Question about Dell Computer Refurbished SYSTEM BOARD - OPT GX280 SFF FOR OPTIPLEX GX280 SFF Computer (H5354) Motherboard
What cpu will it except
What cpu will a m9475 dell mobo except 570/571???
  • 51 Answers
The M9475 board came on the GX280 amongst other Dell models. This is socket LGA775
Posted on Apr 14, 2009
My grand daughter has a Dell Optiplex 620 that stopped working. Pushing the power-on button does nothing, no lights anywhere except for the yellow aux. power light. When I connect the power supply plug...
When powering on the PC and you get no beeps, but you are getting power to the fans and hard drives, this may indicate either a bad power supply or bad memory. You can take the machine into a pc repair shop and have them test the memory and PSU for you.
Oct 14, 2013 | Computers & Internet
Dell inspiron 530 mobo problem
Yes - both MOBO are same form factor.
You will need to remove the backplate (that is the part that surrounds the ports) from the case.
You will need to insert the backplate for the new MOBO in the case.
The CPU and RAM should be direct swap.
Dec 27, 2011 | Dell Inspiron 530 Desktop Computer...
Ok i have a dell inspiron 530 with the g33m03 modo right now i have a intel pen deul core 1.6 what can i up grade too
Make sure that you have the correct mobo and not the g33m02 that dell ships with a duel core cpu's. If in fact you have the 03 model then you will need to upgrade your bios to the latest version from Dell and then you can go with a 45nm Quad core.
Again make sure you are running the correct mobo before you spend the money on the cpu and then cuss this post out that this guy said it will work when in fact the mobo does not support it.
Sep 21, 2010 | Intel Computers & Internet
Dell Dimension 3000, splashed liquid from canned air, mobo fried?
The spray on the MB should not be a problem - unless it was plugged in when you did it. Yes, you should be able to put in a new Dell motherboard. As long as the processor is of the same class, the Dell license should work fine. However, you may need to download new drivers for the machine to run.
If you really want to check the power supply, I would suggest you buy a tester. They are fairly cheap: $10-50. You want to be sure that your board is getting the right power at the right places. 12 V to the fan is fine. However, 3.3 v or 1.5 v?
It sounds like you have done a fairly good test of the motherboard. I've definitely seen bad Dell motherboards with the light on with/without a bad power supply.
If you have another case (an ATX), I would buy an Asus or other motherboard and put your equipment in it. The cost of a Dell motherboard is excessive. Of course, you will have license problems with XP.
May 22, 2010 | Dell (E210882) Motherboard
Building desktop: no beeps, no video The mobo LED are on, fan is running but getting no signal to monitor. I've tested the video card in another pc and confirmed working. The only time the mobo beeps...
If the cpu was bad- nothing would turn on--be sure the cable is good-- also be sure the VGA is enabled in the bios- since you cant see the video you have to reset the cmos setting--unplug the unit and remove the cmos battery-reinstall after one minute and check for video
Apr 10, 2010 | Intel Desktop Board D850MD Motherboard
Dell Inspirion 530. Will not turn on. I replaced the watch type battery and it came on. Went to use again and would not turn on.
check power cords. swap power cords from monitor to cpu. check the power supply if it is on. check cpu fan if spinning. check if power flea from mobo lit on. if all fails replace the power supply and mobo.
Nov 04, 2009 | Dell Inspiron 530 Desktop Computer
Dell 530 workstation cpu problem
go to gell .com and get the specs for your processor if yours is not compatible you will have to buy one but having the specs you will know which processor to buyy.
Dec 05, 2008 | Dell (2H882) Motherboard
Power failure.
www.newegg.com. It is an excellent wholesale parts ditributor.
Mar 16, 2008 | Dell Dimension 9150 (DIM915MIN) PC Desktop
New processor
Usually you can use Northwood-core CPU-s on mobos with Willamatte-core CPU. But is important (exept core) - FSB support of your new processor. Which model of your CPU? What the mainboard use (model)?
Nov 15, 2007 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Computers & Internet Logo
90 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
