Question about Dictaphone 3750 Desktop Cassette Transcriber / Recorder
Foot pedal won't work with hands free microphone
We bought a used Dictaphone 3750 that came with a hands free microphone that has been adapted to fit into the phone record jack. When we press the phone rec. button the foot pedal stops working. Is there a way to use the foot pedal with the hands free microphone?
  • 5 Answers
The Unit will require a special port to be install for the use of an external micro phone. This company will do this for a nominal fee. www.dtpss.com 1-877-387-2838
Posted on Nov 08, 2011
  • 43 Answers
The 3750 won't let you control the telephone record jack. The only way you can get a mic to work using the Tel Rec jack is by pressing and holding the 'Tel Rec' button for about 1 second. But this isn't compatible with the hands-free operation.
If you're looking to do hands-free recording, it uses the built-in conference mic. Press and hold the 'Conf Rec' button for about a second and it should start recording. This built-in mic is located on the right-hand side of the machine near the front by the headset jack.
If you want to control the machine via a foot control while in Conference Record mode, you'll have to change the 'Foot Control Dictate' setting in the menu. Here's how:
1) Press and hold the 'Erase' & 'Search' buttons for about 5 seconds until the menu appears.
2) Scroll through the options until you get to 'Foot Control Dictate' and set this to 'Yes'.
3) Press 'Stop' to exit the menu.
4) Press the 'Conf Rec' button to enter record mode.
Now you should be able to control the start/stop of the record function via the foot control.
Hope this helps...
Posted on Apr 14, 2009
I need a handsfree headset recording device for the dictaphone 3750
Hello this is a great solution
http://www.tvps.com/Products/Nuance-Dictaphone-0421-C-Phone-Hands-Free-Overhead-Headset-with-Boom-Microphone---New__ECS-CMH.aspx if your unit is already modified for hands free with the 3.5 extenal jack mic input if not you also can send your unit to modified Send an email to service@tvps.com or call (805) 644-9525
Jun 08, 2011 | Dictaphone 3750 Desktop Cassette...
Any function I press on the foot pedal results in a request from the unit to "press conference". What do I do to make this work?
Hello you have your unit set up for Hands free recording Follow the next step
Press and Hold Search and Erase at the same time then you will be and the setup mode press play into you see hands free and press FF to say No then press Pay and press stop to exit.
Jun 23, 2010 | Dictaphone 3750 Desktop Cassette...
Dictaphone transcriber 3750 won't play, reverse, or go forward. What can I do?
Does anything show up on the display? Like 'No Cassette' or 'End Tape'?
Are you using a foot control? Does the tape move when pressing the buttons on the machine itself? Is the foot control plugged into the side of the machine (and NOT the back)?
Feb 18, 2010 | Dictaphone 3750 Desktop Cassette...
I need to record something with Dictaphone 3750 - I have no manual and there is just a Tel. Rec button. Help
If you press and hold the 'Conf' button, the machine will record using it's built-in mic (located on the right-hand side of the machine, closer to the front). It is probably recommended to get a microphone that plugs into the machine for better recording quality. Depending on what you're recording, you could get a handheld microphone or a telephone record adapter that plugs into your phone and the back of the 3750 (press and hold 'Tel Rec' to use that).
Aug 08, 2009 | Dictaphone 3740 Desktop Cassette...
Foot pedal FF or Rewinds when pressing Play
It's possible that there's a broken wire in the cable that connects the foot control to the machine. This usually happens near the plug that plugs into the machine, or by the end that goes into the foot control.
You can usually duplicate it if you put the auto-backspace up a bit and then hold down the play pedal on the foot control. While holding down the play pedal, try moving the cable near the machine or near the foot control in a circular motion. If the machine stops, rewinds or fast forwards, then odds are that the problem is with the cable.
Mar 13, 2009 | Dictaphone 3750 Desktop Cassette...
Dictaphone foot pedal
It would be easier/cheaper to buy another foot pedal.
The older style had "leaf" switches in them and they are adjustable from below the foot control. There are 2 screws underneath each switch. Loosen up the one closer to the front of the pedal (just a little) and tighten the one in the back the same amount. This will raise the angle of the switch to make it more sensitive (lighter pressure to activate).
Oct 10, 2008 | Dictaphone Audio Players & Recorders
VOX
On the right-hand side of the unit, there are two buttons with on/off positions. Both the Speaker and VOX options should be in the off position. When VOX is turned on, it only records when it monitors a level of noise. I do not have it turned on ever.
Jun 04, 2008 | Dictaphone 3750 Desktop Cassette...
Dictaphone 3750 Desktop Cassette Transcriber / Recorder Logo
167 people viewed this question
Top Dictaphone Audio Players & Recorders Experts
Alan W Kelly
Alan W Kelly
NOEL
NOEL
Pennywhistler
Pennywhistler
Are you a Dictaphone Audio Player and Recorder Expert? Answer questions, earn points and help others
