Question about Sony Cyber-Shot DSC-P92 Digital Camera
DSC T20 poor image problem
Hi, I have bought a brand new Sony DSC T20 only two weeks ago and took many pictures on different lighting, flash, etc conditions on different objects. I also took many pictures with auto settings. But once I transferred the images to the PC, I was shocked to see very low quality images. Though the images were taken with 8MP and 5MP settings, the resolution quality was similar to images taken by a low quality mobile phone camera (VGA). I tried to view the images on Philips 190S monitor, HP PC (Intel 82945G Express Chipset graphics adapter), 32 bit color, 1024x768. I also tried other non HD support PC's (ASUS & Toshiba) and the result was the same. Can it be with trying to view the images on non HD graphics cards, or a malfunction of the camera ? Regards
    Problem Solver:
  • 36 Answers
If you took the images at 8MP or 5MP settings, then normally you have a high resolution picture, was the picture clear at the cameras LCD monitor? As you said its like low res in your PC, please check the image file size 8MP resolution will be approx. 3Mb size, if its about that figure, then the problem is in the camera, if the file size is about 500K maybe its in the camera settings, PC cant affect resolution, unless you only have VGA card and monitor, hope this will help, thanks
Posted on Sep 14, 2007
SOURCE:
The camera vibrate when i took a picture
Your camera has a gyro image stabilizer. The Gyro is faulty as many are in these camera. Go into menu of the camera and turn of image stabilization. This should solve the problem.
Jul 02, 2009 | Sony Cybershot DSC-T20 8.1 MP Digital...
Flash not working?
I found this solution on another site and it worked for me. Good luck!
hi - thanks - you're right. I called SONY
last week. They told me to reset, as you describe. here's also what I discovered - the flash locks you out in Burst (fast frame) mode. The flash can't recover that fast. Out of Burst mode, you can control the Flash. Isn't it a much better camera with the flash?
Enjoy your W80! Thanks, Jim Connecticut, USA
Jul 17, 2008 | Sony Cyber-shot DSC-T20 Digital Camera
Problems with sony cyber-shot dsc-t20
Kindly initialize your camera from menu and camera will starts with factory default settings.
May 27, 2008 | Sony Cyber-shot DSC-T20 Digital Camera
Vibration when using the Sony Cyber-Shot dsc-t20
Well, it seems that this is either a manufacturing defect or a defective/sub-standard part being used in the product. It would do Sony well to address this problem immediately so that all of us Sony lovers would continue to believe in their products. If this can be solved via a firmware upgrade then I hope Sony can guide us through it.
Feb 22, 2008 | Sony Cyber-shot DSC-T20 Digital Camera
Sony cyber-shot dsc-w55 flash doesnt work
hi
the flash doesnt flash anymore, you may need to replace th bulb for that. the yellow light means its a warning that the bulb is wor out.
hope this helps
Jan 22, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Vibration problem
Sony has recently discovered that with certain units of its "Cyber-shot" DSC-T20 digital still camera, a symptom may arise in which the camera body may vibrate when it is powered on, due to a mechanical failure affecting the lens, and it prevents the camera user from being able to shoot.
To ensure customer satisfaction, Sony will provide a free repair service when this symptom occurs within certain units covered by the serial numbers indicated in the serial number validation box below.
We apologise for any inconvenience this may cause. Your understanding and cooperation would be much appreciated.
Symptom and cause
The camera body may vibrate when powered on, due to a mechanical failure affecting the lens. This prevents the camera user from being able to shoot.
Applicable model
Digital Still Camera "Cyber-shot" DSC-T20.
How to check the model name and serial number
The model name and serial number are indicated on a sticker located at the bottom of the camera.
Applicable serial number
To determine whether your DSC-T20 camera purchased in Asia Pacific region may be affected, click here to validate the serial number.
Model Name Area Serial No. Range Unit DSC-T20/B AU2 2257001 - 2501900 5,050 DSC-T20/P AU2 2258851 - 2485700 4,700 DSC-T20/S AU2 2261851 - 2501500 7,650 DSC-T20/W AU2 2265751 - 2502100 7,650Period of free repair service
From 17th July 2008 to 16th July 2011.
PLEASE NOTE these serial numbers are applicable to ASIA / PACIFIC check your own country sony website if your serial number is applicable as different regions will have different serial number for the DTS -T20, hope this helps
Dec 24, 2007 | Sony Cyber-shot DSC-T20 Digital Camera
PLZ HELP!!!
Thats exactly whats happening to mine at the moment..I dont no why. Did you find a way 2 fix it?
Dec 22, 2007 | Sony Cyber-shot DSC-T20 Digital Camera
Sony DSC-H7 - Pictures have yellow tint
Take the Camera back and get a Cannon......
I bought the WSC-80 for my parents and had the same problem. You will get Sony reps on this forum (and other support forums) telling you to "set the white balance" and "it happens with all camera's because of the white balance."
They are trying to get people who haven't bought their P.O.S. camera to think the end user is the problem....you are not the problem.
I have sent my camera in twice now, once because it was blurry (they reset the lense....everything was fine) and now I am getting the yellow tinge on my pics.
I can take three pictures in a row (within seconds) the light is the same, settings are the same, people are the same, etc and two will be yellow and the other will be perfect.
Research all the Sony Models, they suffer from the same problem.....I will NEVER buy Sony again, I bought the "top of the line" for my parents for x-mas and sony made me look like a fool.
Shame on you Sony....
Nov 02, 2007 | Sony Cyber-shot DSC-H7 Digital Camera
Viewing is fine, taking pictures is not
This sounds like what started happening with my camera a few weeks ago. I found that turning the LCD screen off during picture-taking allows me to take pictures. I then have to go into review mode to look at the pictures I took using the LCD screen. Definitely not a great fix. I'm trying to locate a firmware upgrade that may solve it.
Sep 01, 2006 | Sony Cyber-Shot DSC-W1 Digital Camera
Sony Cyber-Shot DSC-P92 Digital Camera Logo
105 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Dan Dangel
Dan Dangel
Level 1 Expert
Are you a Sony Camera Expert? Answer questions, earn points and help others
