Question about Karcher K2.26 Electric Power Washer
The pump will not kick in and I have a water leak
The pump will not kick in and I have a major water leak from casing. Water pressure from the mains appears fine, but does not pressurise and a small amount just dribbles out of outlet. Furthermore, more water is pouring from the plastic venting area underneath the on/off switch. Internal filter is clear and seated ok. A little proding caused the outflow to cease completly but leak from casing contined. Would like to investigate myself but specilaist tools prevent me. Any advice welcome. Thanks Al Lancashire
  • 92 Answers
SOURCE: Karcher pressure washer won't start
Dear ralph_birtwi,
Most pressure washers when their gun is released, the machine stops automaticaly. This is done ny means of a control valve. When the gun is closed...pressure is built and the control valve moves and switches a micro switch off. In your case the micro switch is still closed in off position. Now this happens if a machine is left and stored with pressure in it., This control valve could get jammed and leaving the micro switch in off position. It could also stay in off position by sticking, due to incorrect chemical.
So the control valve or even called spill valve, must be renewed.
Sometimes a little lubrication with the right type of silicon grease will get the control valve working again. This job is sometimes delicate and better done by a qualified technician.
Regards,
fulltech.
Posted on Apr 12, 2009
  • 32 Answers
SOURCE: Craftsman 1800 psi pressure washer won't start
disconnect the hoses to and from the machine and the try it.
the machine might have a blocked nozzle in the lance, of so get a paper clip and clear the jet backwards
Posted on Jul 04, 2009
  • 92 Answers
SOURCE: Karcher 3.97M Short cycles after trigger is released.
Dear csdamman,
There is a valve called the spill-valve. It is often called the control valve. This valve activates the micro-switch. When the gun is released, pressure builds up and compresses this spill valve. At the same time it puts off the micro-switch. This will then stop the machine. Now when the spill valve is faulty it cannot hold compreesion under pressure so it starts de-compressing and starts the machine again. This goes on in a cycle as you explained. So you have to change the spill valve. If the spill valve that operates the micro-switch is part of the upper head,...then the whole head must be renewed. Myself I rarely service Spill Valves. The best thing is to renew it. From your explanation it seems that you did not take notice of this Spill-Valve. Infact when you mentioned Pressure Switch, I do not know if you are refering to the spill valve. If you are....then saying that the Pressure Switch moves and operates freely, does not mean that it is OK.
In certain machines in the outlet...there is a small valve, coloured black and red or green and yellow. This sometimes when faulty, it gives the fault you mentioned. Sometimes an inlet valve gives the fault you mentioned. But from my expirience it is most of the time that the Spill-Valve is the fault.
Regards,
Fulltech.
Posted on Jul 22, 2009
  • 548 Answers
SOURCE: I have a 3000 psi karcher pressure washer with
sounds like you need a seal and bladder rebuild < if you liver in a cold environmet for winters please dont forget to winterize your washres every year before winter
Posted on Sep 15, 2009
  • 68 Answers
SOURCE: Hi My karcher k3.65 jubilee is leaking water when
Hi This could be just the water inlet channel broken or split. You will need to remove the yellow cover via the screws at the back of the unit and then connect the water hose to see where the leak is coming from. If the water comes from underneath the pump then you will need a replacement pump seal kit of which you can purchase on the Internet.
Posted on Jun 11, 2010
ANTIFREEZE COMING OUT FRONT MAIN SEAL ON 2001 S10
If antifreeze is leaking out of your front main oil seal you would have to have the engine full of coolant which would mean a major gasket leak. I submit that coolant is running down the front side of the engine and then dripping off the oil seal. Probably from the water pump. Pressurize the cooling system to determine the exact cause of the fluid leak
Nov 03, 2013 | Chevrolet Vehicle Parts & Accessories
My neighbours saniflow toilet is drivng me mad. The motor keeps whirring every 5 mins. Whats the problem, please!
Water pressure is what makes the unit kick on and off. If its kicking on by itself most likely water is somehow draining back into the pump. Start by checking the flapper in the flush valve inside the toilet tank, it may be leaking water into the bowl and from the bowl into the pump. Also inspect the check valve inside the 90 degree elbow where the waste is pump out from. The check valve may not be closing properly and is allowing waste water to drain back into the pump creating water pressure making the unit kick on and off by itself.
Oct 07, 2011 | Saniflo SaniPlus-Round SaniPlus Macerator...
My Karcher KB 9030 has lost pressure and is hunting when no demand water supply is plenty
In most cases the water lines can have leaks that bring bring in air and so the pressure will be less. Power off the washer and let the water flow without any air bubbles. If you seen bubbles then recheck the joints.Check the same with the outlet.
If not there is fault on the main pressure pump.
May 02, 2011 | Karcher Garden
Hello, Our Flotec Shallow well Jet is installed in our basement a distance ( perhaps 50 feet or so from the well casing outside in the yard. The pump was installed as a replacement for a worn jet pump...
Hi, Tom, W/D here.
You shouldn't really need a check valve as the foot valve is in effect a check valve.
Next time that you are near the pump when it kicks on and you are using no water, let it achieve full pressure and kick off. Close the discharge valve, isolating the pump and suction line. Watch the pressure gauge. If the pressure falls, you either have a leak in the suction line, possibly a leak at the well head (sucking air), a leak in the casing riser pipe or bad foot valve.
If the pressure holds steady, open the discharge valve and note the pressure. If it falls immediately upon opening the valve, the leak would be on the house side if the pump. Look then for any sources of water usage (ice maker, drips in the tub, water from the pop-off valve at the water heater, etc.).
Best regards, and good luck.
If I can be of any further assistance, please post back.
--W/D--
Jan 22, 2011 | Flotec Corrosion Resistant Shallow Well...
My water pump kicks on every 30 min or so even if there is no water used
When a pump goes on and off there is a water leak somewhere.
There should be a gauge. Let the pump build up pressure and watch the gauge.
The pressure will probably be dropping. This means that water is going somewhere. The leak could be anywhere that you use water, sprinklers, sinks, hose lines. If there is a valve above or near the pump, shut that valve and see if the pressure stops dropping. If the pressure stays up and the pump stops cycling on and off, the leak in in the pressure piping somewhere, you must locate it and repair it.
If the pressure continues to drop even with the discharge valve shut, the water must be leaking back into the well. There is a check valve somewhere on your line between the well and the pump. If this check valve is leaking, pressure will drop and the pump will come on to restore it.
If it is possible to shut off the discharge of the pump, shut that valve and watch the pressure gauge to see if it is dropping.
Dec 12, 2010 | RTO Wayne 1/2 Hp Shallow Well Jet Pump
I have a saniplus toilet, the macerating unit runs about every 2 minutes for 1-2 seconds at a time. I'ver replaced the flapper and even turned off the water to the unit and stopped using it, but it keeps...
Water pressure makes the unit kick on and off. Water could be leaking from the toilet tank into the bowl and from bowl into the pump. Or the check valve inside the discharge elbow (on top of the lid) may not be sitting properly or is being obstructed causing waste water to leak inside the pump, creating enough water pressure to make the unit kick on and off by itself.
Sep 06, 2010 | Saniflo & Saniplus& Macerator Pump
Saniflow pump keeps comming on without flushing toilet
Water pressure makes the unit kick on and off. If it's turning on by itself then most likely somehow water is draining back into the pump. It could be leaking water from the toilet tank, to the bowl and from the bowl to the pump. Or the check valve inside the discharge elbow may not be closing all the way down and is allowing waste water to drain back into the pump creating enough water pressure that makes the pump kick on and off. Inspect the flapper on the flush valve and the check valve on the discharge elbow on top of the macerating pump.
Aug 22, 2010 | Saniflo 002/005/007 Saniplus Toilet with...
The saniflo keeps cutting in even when not flushed
Water pressure makes the unit kick on and off. It will turn on by itself if water is somehow draining back into the pump. It could be water leaking from the toilet tank into the bowl and from the bowl to the pump or the flapper on the check valve inside the discharge elbow may be stuck open or could be defective and allowing waste water to drain back into the pump, once it builds up enough water pressure inside the pump, the unit will kick on and off by itself.
Jul 14, 2010 | Saniflo & Saniplus& Macerator Pump
The pressure tank psi may be too high. To set it you get the system to pressure up and stop then check that water pressure. Whatever that is, is what the tank should be set at. Too much air pressure and the water pressure will suddenly drop before the pump kicks in.
To set the tank properly turn off the pump, drain all water pressure, then set the air pressure in the tank to the same as the water pressure was. Turn it back on and check again.
Apr 14, 2017 | Water Heaters
Karcher K2.26 Electric Power Washer Logo
344 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
