set try printing again. Let me know if this works, if not we will try step 2. Hope this helps!
Oct 23, 2010 | HP Office Equipment & Supplies
Printer ''out of paper'' message
What make / model of fax machine?
Dec 03, 2009 | Office Equipment & Supplies
It has plenty of ink and the drum is good but it stopped printing
All blank pages could either mean: On the scanner side: * Mechanical error, you'll need to perform service on it to reanimate it again. * You can check if it is on the scanner side by printing a test page on the printer. If it prints fine, the problem is in the scanning process.
On the printer side: * Dirty connectors between toner/drum unit and machine. Remove the toner/drum package and clean the metallic cylinders on the left and right side of the toner/drum unit, then reinsert package into machine. * Bad toner and/or drum unit. Replace should solve it. * Mechanical error, you'll need to perform service on it to reanimate it again. * You can check if it is on the printer side by either scanning to a connected PC or sending a fax to someone. If the scanned/faxed page looks fine on the pc/fax that receives the fax, the problem is in the printing process.
Jun 02, 2009 | Brother MFC 9700 All-In-One Laser Printer
MP 780 DOESN'T PRINT
Try printing something in a colored font, like red or green and see what happens. This printer uses two black ink cartridges. It uses the larger one for black text printing. If it is dry, blocked, or damaged, your text (usually black) will not print. Changing to a color font will rule that out.
Good luck.
Feb 23, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Hp office jet 4255 printer not printing anything or copying
ok..first try to make a copy and check if it copies fine or not..
if it copies then hardware is working fine..
turn off the laptop and unplug the USB cable..
turn on the laptop and wait for 5mins and then connect the USB cable..once the USB cable is connected do not try printing..wait for the hardware to get installed..
and then go to the printers folder and check if the printer icon says 0 ready..if it says then try printing..that should work
Feb 19, 2009 | HP OfficeJet 4255 All-In-One InkJet...
Fax printing problem
The blue release lever that holds the ribbon cartride may be cracked or broken. The crack may be so fine, that it's not easy to see, so look carefully. Even the slightest crack will cause the ribbon cartridge to fit loosely enough so that the roller is not touching the paper. Whatever side is not printing, that's the lever that you should look at. That's what happened to mine. I was ready to buy a new machine, until I found that solution. To test it, I tried to copy something while pushing down on that side of the ribbon cartridge, and it printed fine--the whole page. I looked more closely at the lever, and found the crack.
Jun 10, 2008 | Brother IntelliFAX 1250M Fax
Samsung SF 5100 Laser Printer Logo
212 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
