Question about Adobe Photoshop CS2 for PC
Layers I want to make change in a common thing in repetive 15 layers, any single command which can be used to remove the common thing.
    Sergeant:
    Champion:
  • 293 Answers
Use the macro option (action). It has its own window record your action by editing one layer then play that on all layers.
Posted on Sep 13, 2007
6ya staff
SOURCE:
Whats a dual layer disc mean then?
A dual layer disc is a DVD which is able to hold double the info.( http://en.wikipedia.org/wiki/DVD#Dual-layer_recording )
Dual-layer recording (sometimes also known as double-layer recording) allows DVD-R and DVD+R discs to store significantly more data-up to 8.54 gigabytes per disc, compared with 4.7 gigabytes for single-layer discs. Along with this, DVD-DLs have slower write speeds as compared to ordinary DVDs and when played on a DVD player a slight transition can sometimes be seen between the layers. DVD-R DL was developed for the DVD Forum by Pioneer Corporation; DVD+R DL was developed for the DVD+RW Alliance by Philips and Mitsubishi Kagaku Media (MKM).[23]
A dual-layer disc differs from its usual DVD counterpart by employing a second physical layer within the disc itself. The drive with dual-layer capability accesses the second layer by shining the laser through the first semitransparent layer. In some DVD players, the layer change can exhibit a noticeable pause, up to several seconds.[24] This caused some viewers to worry that their dual-layer discs were damaged or defective, with the end result that studios began listing a standard message explaining the dual-layer pausing effect on all dual-layer disc packaging.
DVD recordable discs supporting this technology are backward-compatible with some existing DVD players and DVD-ROM drives.[23] Many current DVD recorders support dual-layer technology, and the price is now comparable to that of single-layer drives, although the blank media remain more expensive. The recording speeds reached by dual-layer media are still well below those of single-layer media.
There are two modes for dual-layer orientation. With Parallel Track Path (PTP), used on DVD-ROM, both layers start at the inside diameter (ID) and end at the outside diameter (OD) with the lead-out. With Opposite Track Path (OTP), used on many Digital Video Discs, the lower layer starts at the ID and the upper layer starts at the OD, where the other layer ends; they share one lead-in and one lead-out.
Jun 16, 2011 | Nintendo Wii Console
I may have a virus but usually it waits until when i listen to my windows media player & within 10 or 15 mins after my pc makes a weird repetative thud noise (like a virus) and im forced to hold down...
Follow the given steps to remove virus from your PC:
1. Keep your antivirus program up to date.
2. Turn off System Restore.
3. Use an online scanner.
4. Use the Malicious Software Removal Tool.
5. Manually remove viruses.
The first step is to identify the virus. Run your antivirus software to identify the name of the virus. If you don't have an antivirus program, or if your program does not detect the virus, you can still identify the virus by looking for clues about how it behaves. Write down the text in any messages displayed by the virus or, if you received the virus in e?mail, write down the subject line or name of the file attached to the message. Search the antivirus vendor's website for references to those specific things you wrote down to try to find the name of the virus and instructions for how to remove it.
Dec 29, 2010 | HP Mini Notebook
What does "multi layer support" mean. Does it write multi layer discs? or is it able only to read them? Also, what is a lightscribe?
Multi-Layer support means the drive can Read/Write a Dual-Layer discs.
Lightscribe means you can create a label on a disk.
Check these Links fro more information:
http://en.wikipedia.org/wiki/LightScribe
http://www.lightscribe.com/gettingstarted/index.aspx
Good Luck!!!!!!!!!!!!!!
Sep 18, 2009 | HP Pavilion dv1000 Notebook
How to burn dual layer dvd with windows dvd maker only 150 minutes pie showing
Everything is the same except you have to choose "DVD-R 9.0G" at the bottom of the DVD maker window. R4.5G is single layer and 9.0G is dual layer.
Let me know if you need more help,
Sai.
Apr 02, 2009 | ASUS P5GZ-MX Motherboard
Dvd recorder funai
I have fixed mine with the same problem , all it needed was the lens cleaned , i used a laser lens cleaning disc from maplin for 6.99 and voila good as new.
May 09, 2008 | Funai PY90DG DVD Recorder
Hdd disk problem
U SHOULD USE DISK MANAGER SOFTWARE
Dec 24, 2007 | Samsung Spinpoint MP0402H 40 GB Hard Drive
Office jet g85
Power on the printer, wait around 15 seconds until the bulb assembly moves a bit to the left and the light goes on, then immediately power off.
Repeat the process around 15 times (or more) until the assembly has moved all the way to the left of the glass, and is located directly beneath the small glass on the left.
Remove the single screw that holds down the small glass.
Carefully remove the grey frame around the small glass.
Carefully remove the small glass.
Using a dry Q-tip, carefully insert it into the slot (to the left of the bulb) and clean the mirror. I found mine was coated with a layer of film, as if grease had accumulated over time.
Put everything back together.
Turn on the printer.
Dec 17, 2007 | HP OfficeJet G85 All-In-One InkJet Printer
Failed to record
Need to connect both the 3-prong AV adapter *and* the firewire cord. The firewire connect alone does not work, and the 3-prong AV cord alone does not work. But connect both cords to the two devices, and it seems to work. 15 minutes and counting... Hope this helps someone.
Aug 13, 2007 | Sony DVDirect VRD-MC3 DVD Recorder
Adobe Photoshop CS2 for PC Logo
61 people viewed this question
Top Adobe Computers & Internet Experts
Peter Dragonetti
Ekse
Alun Cox
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
