You should be able to reduce the size of print somewhere in your program rather than printing at 100%. Try to find where you can change to perhaps 95%. You will still be able to read the print. Experiment with the percentages and check the preview prior to printing. You may need to check the printer properties to find where you can change from 1oo%.
SOURCE: Epson LX-300+ Matrix Printer Problem
Please change the setting print direction from bidirection to unidirection.
SOURCE: epson lx 300 dot matrix printer not printing properly
Make sure you installed correct printer driver and choose the correct model .and remove the pending print job if it is there.
To clear all pending job
In run window type services.msc and the go to print spooler option just stop and restart the service. And switch off and switch on the printer.
Have a nice day and do not forget to rate please...!
SOURCE: i have 9 pin TVS dot matrix printer but i have
hi kravi
Install "Epson Compatible 9 pin" driver, you will get it. Thats all
