Panasonic Viewfinder - Mirror image: Although I don't own a Panasonic, my Samsung and JVC camcorders have this flipped image function, so I guess most are similar in theory. The mirror image is a function used for taking selfies, or where you want the subject to frame themselves while previewing the image on-screen. This only affects the viewfinder screen, not the saved video or still, which remains as normal. To correct this, you need to navigate to the 'settings' menu, exact location depending flavor of camera. There should be an option for "self-portrait" mode or similar. Switch this back to normal mode. Why mirrored? When screen is rotated 180 degrees to face subject in normal mode, they would see an inverted image, so the "selfie" function flips the graphic to compensate. Regards, Clive.
i have replaced the screen on my N96, but when everything is back together, the screen image is back to front, like a mirror image. How do i fix that problem??
Go to Start printers and faxes. Right click on Hp printer. Go to properties. Go to advanced. Open the printing defaults tab.Open advanced tab.Look for Printer Features : Mirror Image. Set this to no
This should correct your problem.
Hope this helps
Please leave feedback
You have probably got the Preferences set to "Mirror Image".
Next time you go to print something, click on Properties or Preferences when the Print window comes up.
Click on the Advanced tab. Look for Mirror Image. It should say Off. If it is ON, click on the word "On" and a drop-down menu will appear to select Off. Then click OK at the bottom.
You can then cancel the print job, or go ahead and print it out to verify that the printing is OK.
Mirror Image is used mainly for T-shirt iron-on transfer images.
I would have said
Gotta be setting in your print dialogue box, but if the test page comes out as mirror image, must be a setting on printer control somewhere
You need to TURN ON MIRRORING. Then everything displays the same on the computer & projector. This is an iPhoto limitation, which utilizes only 1 screen, not 2.
The setting is in the Menu. It sounds like you went to the "Image" section which lets you make the adjustments you list. Try the "Source" menu, then "Mirror". That's where you will find options for Rear Screen Projection, which makes the image backwards.
