SOURCE: Royal 10X confetti shredder
More than likely, there is a lot of paper debris jammed between the cutters and strippers. If you are handy, try the following.
Disconnect the power.
Disassemble the shredder from the lower bin to access the cutting head. Clear the head of all debris with a small screw driver or ice pick. Reassemble and oil the cutters with shredder oil, being careful not to get any oil on the optics. This should solve the sluggish problem. Oil on a regular basis, before every use.
SOURCE: Royal 10x Crosscut Paper Shredder (PCUA: 29054E) paper jams.
Try soaking the cutters with soapy water, yes it works. Oil after you are done.
SOURCE: Replacement gear for Royal PX100MX shredder
For replacement parts call Royal at 1-800-524-0799; they should be able to help.
SOURCE: I own a Royal RL170MX shredder. I turn on the
If the blades rotate then the paper should go in...just be sure the blades are turning in the forward direction and not in reverse.Also make sure you lubricate the blades with shredder oil.
SOURCE: how do you empty royal 10x shredder?
Remove the waste bin from the front and empty.
If you have it jammed so full the bin wont come out I have heard people say that they got the bin out when they turned the machine upside-down....be aware this might make a mess.
