Cannot connect wireless through this router. Having a problem setting it up
Cannot connect wireless through this router Having a problem setting it up
  • joecoolvette
    joecoolvette May 11, 2010
    Should like to know what maker and model, of router you're speaking of.
    Would also like to know how you're going about setting wireless up, and to what computer, (name and model number)
    Plus, what wireless adapter you have installed in your desktop computer.
  • 227 Answers
Just as a general rule: You should only have 1 DHCP client, either your modem or your router should be the DHCP client, not both.
Posted on Apr 13, 2009
I have a new laptop computer but it wont let me go to internet explorer and connect to my wireless router
1. First try and power off your modem, router and desktop/laptop. Then power on the modem, then the router, and then finally the desktop/laptop. Please do this in that order, allowing 60 seconds in between each device to enable the device to be fully booted and able to accept connections.
2. Update the drivers for your wireless network adapter via Windows Update, or by using the website for either the company you bought your PC/Laptop from or the manufacturer of your networking device.
3. Ensure that your router is set to broadcast it's network name (SSID), ensure that you are connecting to the correct wireless network (SSID) and that you are using the correct WEP/WPA passkey on both devices.
a. Please use "Windows Connect Now" or "Wi-Fi Protected Setup" if available on your wireless router to ensure that the connection is setup correctly.
4. If you are trying to use WPA or WPA2, please ensure that both your network adapter and wireless router support this protocol. If you are having issues detecting your wireless network when using WPA or WPA2, try configuring your router to use WEP instead and see if you can connect.
a. Please note that the change between WEP/WPA/WPA2 will need to be made on both your computer and wireless router.
b. If you are only able to connect using WEP, then your networking hardware may need a firmware upgrade. If you are not comfortable doing this yourself, please call your hardware/router manufacturer for help in doing this.
5. If you are having a problem with your wireless connection after resuming from hibernate or sleep, or are having intermittent connectivity issues, try to adjust your Power Management profile to change your Wireless Adapter Settings to Maximum Performance.
a. To do this click "Change Plan Settings" next to your Power Profile, and choose "Wireless Adapter Settings" and set it to Maximum Performance. You should do this with all of your power profiles. Additional guidance is available here: http://windows.microsoft.com/en-us/windows7/products/features/power-management
6. Call the support line for your router manufacturer. It is likely that neither Windows nor the router are having problems, it is simply an issue of getting the configuration settings on both set up to work correctly together. The router manufacturer will be the best resource to know how to configure their device. Most of the contact numbers are listed here: http://support.microsoft.com/gp/vendors/en-us
Jan 21, 2011 | NetGear WGR614 Router
Trouble connecting to router
Make sure SSID broadcast is switched on under wireless settings. You will have to connect via ethernet cable first to do this.
Then, if PC's can see it, once logged in and set to automatic you can turn off SSID if you like.
Personally I leave it on and set high security using MAC addresses so I don't mind if my router broadcasts it's existence.
Apr 20, 2010 | Linksys Wireless-G WRT54G Router
D-link 615 wireless router having problems connecting with my macbook pro. keeps dropping connections.  the airport status always shows its scanning.  always very slow.
You will need to check the wireless settings of the router. If possible then upgrade the firmware of the router. try changing the wireless channel of the router. Is there any computer connected to the router? If not then connect the computer to the router and open the set up page of the router.
Click here for step by step instructions
Apr 05, 2010 | D-Link DIR-625 (790069292637) Wireless...
I am unable to enable wireless networking - the
So your on the GUI page of your router? you need to create the network name and password using your router connections. Make sure you have wireless adapter for you to be able to connect your computer wirelessly. If your having a problem to configure the wirless set up using your router contact your ISP.
Feb 21, 2010 | D-Link Xtreme N DIR-655 Wireless Router
Im having trouble securing my wireless router
Is there any computer connected to the router ?
If not then you will need to connect the computer to the router.
check the IP address of the computer.
open the router set up page of the router.
Here you can change the wireless settings of the router.
Click Here for step by step instructions
Jan 14, 2010 | Linksys Wireless-G Broadband Router
PS3 and Netgear WGR614 V7 Router
Basically the PS3 wireless settings needs to be configures with the Netgear wireless router settings.
To test if the modem is connects to the Internet, connect a computer into the modem, if it works then the modem is configured correctly. If it doesn't work, then contact your ISP and get them to test your modem connection.
For details on how to configure the PS3 click on the WEB link :-
wii.php">http://fixhomenetwork.com/xbox-play-station-wii.php
Dec 20, 2009 | NetGear WGR614 Wireless Router
Upgrade of router giving connection problems
You need to check the settings on the wireless adaptor to make sure it is the same as the new router. If you had set the old router with a password, then you need to set the new one the same way. If the new router is not set with a password and the connection is open and not secured, then you need to change the settings of the computer wireless adaptor.
Jun 26, 2009 | Dell 1450 (D1450U) Wireless Adapter
Setting up Netgear Wireless-N router
try this plug up a line to laptop to modem to check to see if you can get connected if so then make sure you are on the same network and if so then call comcast to help you setup the laptop wireless settings in sound like the settings online doesn't have the laptop enable to accept the laptop
Dec 01, 2008 | NetGear WNDR3300 - RangeMax Dual Band...
Connecting wireless router to laptop computer
Try changing the channel on the router. It would be better to isolate the problem first by trying to connect to other wireless networks on your laptop or having someone's laptop connect to your home wireless network.
Sep 03, 2008 | Linksys WRT54GX2 Wireless-G Broadband...
Connecting a laptop to belkin wirless router
Check the wireless settings of your router, ssid, channel and wireless security. Set thoe information on your laptop so that it will work wirelessly with the router.
Aug 17, 2008 | Belkin Computers & Internet
Computers & Internet Logo
David Payne
David Payne
