Question about Vizio P42HD Television
Vizio P42HDTV10, 1.5 Years Old,Serial # AHPFABAG150971
Set Has Audio But No Video Worked Perfectly Until The Other Then Suddenly No Video, Nobody Locally Services TheseAnd It Is To Heavy To Ship, I Am Pretty Good With Electronics If Someone Would Point Me In The Right Direction.
Thank You
Steve
  • 3 more comments
  • Steven Rivera
    Steven Rivera Apr 13, 2009
    I Have 5 Of These In This Place Telling Me I Have To Replace
    Them After A Year And A Half Has Got To Be Wrong
  • Steven Rivera
    There Is One Set That Has The Problem, But The
    Other
    Four Sets Are Exactly The Same And Were Purchased
    Together, I Do Not Want To Have To Replace Them
    All After Only 1 And A 1/2 Years,From What I Am
    Reading This Seems To Be A Common Problem With
    This Model. Thank You,Steve
  • Steven Rivera
    When You Say MAIN Board Are You Talking About The MAIN Power Supply Board ?
    Thanks Steve
  • Steven Rivera
    I Did Hit Add Comment,It Is 1 Of The Five Sets That Have The Problem
    Thanks
    Steve
  • Steven Rivera
    Steven Rivera Apr 14, 2009
    Thanks For The Info But Those Resistors Are Not On The P/S Board They Are Surface Mount Resistors On The Tuner Board,
    To Clarify My Problem Is With Just One Of The 5 That We Have Here It Worked Great Till A Few Days Ago When The Set Is Turned On We Sound No Picture Just A Black Screen.
    Thanks Again
    Steve
    Sergeant:
  • 291 Answers
Check out the video ic on the main power supply board that is IC NUMBER IC301LC.and also check out resistor number r94 and 97 on power supply board.they control the video in the tv of your model.the cost of the parts is negligible and are easily available.
thanks. keep updated.
Posted on Apr 13, 2009
  • jamesrated Apr 14, 2009
    it happens due to many reasons.most common reason ios power failure at the time when the tv is turned on.or due to humidity problem at certain location.the moisture droplets gets collected and when you on that wet moisture droplets makes the circuit board short and this types of problems happens.
    this are just some common reason of why this problem happened but there are many other reasons too.
    and yes you are right that the resistors on the mount.its the proper location.in older tv board it was on the power supply board.in newer tv boards its there on the mount.
    get it repaired.this wioll help.
    please do rate the solution.thank you for using fixya.
  • 10,594 Answers
I'm not clear on above comments, do you have 5 TVs of same model for same problem?
Hit "add a comment" button for reply to move forward.
Thanks.
  • Shahid Electronics
    Shahid Electronics Apr 13, 2009
    Now I have lost contact with you and can not carry on this repair project of 5 TVs because you did not use "add a comment" button and re-posted problem.
    Good luck.
    Top Expert:
  • Vizio Master
  • 76,164 Answers
The main circuit board goes out in these, it is useually tiny little capacitors that cause the problem, do u have the equipment and background to perform test on this, u will need the circuit diagrams and repair manual, but in the end u will end up buying a new set, go with LCD model.
  • yadayada
    yadayada Apr 13, 2009
    are u in a TV repair business? the main board is going to have to be repalced, this set has lots of posts on the internet about this problem.
No input to tv
Hi, during the last 3 years, my Harman Kardon AVR3600 has worked perfectly, but suddenly i don't know why does my unit only provide sound, and no video.
That I can do, and reset the unit, change the HDMI cable, etc... but still no video. Tkhs
Mar 19, 2013 | Harman Kardon AVR 3600
Vizio plasma tv
what connection are uusont tivo ? have u tryed other sourses
Jan 28, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Philips Magnavox 9P6031C103 projection tv quit working 2 years ago (before, the picture began to shink and expand until it finally quit completely with no audio nor video -- turned it on two years later to...
Based on what you described I would say your TV has the "shrinking and expanding" fault. Its a common problem on that model and the symptoms can range from the video shrinking and expanding or no video or no audio....You can read more about this fix on the site www.TvRepairKits.com
Jan 13, 2013 | Philips Magnavox 9P6034C 60" Rear...
I have a cable running from my set top box to another tv. Although i have a good picture there is not enough volume on the sound. It has worked perfectly well until I had to dismantle everything . I have a...
This is not how you explain your problems to others. It should be precise. In this case, you could have said that you connected the cable between the RF out put of set-top box and RF input TV. Or Audio/video output of set-top box to Audio/video input of the TV. Also you did not mention, to which port you had connected the Vedeo recorder and DVD which are working good. Now, it may the volume level of the set-top box at low level which you can try to increase by using the remote control
If you could not sort out the problem explain how you had 'dismantled everything'
Apr 12, 2011 | Sharp 25N-M100 25" TV
I am trying to connect my mp3 player to my Vizio VX42L
In most cases the TV's have a "video mute" feature that will block the audio until the set detects a video signal in the corresponding video port. You either have to have a way to turn the video mute off or run a video signal into the video input that corralates with the input you are wanting to connect your mp3 palyer to.
Jun 29, 2010 | Vizio P2 42 in. HD-Ready Plasma Television
Sony STR-DE925 auto-decode has worked fine for years. All DVD/PS3/Cable is attached to TV via HDMI and inbound audio from HDTV is optical fiber (TOSLINK). Up until today, this has worked perfectly, i.e.,...
OK, so with more troubleshooting, I was able to eliminate the problem with my DE925. It was actually the Vizio HDTV that was causing the problem, as I decided to route the optical audio from my DVD and PS3 directly to the same TOSLINK port on the DE925 and auto-decode worked. It was not the fiber-op cables either. This HDTV was a less-expensive 720p 32" model anyway, so I am not too concerned with the optical out working on it as I can run up to four TOSLINK connections in to the receiver.
Jan 02, 2010 | Sony STR-DE925
Vizio VX37L 37'' LCD HDTV Television not turning on
Unplug set and hold and press the power button for about a minute. Replug set and turn it on. If nada, then the issue is with the power supply of the set. Given its age and the high cost of repairs it might be more cost effective to get a new set.
May 03, 2017 | Vizio L37 Television
Lcd tv
If it is a 42", then it IS worth repairing. Vizio will send someone to do it for you, and it will only take 30-60 minutes. There are THOUSANDS of Vizio repair techs around the country, due to the repair company's procedures. Give it a try....
Jun 26, 2008 | Vizio 42 in. LCD TV
Video works when playing DVD, but not with Dish signal.
I have the same problem.I turned it off for 5 minutes then turned it on and off a few times.
And I hit it to, not recomended
Jan 18, 2008 | Sony KV-27S42 27" TV
Vizio GV42L LCD TV screen black when turn TV on first time
If you are using a set top box this might be caused by turnig the box on at the same tie as you turn the tv on or slightly after you turn the tv on.  If you are using compnent or HDMI inputs the set needs to see the signal as it is turned on to know what formt the signal is in.
Oct 15, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio P42HD Television Logo
148 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
