Question about Brother MFC-9440CN Laser Printer
No paper in traY
I LOAD PAPER IN THE TRAY AND IT STILL GIVES THAT ERROR. I HAVE SHUT IT OFF AND RESTARTED IT SEVERAL TIMES. THIS IS A mfc 8860 PRINTER/COPIER/FAX
  • 526 Answers
Make sure the tray is set for letter size, many times the handle moves and the settings on the tray change, so the paper moves back to the settings of legal paper, so when the printer tries to load paper, it cant.
Posted on Apr 15, 2009
Printer makes a horrible sound when trying to print also the blue button on the right side making a loud clicking noise. the paper won't feed.8860 dn
I have had the exact same problem. The problem is in the tray. It won't raise the paper properly despite how much paper you have in it. Make sure that all of the springs are there, and that the plastic sensors are correct.
I've found it useful to just buy another tray. You can find it as low as $30-35.
It's a very typical mechanical problem, but most likely resolved by changing the tray.
Apr 01, 2011 | Brother MFC-8860DN Printer
Brother mfc-8480dn no paper error I have a new brother laser printer and it is telling me there is "No Paper" but the paper tray has paper. I have tried removing the paper and reloading the tray...
Open the file you are trying to print, go to "file", "page setup", "Paper" and choose "Default tray" under paper source. It may give you an error message that the margins are outside of the paper. Click on "Fix this", then you can print. I had the same problem.
Jan 12, 2011 | Brother MFC-8860DN Printer
I am having a problem with the paper tray for Brother MFC 8860 dn printer - The paper tray clicks when it is printing a page and then says there is no paper in the paper tray or that a page is jammed -...
The paper is not feeding from the paper tray. The loud click is alarming, but not the problem. Check the adjustments in the paper tray. The left and right guides should be snug, but the rear guide should give between a 1/16 inch and a 1/8 inch of free play. If the rear guide is tight, that is the problem. You can check for this by depressing the lever on the right front of the tray. Depressing the lever should raise the stack of paper out of the tray so that it can slide forward.
If you remove the paper from the tray, but will see calibration marks for the paper size you are using. Unlock the read paper guide n the tray, squeeze the release and move the guide ot the mark for the size paper you are using. For example, it you are using letter size paper, the read guide should point to "LTR".
Oct 13, 2010 | Brother MFC-8860DN Printer
Our mfc5460 brother printer is giving the error message "print unable 30" and "print unable 50" alternately. WE had a paper jam, removed everything we could see from top and back, and are now stuck. We...
  • Remove the input paper tray and take off the output tray. Remove all loose paper from the input tray.
  • Step 2Pull out the paper support flap and unfold it to its greatest length.
  • Step 3Flip through the stack of paper before inserting it back into the input tray. Place the paper in the tray and adjust the paper guides so they press against the margins of the paper.
  • Step 4Ensure that the stack of paper is below the maximum paper line on the inside of the input tray. Unplug the power cord from the back of the printer.
  • Aug 09, 2010 | Brother MFC-5460CN All-In-One InkJet...
    Brother MFC 8860: Display reads
    I have exactly the same problem with my Brother 1250 mono laser printer.
    Any solution yet?
    May 11, 2010 | Brother MFC-8860DN Printer
    I have an error message, Brother MFC-8640D Printer
    NO PAPER MP
    Load paper into the Multipurpose (MP) Tray There is no paper on the Multi-purpose tray. Load paper onto the Multi-purpose tray.
    http://welcome.solutions.brother.com/BSC/public/eu/eu_ot/en/faq/faq/000000/002100/000073/faq002173_005.html?reg=eu&c=eu_ot&lang=en&prod=hl3260n_all
    Thanks
    Jan 15, 2010 | Brother MFC-8640D Printer
    Problems printing to Brother MFC 8660DN printer
    Pull the paper tray, likley a small black lever to the left of the roller called the edge actuator is dislodged and hanging down. When in position the actuator should easily push up and appear flat next to the roller.
    Dec 09, 2009 | Brother MFC-8660DN All-In-One Laser...
    Paper Tray #1 error message
    on your control panel, press "menu/set" "7" then "2". if your page count shows 288,888, you have a bad engine controller board. anything other than that count, most likely is a damaged paper cassette. there is a tab on front left side that is probably worn or broke off.
    hth,
    razors
    Feb 09, 2009 | Brother MFC-9420CN All-In-One Laser...
    MFC-8860DN
    This is a common issue.
    Here is the solution:
    Pull out the paper tray
    On the left of the feed roller there is a black piece of plastic that is a sensor. It is jammed forward. Gently bend it out to the left and push it back until it snaps back into place.
    Be careful not to break it.
    Oct 27, 2008 | Brother MFC-8860DN All-In-One Laser...
    Brother MFC-9440CN Laser Printer Logo
    390 people viewed this question
    CheckitRight
    CheckitRight
    James Cagle
    James Cagle
    Samyfam
    Samyfam
