Question about Hotpoint WMA46 Front Load Washer
Locating carbon brushes on a wma46 aqarious extra
Where and how do you locate the carbon brushes for replacement,i have the lid off but at a loss?
    Sergeant:
  • 436 Answers
The brushes at at either side of the motor, they will be about 4cm long with wires attached to them.
Posted on Jan 04, 2010
Sf160kjs keep shown c9 means I need to call someone to repair ?
According to post in Fixya posted in July 20 it relates to the motor not operating.
Post follows:
c9 means there is no motor movement, typically worn out motor carbon brushes.
You may need to replace the carbon brushed within the motor,.if that is the case
It may also be related to C8 The lid cannot be locked ? Is the lid closed? ? Are there any foreign objects in the lock? Check that the lid is completely closed. Check that there are no foreign objects in the lock.
Mar 02, 2017 | Washing Machines
Need brushes for a 111409-01 branch wizard
Remington Pole Saw Carbon Brushes
If you're Remington Pole Saw is slowing down, throwing sparks, overheating or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
Remington carbon brushes on E-bay Search for:
Remington Pole Saw 8 AMP Carbon Brush
May 03, 2014 | Remington Electric Chain Saw
Are brushes available for remington 106890-02
If you're Remington Pole Saw is slowing down, throwing sparks, or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
Nov 06, 2013 | Remington Electric Chain Saw
Rec'd a RYOBI 10" miter
I would remove the one already installed and take it to different dealers or large electrical suppliers to match it
Oct 02, 2017 | Ryobi Garden
Hi i have a viperpro 2000 watt chop saw and the brushes have got to the end of there life but i can not find any one who stocks or sells them my local tool shop has told me to throw it away as they do not...
locate brushes with the same wire/spring attachments and that are slightly bigger than your brushes. Carefully reduce their size on abrasive paper laid on a flat surface, often checking for fit. They should slide into the guides freely without any sideways play. Be careful, the carbon abrades very fast and it is easy to rub off one end more than the other, rounding the surface off or having the brush taper, which is not what you want
Jan 25, 2011 | Garden
Where are carbon brushes located inside Hoover Performa Plus PPA 146-80 and how easy is it to remove them and replace?
The carbon brushes are part of the drive motor , early machines had replaceable ones ,but on many modern machines they are not replaceable , it depends on which motor has been fitted . you need to know if / why they need replacing anyway before attempting same.
Nov 08, 2009 | Washing Machines
Washer won't do anything. was washing a large comforter and the washer stopped working in the middle of a spin cycle. water did drain. now won't turn back on...no noise or anything. fairly new washer only...
If there is any voltage on the power group, try it temporarily with another device, if there is a control light on the display and it burned then read this suggestion.#
Its written by Hitachi but its on all kind of brushes made by other brands to find .
Carbon brushes are one of the most commonly replaced power tool parts. This is because carbon brushes are wear items, meaning that through friction and use they will gradually wear away until they need replacing. Worn brushes are a common causes of intermittent motor function, reduced electric braking and reduced motor power. A worn-out brush will often be worn down near to the wire lead and can be cracked, pitted, or burned. When replacing carbon brushes, be sure to inspect your armature for burns, cracks, or other damage which can indicate larger motor problems. [ NOW COMES THE IMPORTANT THING what i suggest ]
This Brush will pop out a pin when the Brush wears to a certain length.
It is advised to keep an extra set of these brushes on hand at all times
Jun 30, 2017 | Maytag Washing Machines
Need to replace carbon brushes on Indesit Omega 1200
The brushes are located inside the motor. Remove rear panel of washer, remove drive belt, from motor and drum, unplug the motor, undo screws that secure motor, and remove motor.
At the opposite end to the motor pulley, you will find the brushes located, undo 2 screws that secure the brushes, remove and replace brushes.
I would also check the pump filter, which should be located behind a removable panel at bottom of washer, unscrew anti-clockwise, remove and clean.
Please rate my fixya solution.
Thanks.
Feb 01, 2009 | Indesit W 123 Front Load Washer
Hotpoint WMA46 Front Load Washer Logo
223 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
