Question about Dishwashers
Dishes do not dry
Whirlpool Model# GU980SCGQ1 Does not dry the dishes, element "looks" OK.
    Sergeant:
  • 187 Answers
Hi..
Try these..
1.Check that you are using a regular machine cycle, not a short or special cycle. 2.There could be insufficient water fill or pressure. Run your dishwasher when other household demands for water are low (i.e.k, laundry or bathing). 3.This may be due to improper loading of dishes. Check that your large dishware doesn't block the detergent dispenser or water spray. Check your dishwasher manual for proper loading techniques. 4.You may have used too little detergents. Use Finish tabs for even dosing. 5.The spray arm may have been blocked, please ensure that the spray arm can rotate.
please rate my suggestion
Posted on Apr 14, 2009
Whirlpool dishwasher WDF510PAYS dishwasher isn't drying. We're using a rinse aid and it's on the max setting and we are using high heat dry. Dishes are still coming out wet. Any suggestions?
Check the heating element in the bottom of the unit for any signs its damaged. If looks OK, check its continuity, for a short to ground, and the voltage at the terminals.
Jul 29, 2014 | Whirlpool 24" Built In Dishwasher Energy...
Whirlpool dishwasher is not drying the dishes
sounds like your heating element is not working. It may be faulty.
May 01, 2012 | Whirlpool Dishwashers
Heating problem on dishwasher
Your dishwasher has an electrical heating element that helps to dry the dishes. If the element is burned out, the dishes won't dry properly, and you need to replace the element. To determine if the heating element is burned out, watch the part testing video at the bottom of this page.
Thanks
Apr 01, 2012 | Whirlpool ADP 8900 Dishwasher
Dishes are wet,,not drying!!!
sounds like the heater element needs replacing. I think the part is about 60 bucks for most of them--but ask a local shop or look online with your exact model number for an actual price.
Feb 28, 2011 | Whirlpool Dishwashers
I have a whirlpool Du810SWRQ0 dishwasher. Whwn we wash the dishes, it is ok until the drying process start. Then it has smoke from inside. So, we can not use heat dry anymore.
smoke from inside the dishwasher or the panel?
if smoke is from inside the dishwasher... firstly check that the element is clean? is there any evidence of melting on your lower basket shelf or cutlery basket? if so the thermostat or rhe heating element control may be faulty and will require repair. If its an old dishwasher, sometimes its just easier to bite the bullet and buy a new one.
Dec 17, 2010 | Whirlpool 24 in. DU810CWD Built-in...
Dishes are not dry anymore after cycle?
Hello there:
If` you ahve already checked all of the filters and they are ok than your drying cycle has problems to check these check these: Heating element Drying fan Thermostat Heating element Your dishwasher has an electrical heating element that helps to dry the dishes. If the element is burned out, the dishes won't dry properly, and you need to replace the element. Drying fan Many high-priced dishwashers have a small fan that blows air or heated air into the dishwasher to speed up the drying process. If the fan is defective, you need to replace it. Thermostat Some dishwashers have a thermostat that monitors the drying temperature. If the thermostat is defective, the heating element may not cycle on or off properly. If that's the problem, you need to replace the thermostat. there:
Normally if you have just started to have this problem and you have checked all of the filters and are sure they are ok than
Jul 06, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Heating element quit working on model # ler4624bw2 Whirlpool electric dryer
Hello there
Here is a couple of links that will help you replace the heating element along with some manufactures that can also help ok?
Best regardss michael
  1. Whirlpool Dryer Heating Element 279838 Kenmore | Estate ...unknown.gif ... REL4632DW0,LER6638DW0 LER4624BW2,LER7646AW2,KEYS677EZ0,REL4632DW1,LER6638DW1 ... Model: Whirlpool | Kenmore | Sears | Roper | Kitchen Aid | Estate. Shipping ...whirlpoolpartssurplus.com/cart/whirlpool-dryer-electric-h...
  1. How to Replace Your Electric Dryer's Heating Elementunknown.gif How to Replace Your Whirlpool, Kenmore, Roper, or Kitchenaid. Electric Dryer's Heating Element ... 3 styles of heating elements in use for these dryers. ...www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm - Cached
  2. How to Replace the Heating Element in A Whirlpool Dishwasherunknown.gif How to article - how to replace the heating element in a whirlpool dishwasher. When your dishwasher heating element goes bad, your dishes will not dry quickly. Before...ehow.com/how_5337380_replace-heating-element-whirlpool-di...
  3. How to Replace the Heating Element in A Whirlpool Ovenunknown.gif How to article - how to replace the heating element in a whirlpool oven. If the lower heating element in your Whirlpool oven no longer gets hot, or if you n
Oct 15, 2009 | Whirlpool Dryers
Whirlpool dishwasher is not fully drying dishes
Are you using jet dry or a similar drying agent? If not you should be. Also check to make sure the heater is getting hot in the dry cycle, just place your hand over the heating element to see if it's generating heat, don't touch it as it will burn you.
Feb 19, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
WHIRLPOOL QUIET PARTNER IV
Ok this can mean 2 things.
Pump or filter is clogged
or heater is not working correctly. Can you give the precise model number?
Aug 09, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
111 people viewed this question
Top Dishwashers Experts
Owen Barnes
