Low to poor sound out of turntable
My brother owns an L 431 JVC direct drive turntable. We recently replaced the stylus as it was broken after a loan out to one of his friends. Problem: In order to hear any sound from the records, the receiver has to be cranked way up and then the sound is muted and soft. Continuity checks were done on the unit to unit cable and it is ok. Possible resolutions? Suggestions?
  • 104 Answers
This problem is almost 1 of two things
A) the new stylus is not seated perfectly into the body of the cartridge. if you suspect this, email pics to turntableneedles (the at sign) comcast.net before pushing too hard on anything.
B) if the setup changed you might need a preamp to boost the signal if it is not hooked up to the phono input on the receiver.
Posted on Apr 17, 2009
Turntable not rotating. What should I do?
HI, lift the platter off and check belt. If it is broken or stretched you will need to replace it. To test belt for over stretch simply place it on the platter pulley then flip platter over the right way up. If belt stays put it is ok, if it falls off it needs replacing. Keep em spinnin, John Stylus City.
Jun 20, 2014 | JVC AL A158BK Turntable
Playing records too slowly
It's likely that the belt has moved off where it should be. If the stylus was damage it would slide across the record or cause poor sound. It would not affect the speed unless there was too much pressure on the stylus, but you would feel that as the head of the arm would feel heavy.
May 24, 2013 | Crosley Conductor CR73 Turntable
JVC auto return turntABLE - mODEL al-a95bk
when you said "no sound enough to enjoy listening" did you mean that you could hear something coming thru the speakers, but it isn't loud enough? if so, you may be plugging the turntable into a "ceramic" phono input on your stereo. it may be that your stereo doesn't have a pre-amplifier on the phono inputs. Ceramic tonearm cartridges (the part that holds the stylus - which you may call the needle) have enough output level to drive an amplifier. if your cartridge is magnetic, the output is very low compared o the ceramic. the trade off is that magnetic cartridges have a much wider dynamic range than the ceramic, and when properly pre-amplified, sound MUCH better than a ceramic unit. you can probably find a separate pre-amp at radio shack (i know they sold them several years ago). you plug the turntable into the inputs of the pre-amp, then plug the pre-amps output into your stereo. hope this helps.
Dec 19, 2011 | Audio Players & Recorders
I have JVC L-FX2 fully automatic direct drive turntable.I need a needle.It was broken...how can i find it?please help...
if your looking for a needle. any music store should have them for you, even old record shops
May 08, 2011 | JVC Audio Players & Recorders
I replaced the stylus with needle and now when i try to play a record, it makes a terrible crackling noise and the record sounds completely blown out. just bought a new tuner preamp too, so its probably...
Unplug everthing. Reseat all connectors, Did you replace the cartridge when you replaced the stylus? If so, verify that the 4 tiny tiny wires and connectors are on tight. Also, some of these turntables have a 'knob' built into the tonearm that you need to twist to release/lock the whole head assembly of the tone arm. Try to see if you have a removable tonearm cartridge assembly and then twist this tight. It sound like its in the wiring from the cartridge to the connectors to your preamp. The levels are so low, that any loose connection will be amplified 100 times.
Aug 10, 2010 | Sony PS-LX300USB Turntable
Well im not too sure if my needle is broken but when i play a record i cannot hear sound and it sounds like my record is being scratched. Do i need to keep the white cap on the needle or not? or is it just...
It's called a stylus. What red or white caps are we talking about? Some phono cartridges come with stylus guards that flip up out of the way for play or down to protect the stylus from damage while in storage or during tonearm balancing. The stylus needs to touch the record groove directly.
Jul 14, 2010 | Numark ttUSB Turntable
Very low sound comming out pioneer pl300
Hi Jack.
Just confirm that it is plugged into a PHONO input (designed for turntables) Cannot use AUX/TAPE etc type inputs. If not, you will need an RIAA preamp from local electronics/Audio store. If that is OK, then try replace stylus first and the cartridge (may be just easier to do both same time). No volume control in turntables and it can only be 3 things (generally) Input, stylus, cartridge
Best of luck
Jul 24, 2009 | Audio Players & Recorders
Old Philips turntable 312 No sound
I am in a similar situation. I recently discovered that exact model turntable in our storage room. The Philips 312. While looking it over, I noticed the stylus is broken. I was wondering where you purchased yours?
Mar 27, 2009 | Philips Audio Players & Recorders
Poor quality sound
Double check all your cables. The only 2 things that affect sound on the 1200s is the RCA cables and the tonearm. I would first replace the RCA cables to a better quality set.
- OPTiC
Technics Repair Videos
Technics Turntable Repair
DJ Equipment Sales
Technics Parts Sales
Jan 16, 2009 | Technics SL-1210 Turntable
Poor sound output
One of the wires from the stylus had a poor connection through the pin connector.
I recrimped the pin lug reconnected and all is now working as it should.
Jan 01, 2009 | Ortofon Stylus DJE Turntable
242 people viewed this question
 Grubhead
Grubhead
