Panasonic Lumix DMC-TZ1 Digital Camera
Problem for Panasonic Lumix DMC-TZ1 Digital Camera
I have a Lumix DMC FX3..great butr is stuck in
By jack_griffit on Apr 13, 2009
I have a Lumix DMC FX3..great butr is stuck in full zoom mode and none of the function buttons work. ie no shutter etc. but review shows one of the pics stored only and in camera mode it shows all in focus but fully zoomed...help!
Solution #1
posted on Apr 13, 2009
Not Helpful)
MelMc
Rank: Apprentice
Rating: 81%, 5 votes
try removing the battery and leave out for a few minutes to erase the camera memory so to speak, then replace battery and see how you go, good luck
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Nov 05, 2009
Not Rated)
dupalopez
Rank: Guru  Panasonic Expert
Rating: 93%, 19 votes
Hmm, looks like the zoom rocker switch might be stuck. To get to the switch you'll need to partially strip the camera. This is a bit fiddly, but should be ok if you are comfortable with taking things apart. I repair cameras as a hobby and in my opinion lumix-es are by far the easiest to take apart and put together.
Remove the battery, unscrew all the screw holding the case making notes which screw goes where (they are not the same). Very carefully lift the back of the case to see two white ribbon cables going to LCD screen. Disconnect them. Once done, remove the front of the case. With both case panels removed pull off the top section (where the power, shutter/zoom buttons sit). This will require a bit of force. Once done, you'll need to undo the plastic cover, there should be a screw or plastic catches holding it onto the small logic board. A word of warning, there is a flash capacitor attached to the board (looks like an AAA battery). This can potentially electrocute you (won't kill you but is not very pleasant) , so try not to touch the tracks/connections on the board. Once you expose the top of the board you'll be able to see the zoom rocker switch (a little silver square thingy with a black bit sticking out). The black bit is the bit which is stuck. Try to move it (gently). It should stay in centre position. Well, that's it. Put the camera together and hopefully it's back to normal.
Hope this helps.
Raf
Was this helpful?
Yes
No
Popular Solutions for Panasonic Lumix DMC-TZ1
Questions and Unsolved Problems for Panasonic Lumix DMC-TZ1
Do you recommend Panasonic Lumix DMC-TZ1 Digital Camera?
Answer
Answer
I am having a problem putting the battery back into camera, advise please Model Lumix Panasoni TZ4
Answer
I keepgetting a large blurred spotin the middle of thepicture when taking pics inside-I have tried... (More)
Answer
I replaced the battery and sometimes I turn it on and it indeed does turn on and other times I turn... (More)
Answer
Hvor kan jeg kjøpe batteri og Batterilader for EuroCaber x-28. og hva koster dette?
Answer
tells me to turn off then on again and get the same thing.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Panasonic Lumix DMC-TZ1...:
Top Digital Camera Experts
Rank: Guru Guru
Solutions: 901
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Digital Camera Experts
Top Camera & Camcorder Repair
(915) 239-6199
CamerasAndParts.Com Specializes in the Service /...
CamerasAndParts.com
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
