Question about HTC Tilt 8900 Smartphone
Htc 8925 wont turn on, little red light comes on when connected to charger. battery measures 4.2VDC.
    Problem Solver:
Have you tried hard-resetting your device? Push the buttons on the bottom and while you hold them, also press the normal reset button with your stylus. Now wait for a white screen.
Posted on Apr 13, 2009
My HTC mobile not going to on after pressing power button and on connection of charger it is showing red LED. Same there here. I woke up this morning and my phones just dead. Even if i connect the charger...
Remove the battery then connect the charger without the battery. Then hold down the power button for a few seconds. The red light may come up for a quick second during this process.
Don't remove the charger. After the red light goes off then insert the battery and check if the light turns amber or orange.
Leave it in orange or amber light state for about 2 minutes. After that, try to turn it on. If it turns on then it is resolved. If not then there is a hardware problem with your phone and it needs to be checked at any HTC Service Center.
Jan 28, 2011 | HTC Touch P3450 Smartphone
My htc wont open and when i connect charger, led light goes red what happen?
Maybe your battery is dead and will not charge. Normally when you connect the charger the led must become orange after a few seconds and green when the battery is fully charged. If it stays red the battery is not charging.
Jan 24, 2010 | HTC Touch Dual Slider Smartphone
My tilt 8925 wont charge the battery anymore, I've had it appox 1 year. the phone reacts to the charger being pluged in but won't convert over to charging mode
If it will turn on a little, tap the icon for the battery in the upper right hand corner of your main screen. This will bring up a "system status" screen. Tap the icon of the battery there also. It will then pull up a tabbed screen. Under the "battery" tab, make sure that the check box next to "when device is turned on, do not charge the battery when connecting to the PC" is UNCHECKED. Then try plugging it into a USB port and see if it will charge or sync. I hope this helps!
Jun 29, 2009 | HTC Tilt 8900 Smartphone
Tilt 8925 will not come on
Most probably that's your battery is faulty.
Good luck.
May 05, 2009 | HTC Tilt 8900 Smartphone
Battery will not charge in phone on charger
Ive seen phones that were the same but most newer phones should be able to charge the battery through the phone not just the battery cradle. You have probably got a defective phone. I'd be very surprised if it was designed that way but sadly its possible. Call your provider to double check and be sure to keep your box and all materials as most companies wont let you return or exchange a phone without the original packaging and everything in it. Good Luck.
Apr 19, 2009 | BargainCell AT&T HTC 8925 Tilt Smartphone...
My htc tilt stopped workng.
I've seen this on the 8525 which is the same basic model (different processor and few different features) as the 8925 (Tilt).
Most likely it's a bad mini-USB port on the phone. You can check this by replacing the phone's battery with one that is known to be fully charged.
As for water damage, the only way to know is to check the water damage sticker.
Dec 12, 2008 | HTC Tilt 8900 Smartphone
Htc not turn on, red light on
Remove the battery from the mobile, press the power button, for 30 seconds.
Re attach the charger , switch on the phone. If it turns on switch it off again and reinsert the battery and check.
If none of the above steps work, you would have to take it in for repairs as there could be a problem with the power supply inside the phone , that would require special tools to open
Thanks
proton
Oct 11, 2008 | HTC P3300 Smartphone
HTC Tilt 8900 Smartphone Logo
591 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
