Question about Hardware & Accessories
Vehicle Entry Gate Will Not Open on Schedule.
I have a Paragon EC71D Single channel time control for two sets of vehicle slide entry gates. The problem that I am having is that one of the entry gates does not open at the scheduled time. The other three gates are working fine. I have reentered the schedule in the timer with no luck. If I manage to get the gate to stay open it closes at the right time, but will not open the next morning. The wires seem to test out fine. Does anyone have any suggestions?
  • 50 Answers
After you program the door, you have to push "sel" and override the load until the next setpoint.
Posted on Apr 13, 2009
I have 2005 chevy tahoe my doors all licks but my liftgate door with window stays open use to lock w all my doors? I havent check anytjing yet? I cant lock it.
Here is how it works !
Liftgate Locking Operation
The lift gate will lock any time the vehicle is shifted out of park on vehicles equipped with an automatic transmission and at vehicle speeds exceeding 5 kph with manual transmission. This happens in conjunction with auto door locks if enabled or independently of auto door locks if the feature is disabled. This ensures that the lift gate is locked anytime the vehicle is shifted out of park or when the vehicle is in motion.
The lift gate lock relay supply and coil sides receive a constant voltage through the battery voltage supply circuit and the ECC fuse. The normally closed contact is connected to ground and the control side is connected to the body control module (BCM). A lock function will occur when a door lock switch activation, keyless entry lock transmission, auto door lock function or a lift gate lock function has been received by the BCM. The BCM will then ground the control side of the lift gate lock relay. This energizes the relay and allows voltage to be applied to the lift gate lock actuator lock control circuit. Since the other side of the lift gate lock actuator is connected to the normally closed contacts of the door unlock relay to ground, the lift gate will lock. When an unlock function occurs the BCM will ground the control side of the unlock relay and the rear doors and lift gate will unlock.
The BCM also runs diagnostics on the lift gate lock relay control circuit and will set DTC B3825 as current and also send a Class 2 message to the DIC. The DIC will display REPLACE LIFTGATE FUSE to inform the driver that a fault has been detected in the lift gate lock circuit and that the lift gate is not locked. Faults that will set the DTC and cause the DIC to display the message could be any of the following:
An open ECC fuse
An open or short to ground in the lift gate lock relay battery positive voltage circuit
A faulty lift gate lock relay
An open or short to ground in the lift gate lock relay control circuit
A short to ground in the lift gate lock actuator lock control circuit
A faulty BCM
May 14, 2016 | Cars & Trucks
I have a 2003 trailblazer and i bought a fob and it does not work after programing Everything thing works on my truck but the fob. Any ideas?
How was it programmed ? Was a scan tool used ?
Program All Key Fobs
To complete this programming operation, all keyless entry transmitters associated with the vehicle must be available for programming. Once placed into program mode, all previously programmed transmitters will be erased from memory upon the receipt of the programming signal from the first transmitter.
  1. Close the lift gate.
  2. Ignition ON, access the scan tool Lift gate Module Setup menu and select Program All Key Fobs.
  3. Follow the scan tool on screen instructions in order to program the transmitters. Select "Start" on the scan tool to enter the program mode.
  4. As each transmitter is successfully programmed, the scan tool will show how many transmitters have been placed into memory.
  5. When all transmitters are programmed, exit the program mode by selecting "Stop" on the scan tool. The vehicle will not respond to the transmitters until the program mode is exited.
  6. Operate the transmitter functions in order to verify correct system operation.
Program Individual Key Fob
If there are less than four keyless entry transmitters programmed to the vehicle, an individual fob transmitter can be added. This method will not erase previously programmed transmitters from memory.
  2. Ignition ON, access the scan tool Lift gate Module Setup menu and select Program Individual Key Fob.
  3. Select "Program additional Key Fob" on the scan tool.
  4. Follow the scan tool on screen instructions in order to program the transmitter.
  5. Operate the transmitter functions in order to verify correct system operation.
Apr 08, 2016 | Cars & Trucks
WHERE IS THE KEYLESS ENTRY FACTORY CODE FOR A 2001 WINDSTAR LOCATED ON THE VEHICLE
dfa7bf75-8862-4db4-b289-d31ec41490a8.jpg 7b75fc08-b003-496e-ab19-505a28abecef.jpgYou mite find it on the glove box sides or on the back gate just a sticker with the 5 numbers on it . It is be hind the radio
Jul 02, 2014 | 2001 Ford Windstar
Keyless entery only opens drivers door
Try pressing the unlock button twice
Nov 16, 2013 | 2006 Chevrolet Uplander
Elite slider gate opener sporatically stops partially closed
first guess a bad electric motor
second guess to much resistance between the gate and the tracks try manually moving the gate does it get stuck at some point
3rd tighten any and all loose bolts throughout the system
Feb 04, 2018 | Home Security
2006 F-150 no manual.. does this model have a garage door opener built-in ?
It is not standard equipment.
Here is what the manual says (copied and pasted from owners manual)
HOMELINK WIRELESS CONTROL SYSTEM
(IF EQUIPPED )
The HomeLink Wireless Control
System, located on the driver's visor,
provides a convenient way to
replace up to three hand-held
transmitters with a single built-in
device. This feature will learn the
radio frequency codes of most
transmitters to operate garage
doors, entry gate operators, security systems, entry door locks, and
home or office lighting
Feb 27, 2011 | Ford F-150 Cars & Trucks
Donde puedo encontrar los 5 numeros del keyles entry en el auto
OPEN THE TAIL GATE ON TH INSIDE OF THE TAIL GATE SOME TIME THEY PUT A LITTLE STICKER WITH THE NUMEROS.
Nov 06, 2009 | 2001 Ford Windstar
Problem with KXTDA50 CO 4 Connected to Gate entry system
you can increase the timer that the system checks for dial tone... but you BEST bet would be to put the doorking into Intercom mode
May 26, 2009 | Panasonic KX-TDA50 Phone
Toyota 4runner gate window, wiper, and keyless entry not working
make sure the back window is all the way up then try the wiper, if it still does not work then it is a sensor for the rear window (about $30.00) if you installed it yourself
Mar 31, 2009 | 2000 Toyota 4Runner
Hardware & Accessories Logo
157 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
