Question about HP Pavilion ZV5000, ZV6000, ZX5000 Series 12 Cell Li-Ion Battery - DP390A (DP390A1) CD-ROM Drive
My laptop constantly logs off shortly after logging on, why?
  • 600 Answers
Check your power settings ( sllep mode, hibernate etc) and uncheck the option to "go to logon screen on return"
Posted on Apr 13, 2009
After I log-on my computer the screen goes black?
I've had this problem before and it was a fault in the multicore cable from the screen to the motherboard caused by constantly closing the laptop. It drops out when a demand is put on the cable. simple fix for an engineer.
Aug 28, 2014 | Acer Computers & Internet
I recently have updated a app for Zedge.com. I went into it, and now i am constantly getting "The app HTC Sense stopped unexpectly". I force close it but nothing happens and its freezing up my...
Hi mistybates1,
Please install "Log Collector" from Market. Next time this happens, please start Log Collector immediately and send your log data to android@zedge.net. This way we may find out what's actually going on and hopefully fix it.
- Stig from Zedge
Jan 18, 2011 | HTC Cell Phones
My yahoo mail shortcut on my desktop takes me directly to my inbox. When I click on it I get a constantly flashing screen that goes from inbox to a blank screen, inbox blank screen at a rate of about 1...
You may have saved the short cut without the User Name and Password typed in your Yahoo Email Log On page. (And it's unable to log on).
Try creating a new short cut and make sure that info is included on the short cut icon.
Aug 18, 2010 | Yahoo Mail
How to plug in y = log?
if you want to graph the log of x, simply put Y1=log(x), it will show the basic logarhythmic function. "log" cannot stand by itself without a variable or constant after it
Apr 26, 2010 | Texas Instruments TI-83 Plus Calculator
How to use the log function for acidity constants? I get a syntax error
Let Ka be the acidity constant (acid dissociation constant). The pKa is defined as the negative of the log in base 10 of the acidity constant.
pKa= - log_10(Ka) where log_10 is the logarithm in base 10.
To calculate the pKa you use the key labeled [LOG], just above [COS]. Be careful with the negative sign: For that, you use the key [(-)] just above the RCL key. Press the keys in the order specified below
pKa = [(-)] [LOG] number [ ) ] [=]
Although the right parenthesis is not required in this particular case, it is better to accustom oneself to close the parenthesis.
Hope it helps.
Dec 07, 2009 | Casio FX-115ES Scientific Calculator
I cant login to my mail form my laptop I can login
Hello
Thank you for using FixYa for your problem
Looks like Yahoo is down again, try again shortly
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Dec 03, 2009 | Yahoo Mail
2log(base4)x + log(base4)3=log(base4)x-log(base4)2
It is easier to use the rules for logarithms to clean this equation before trying to solve it. And the calculator is no help here.
Let me represent the logs as follows log b in base a = log(a,b). The first argument is the base.
2*log(4,x) - log(4,3)= log(4,x)- log(4,2)
Here you have two similar terms 2*log(4,x) on the left and log(4,x) on the right. Gather them both on the same side, say the left. You have
2*log(4,x) -log(4,x) +log(4,3) = log(4,x)-log(4,x) -log(4,2)
which is equivalent to log(4,x) +log(4,3) = -log(4,2)
Gather the constant terms on the right, and use log(a) +log(b)=log(a*b)
log(4,x) = -log(4,2) -log(4,3) = - { log(4,2)+log(4,3)} = -log(4,2*3)
You get log(4,x)= -log(4,6).
Take the constant term to the left, while changing its sign in the process. On the right remains 0, which is also the log of 1 in any base So log(4,x)+log(4,6) =0 =log(4,1)
Use the rule log(a) +log(b) = log(a*b) valid in any base, to obtain
log(4,6x)=log(4,1) which is equivalent to 6x=1. The solution is x=1/6
There are a few other shortcuts to get the solution but I preferred to take a pedestrian, step by step, approach.
Hope it helps.
Nov 25, 2009 | Casio FX-300MS Calculator
Saving call log and text messages
You can't save your call log but to save text msgs. you press the blackberry button on the msg. u wanna save then scroll down to save.
BUT if all your msgs., call log and BB msg. are constantly getin deleted the try getting a new battery.
Oct 13, 2009 | RIM BlackBerry Curve 8310 Smartphone
Laptop shuts OFF on it's own
Laptop fans DO NOT run constantly. They only turn on when booted up and once the laptop has reached a certain temperature. You should probably time how long for a shutdown, record your results. Let laptop cool for 10-15 between attempts. If it takes approximately same amount of time to shutdown between attempts it is very possible its overheating.
Other things like Viruses, software conflicts, and Harddrive problems can also be the culprit. take a look at the administrator event logs for any clue there. Event logs are in control panel under Administrator Tools.
I don't recommend trying to fix any overheating issue you may have, as that would entaiil disassembling your laptop. Unless you have a bit of experience in this, I would take it to a good repair shop.
Hope this helps you some. If so please rate my solution.
May 10, 2009 | Dell (6F858) Cooling Fan
HP Pavilion ZV5000, ZV6000, ZX5000 Series 12 Cell Li-Ion Battery - DP390A (DP390A1) CD-ROM Drive Logo
85 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
