Question about WEIDERFITNESS.COM Weider Platinum Plus
Weider platinum xp800 does not work
Computer system seems to work.weight system is locked on full weight compacity
  • lwolfe57 Apr 13, 2009
    how do i get the an answer to my problem?
  • 3 Answers
There is a wire that breaks that is located inside of the pivot arm that hooks to the limit switch. (If you take off the back look on the RIGHT side of the machine.) When that breaks, the weight will not adjust.
I extended and rerouted my wires to run on the outside of the arm instead of the inside where they get nicked or broken by the moving parts.
Posted on Aug 20, 2010
When turned on and increasing the weight, the digital numbers increase, but the weight doen't change.
Posted on Feb 21, 2010
I will sell you the board off mine. email me at hangitmerm125@hotmail.com
Posted on Nov 16, 2009
4 Suggested Answers
SOURCE: I have a Weider Platinum XP800 Crossbow that will not start.
I had the same problem. Take off the black box at the base and check to see if any of the wires broke lose from the connectors, mine did. One pair of wires was alot shorter than the rest, so when the previous owner disassembled the crossbow he lifted the unit too far before disconnecting the wire connectors thus braking the two wires from the connector. Simply remove the remaining wire bits from the connector with something sharp (unplug machine from the wall). Then take the broken wires and push them down into the connector terminals with a butter knife. The terminals will cut through the wire insulation and make a contact with the wire. Problem solved.
Posted on Sep 02, 2009
  • 3 Answers
SOURCE: My Weider XP800 will increase in resistance but will not decrease
There is a wire that Breaks that is attached to a limit switch that is located inside the elbow of the Pivot arm. If looking from the Back of the Machine, it is on the RIGHT side. I extended the wire an rerouted it to run on the outside of the pivot arm to avoid be nicked or pinced by the moving parts.
SOURCE: weider platinum xp800 gets locked in maximum weight position
open the housing in back of unit and manually turn the bar (top left)next to pulley motor until the resistance bar is all the way to the right or in the lowest wieght setting. make sure to put the weight on the console to 10lbs. now plug unit in and press and hold the next button and the + on the wieght selector for five seconds then press the + again on weight then next one more time and this will recalibrate the machine, unplug and plug back in and ur ready to go.
Posted on Oct 23, 2011
Weider Platinum xp600 won't change weight
I just finished fixing this exact problem on my XP600. I also could increase the weight, but not lower it. Both wires (grey and orange) were cut from the lower limit switch (it's in the upper right corner). The way the harness was jammed into the unit, it broke the wires. The limit switch fell apart as I was taking it out, so I soldered the grey (there's two) and the orange wires together. The display now works properly. Because the switch is now bypassed, I just have to be careful and not drop the weight past 15/20 lbs. If you raised the weight when the display wasn't reading right, it will reset once you increase the weight to the max. Then you can decrease and it will read the right weight.
Jan 05, 2014 | Weider PLATINUM XP600 Console
Replace internal cable weider platinum xp 800
This is a tricky job.
I do suggest calling a professional.
Because if you have to ask then explaining is very hard to do
Nov 30, 2013 | Weider PLATINUM XP800 Console
Weider platinum xp800 gets locked in maximum weight position
Aug 09, 2009 | WEIDERFITNESS.COM Weider Platinum Plus
Jun 14, 2009 | WEIDERFITNESS.COM Weider Platinum Plus
Weider Platinum Home Gym - Cable Motor Stopped and Controls Blink
My son received an old Weider 8515 weight machine from a relative. The cable was worn and broke. Where would I find a replacement cable?
May 19, 2009 | WEIDERFITNESS.COM Weider Platinum Plus
Apr 27, 2009 | WEIDERFITNESS.COM Weider Platinum Plus
WEIDERFITNESS.COM Weider Platinum Plus Logo
2,022 people viewed this question
Top WEIDERFITNESS.COM Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you a WEIDERFITNESS.COM Exercise and Fitnes Expert? Answer questions, earn points and help others
