Question about Sharp VC-A420U VHS VCR
Sharp vc-a422 I want to hook up my vcr I already have a cable box and dvd player hooked up i need to know what other cords I need and where to put them thanks
    Genius:
  • 1,139 Answers
This is easy in a nutshell. from the cablebox into the VCR RF connection (ant in) then from the VCR RF into the TV RF in. The from the DVD composite video out and audio out into the VCR composite video in and audio in. This make the VCR the hub of your setup the VCR should be set to channel 3 and you can switch between the VCR and the DVD by using the VCR remote. Now for the cords: 1) Cable to VCR RF = Coaxial 2) Composite Video and audio out = RCA patch cable 3)Composite Video and audio in = RCA patch cable That is it. If your TV can support multiple inputs then use it as the hub. Cable Box to VCR RF (Coax cable) VCR to TV RF(coaxial cable) or VCR to TV Composite video, or TV Component Video (RCA Cable) DVD Player to Composite video, or TV Component Vido (RCA Cable), or Svideo (Svideo cable)
Posted on Sep 15, 2007
SOURCE:
How do you hook up cords to cable box & television
WELL IT SEEMS U HAVE TWO PROBLEMS :
1ST YOUR rF SIGNAL IS NOT GETTING THRU , THIS IS A ROUND CABLE WITH A SCREW ON END TO IT , THIS ONE MUST 1ST COME INTO YOUR HOME AND GO TO CABLE BOX , THEN LEAVE OUT OF CABLE BOX AND ENTER VCR THEN LEAVE OUT OF VCR AND GO TO RF INPUT OF TV ( HAS TO BE HOOKED THIS WAY WONT WORK ANY OTHER WAY) SET OUTPUT OF VCR TO CHANEL 3 SET OUTPUT OF CABLE BOX TO CHANNEL 3 SET TUNER OF VCR TO CHANEL 3 , AND LAST SET INPUT OF TV TO rf CABLE ,CHANEL 3 , NOW YOU CHANGE CHANELS ON CABLE BOX only
2ND YOUR DVD PLAYER HAS NO RF OUTPUT SO YOU NEED TO CONNECT BY ONE OF THESE MEANS (HDMI, RGB, COMPOSITE) ALL THESE REQUIRE A DIFFERENT CABLE YOU DECIDE , THERE HOOK UP IS PRETTY MUCH ONE WAY SO I WONT ELABORATE ON EACH METHOD , BUT TV NEEDS TO BE SET TO CORESPONDING INPUT TYPE YOU DECIDED ON
Nov 11, 2015 | Magnavox DV220MW9 DVD Player VCR
How to hook up vcr and tv using digital adapter
You can hook up the VCR directly to the TV; you don't need to hook up the VCR to the adapter. If you already had the VCR hooked up to the TV, you don't need to change those connections.
Jan 29, 2015 | Televison & Video
I have an older TV with only an antenna hook-up, a VCR, a DVD recorder and a converter box that I would like to hook all together. I can get the VCR to work, but don't really know how to hook the DVD...
Try this. You will need 2 RF cables and a RCA cable that has a red, black, and yellow plug on each end.
  1. Plug the antenna signal into the converter box.
  2. Connect the RF output (TV out) of the converter box to the RF input on the VCR
  3. Connect the RF output (TV out) on the VCR to the TV
  4. Finally, plug the DVD recorder into the converter box also, but use the 3 RCA cables that came with it (audio left, right and video).
Apr 13, 2010 | iLO DVDR05 DVD Recorder
Trying to hook up magnavoc Dv220mw9 to my cable box & tv
Sorry, looks like it didn't load right with that last solution. Let me try again....
CONNECTING VCR
If this doesn't get it let me know I will try to walk you through it further.
Good Luck....
Jan 13, 2010 | Philips Magnavox DVD/VCR Dual Player
Hook up of magnavox zv427mg9
I have a magnavox dvd recorder/vcr combo (ZV427MG9A) connected to my Sharp hdtv via hdmi cord, Can anyone tell me simple setup steps to make it record and play on either sides. I have read instruction book over and over and it is still not recording to disc or tapes. I also have Charter Cable connected. Can you tell me what do i need to do to make it work. H-E-L-P!!!!
Nov 17, 2009 | Philips Magnavox DVD+R/+RW Recorder/VCR
How do I hook up my old VCR to an insignia tv?
You will need a converter to record onto a VCR. I can't remember the when the FCC require VCR to have digital, but I know yours old enough it has an analog tuner. Take your antenna connection to the in on the converter box, then you can take the out from the converter box to the in on the vcr and finally take the out to tv to the tv. To record you have to have the vcr on 3 or 4 and use the converter box to do the channel changing.
Another way would be take the in to the converter and use RCA cables to the line in on the vcr, and line out to the to the tv. This will give you stereo sound.
Aug 10, 2009 | Panasonic Televison & Video
Hook-up
first you do connect cable to your > combo VCR / DVD player & recorder then connect to > to your TV:
cable coax output or if that cable have video/audio ouput is going to INPUT >to combo VCR / DVD player video / audio output is going to INPUT > to TV,.that's the time you can record and playback;
click below for more information in hooking up:
DVD Players/Recorders: Home Theater Setup, Installation & Hook Up ...If i have helped,please click fixya,it is the only way i get paid for my work ,also please consider leaving feedback...
Good luck ,and Thank you in advance:
Jul 15, 2008 | Televison & Video
Converter box
the digital box has to hooked up the rca plugs on the bac of the vcr if you want to use the vcr (you will only be able to pick up channels throught input and the box will have be set on the channel you want to record. You need a switch to hook the vcr and dvd player both up. the atenna cord can be attached to the back of the convertor box then attached to the tv.
Jun 15, 2008 | Insignia Digital-to-Analog Converter for...
Dvd/vcr without cable hook-up
If ** cable TV hookups exists, then the only inputs you can use are the line-in along with audio left/right. You've probably got a slew of output connections. Your unit does **t contain a tuner (which would allow you to use a cable input). You need to have a cable box or other device (vcr/tv) that has outputs compatible with the input of your dvd/vcr. A lot of dvd/vcrs are that way. It actually saves you some $$ since most cable boxes (especially HDTV compatible) already have the required outputs on them.
Mar 09, 2008 | Memorex MVD4543A
Can't hook up DVD player
I have a cable box and a Samsung DVD-V5500 player. How do I hook up the 3-part cable to the back of the player?
Jan 12, 2008 | Protron PD-007 DVD Player
Sharp VC-A420U VHS VCR Logo
275 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
