Question about Canon PowerShot SD300 / IXUS 40 Digital Camera
Powershot SD300 wont appear on computer
Well, we were recently given a free camera, and it came with the connection, but not the disc. and when i try to load the pics on the comp, the comp wont recognize it or anything. it wont come out on scanners and cameras, and it wont pop out on anything either.
    President:
  • 2,961 Answers
Nothing on a sd300 but there is on a Ixus 40, see below for IXUS drivers and manuals http://software.canon-europe.com/products/0010105.asp
Posted on Sep 12, 2007
SOURCE:
Importing photos from Canon IXUS 40 to computer. It stops on the 9th picture & will not import any more !
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Oct 03, 2012 | Canon PowerShot SD300 / IXUS 40 Digital...
Transfering pictures from computer to Canon PowerShot SD300
If there is a SD card for your camera, you can do that easily by a card reader
Jan 04, 2011 | Canon PowerShot SD300 / IXUS 40 Digital...
Will sdhc memory card work in canon powershot sd300
SDHC will not work in cannon powershot sd300.. you can try using sd cards..
Nov 22, 2009 | Cameras
My canon sd300 will not turn on
I had the same problem, and finally I took it to a camera repair shop and they said it was time to get a new one.
Dec 17, 2008 | Canon PowerShot SD300 / IXUS 40 Digital...
PowerShot SD300 Flash Won't Charge
Hi
Yes its very possible that something was damaged during the repair. If you scratched a board you can break an electrical connection between two parts.
The thing to try first would be replacing the flash, look for a used one as it will be cheapest. If that doesnt work, then you have to replace the main PCB.
If you need parts, please let me know, its what we do.
Good luck from Darntoothysam com
Thomas
Sep 16, 2008 | Canon PowerShot SD300 / IXUS 40 Digital...
HELP!
Not sure if this will work, but connect the camera and using windows explorer, drag the photos to the camera. Its worth a try!
Jul 05, 2008 | Kodak EasyShare C330 Digital Camera
Camera will not turn on
Here are some simple things to try first for a camera that won't power on. They won't work for every case, but they're worth a try:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
Jun 03, 2008 | Canon PowerShot SD300 / IXUS 40 Digital...
Use as mass storage device
Connecting a camera to computer via a USB to download is one thing- Connecting a camera to Computer to feed back the the card is another. The chances are the firmware on the camera will not accept anything that is not in EXIF format. Try it -simply connect camera in the normal way. This will if you have the normal A C D drives will come up us removable storage -'E' with the appropriate icon in 'My computer' Now pick a file[s] and using the normal Edit/ Select/ Copy[Or right click] routine then go to the removable media['E?' right click paste See what you get- you wont break anything
Aug 25, 2007 | Canon PowerShot SD300 / IXUS 40 Digital...
Memory Card is locked up?
Hi Phatback, There should be a switch on the card, move it in the opposite direction. If this does not work, format it in your PC. Please let me know if this works. Best regards, nightdiver
May 30, 2006 | Canon PowerShot SD300 / IXUS 40 Digital...
Canon PowerShot SD300 / IXUS 40 Digital Camera Logo
76 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
