Question about Panasonic Workio DP-3530 Copier
Panasonic DP 3530 printer keeps saying Machine error E03-40
What is this and how do I fix it?
  • 1 more comment
  • Chris Coughlin
    Chris Coughlin May 11, 2010
    Your question is cut off. Please reside you question a different way.
  • atta muhammad
    atta muhammad Jun 17, 2017
  • atta muhammad
    Problem Solver:
  • 19 Answers
E3-40 is the copy density sensor on the drum unit. Toner is probably dropping from the drum unit onto it. You have to remove the drum to access the sensor.
Posted on Jul 19, 2009
When the machine start error E03-40 came give solution for the problem
That has to do with the copy density sensor located in the drum module. The sensor could be dirty or defective, The SPC pcb could be bad. I've also had a broken drum drive gear cause this. Try setting F5-25 to off.
Jun 28, 2011 | Panasonic Workio DP-3530 Copier
Calibration for 8060 touch panel
Press and hold down energy saver button and function button together then power on the machine. keep on holding the two buttons the machine will once show screen calibration marker then again show the calibration markers now touch the shown marker it will go to a new place keep on touching the final marker will be at center of screen . after touching it the calibration completes
May 05, 2011 | Panasonic Workio DP-3530 Copier
We have a panasonic dp 3530 copier and no turn on, we check the main swtich in the back side of the machine.
1.do you have power?
2. remove the screws of the back panel and check the fuses.
3.see optical or with instrument near the 10k white _brick_ for blown up components.
3. there is no communication between main board +-5 +-12 and the power module.
Dec 01, 2010 | Panasonic Workio DP-3530 Copier
Panasonic DP-3530 I need a driver for it
You can download the latestdriver from Panasonic Support at the following link
http://panasonic.net/pcc/support/mfp/dp-6030/index.html
Sep 24, 2009 | Panasonic Workio DP-3530 Copier
FAX card
http://www.abetco.com/pdf/Panasonic/3530.pdf
Check the Yellow Pages for a Panasonic Dealer near you.
Sep 08, 2009 | Panasonic Workio DP-3530 Copier
DP 3530 error code E04-02
Hello sir; You have to look at heating unit you havv paper jam over there!
Aug 23, 2009 | Panasonic Workio DP-3530 Copier
Where is the waste toner container???
Remove right rear cover. Bottle sits along back of machine. These are rated for 240k and are replaced at your Preventaive Maintenance service.
Aug 06, 2009 | Panasonic Workio DP-3530 Copier
Where's the fuser unit on a Panasonic DP 3000
Hello sir;Cleaning the fuser unit not thing to do with the error code E4-01, but there is the way to reset just followinf the steps;
1, press and hold down following 3 keys by order "function", "original size", "3".
2, enter 9, press print,enter 04 press print.
3, press following two keys at same time "function", "'clear".
May 16, 2009 | Panasonic Workio DP-3530 Copier
Panasonic workio DP-3530 error code E01-20
e1-20 means " laser unit horizontal problem" its ether your lsu is not connected or defection or you spc board is not connected or defective.
good luck
Nov 19, 2008 | Panasonic Workio DP-3530 Copier
E03-40 error code
panasonic dp-4520 copier. e4-02 error code
Jun 19, 2008 | Panasonic Workio DP-3520 Copier
Panasonic Workio DP-3530 Copier Logo
889 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
