Question about Dryers
Dryer not heating up
Dryer is tumbling and blowing properly but it isn't heating up which sounds like the element
  • 77 Answers
It does sound like the element BUT it also could be it could be your vent is kinked or clogged. If it is not heating at all, it may be an overload, or thermal fuse.
Posted on Apr 13, 2009
My indesit is70c tumble dryer is just blowing cold air,
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 07, 2010 | Indesit Dryers
Dryer wont heat blows cold air
There's no heat If your dryer doesn't heat, check these: Power from the house Heating element Thermal fuse Wiring Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Jan 02, 2010 | Roper Dryers
My frigid air dryer turns on and tumbles but will not heat up. We are doing renos and the duct(ing) is not connected to the dryer vent. Is that the cause? thanks.
No probably not the reason for not heating, what comes to mind first is check for proper 220/240 voltage is getting to the dryer, a dryer will run and seem to operate normally evn with getting only 110/115 volts but that is not enough power to energize the heating element to heat the air blowing into the dryer,or you may have a failed dryer heating element. Good luck !
Nov 30, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
My dyer heats and tumbles, but doesn't dry
I'd check first for clogged vent hose or clogged lint filter or clogged vent flap on wall (outside).
If that's not a problem, it may be a faulty thermostat. Heating element is probably okay if it heats some of the time.
More info, let me know.
Charlie
Oct 01, 2009 | Kenmore Dryers
Dryer won't heat. I just replaced the felt seals on the drum, the door switch didn't work but after I unplugged it & reconnected it worked. Could it be the doorswitch? I replaced the high temp switch a...
A tumble dryer that isn't heating up at all needs checking with a continuity test meter. The most common cause is a heating element failure, or t.o.c's going open circuit. It depends on which make and model of tumble dryer you have as to how easy it is to get to the relevant parts. Some tumble dryers have heating elements that are easily accessible by removing the back panel, and can be tested for continuity or checked for obvious breakage. Others though have their heating elements inside, which aren't accessible without stripping the dryer down. Tumble dryer heating elements are always protected by thermal fuses which are usually simple devices with 2 wires connected. They can be tested for continuity with a test meter
or
If power is getting to the tumble dryer and the socket is definitely OK, then the most common problem with tumble dryers not working is when the door micro switch fails, or the catch on the door that operates the switch either breaks or no longer activates the door switch. Check for broken door catches. There is usually a plastic peg on the door that pushes through a hole in the tumble dryer's casing where the door catch is. Closing the door should operate a simple micro switch. If the plastic peg is broken or bent it might not operate the switch properly
Jul 19, 2009 | Hotpoint NVL333GY Gas Dryer
Kenmore heavy duty. its working properly but not heat
Power from the house:
Heating element:
Thermal fuse:
Wiring : A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
thanks and keep updated.
Jul 08, 2009 | Kenmore Dryers
The tumble dryer is work but is only blowing cold air
sounds like a heating element. not to hard. remove the back and its is right there.
Jun 07, 2009 | Zanussi TC7102W Electric Dryer
Dryer not heating...tumbles and blows OK - is 2 30 amp fuses enough
ELEMENT IS BAD NEED TO HAVE A SERVICE TECH REPLACE THE HEATING ELEMENT
May 29, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Dryers Logo
56 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
