Question about RCA 32V524T TV
Bush LCD 2 will not switch on at all, no light at all.
  • RCA Master
  • 19,396 Answers
If the TV has no power at all, not even the led light on, and does not respond to remote or button, then the most common is a faulty power board inside the tv.
Posted on May 05, 2009
SOURCE:
How can i switch on my bush LCD TV without remote
There may be a power switch somewhere on your TV.
Jun 26, 2018 | Bush Televison & Video
Hi I am having problem with my tv bush model s642f while I am switching the tv on the red light keep flashing an it won't come on please help me thanks
It's possible it may be an error code. Depending on the number of blinks it will tell you what to look for when diagnosing the TV.
Feb 13, 2015 | Bush 42" LCD TV 1920x1080, 50 Hz, Freeview...
Bush led 26916hd
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/. If the blinks continues, and non-stop, the fault should be with its main system control IC, and with the memory IC.
Dec 13, 2013 | Bush LCD/ Plasma/ LED Pivot Mount in Black
Bush IDLCD26TV16HD blue flashing light?
It is on protection mode due to some defects on the board. Switch off the TV manually, remove the plug and cool it off for 48 hours and retry. If nothing works, better refer it to a qualified service technician.
Jul 18, 2012 | Bush Industries IDLCD26TV16HD LCD TV
The Power button on my Bush HD LCD Television is not staying on. It shuts off when switched on. What could be the problem please
There is some short circuit inside it. It might be due to component /s short, or IC damage. Seek tech support. This is skilled work.
Jun 05, 2012 | Bush Industries IDLCD26TV16HD LCD TV
I turn tv on then the standby light goes green then goes to red flashing
It is a common Fault on some lcd tvs you will need a replacement switch mechanism fitted don't know the correct name for it but it can be fixed .I had exactly the same problem with my BUSH 26 inch LCD tv took it to a local independent tv shop and the owner repaired it for me it cost around £67 if my memory is correct this fault started on my TV 14 month after i bought it - 2 month out of warranty. hope this response helps
Good Luck
Eddie Hall
Nov 27, 2010 | Televison & Video
Bush 26" hd ready digital LCD tv brought argos today have gone into menu to turn off subtitles but every time i change chanel there they are. I know by pressing to subtitle button i can get rid of them but...
To switch off sub-titles on Bush 26" HD ReadyTV - the following has just worked for me 19.1.10
1) Select Features on Menu options
2) Switch Analog Subtitle to Off
3) Change Subtitle Type to Hearing Impaired
Good Luck - Geoff - Newcastle
Nov 21, 2009 | Bush Televison & Video
Bush PDVD0707 personal dvd player will not play
Oct 03, 2009 | Bush Televison & Video
TV switching to standby
Hi.i had exactly the same problem with my bush 37 inch lcd tv and i took it to a friend of mine who is a t.v electrician he said it was a component in the back of the tv which he replaced and its now working fine.
Jul 05, 2009 | Televison & Video
Bush lcd 27006 standby flashing
Yeah your psu needs new capacitors.
Jan 06, 2008 | Bush 5693D 24" TV
RCA 32V524T TV Logo
1,137 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
